GTR Class 377/387 cascade updates 2026
physics34
1 Dec 2013
I should also add that there are differences in the interior, namely that the Class 377 has good old fashioned comfortable seats and the Class 387s have ironing boards. Nearly all of the seating throughout the train is 2+2 as well, rather than the mix of 2+2 and 2+3 present on most Class 377s.
In general, the inability to operate Class 377s and Class 387s together I would say is it a bit of bummer. However, if they are predominately allocated to either the West or East Coastway generally in the long term, its not much of an issue, given the trains usually operate as single and uncoupled 4-car units, and I suppose if they ever needed to extend them to 5-cars should demand ever increase (which I highly doubt given fares will probably end up skyrocketing at this rate after this so called "trial" on LNER, which there is another thread all about), then they could do that with some units which are semi-permanently assigned to Southern. Although most platforms can handle coupled 8-car units, in most cases its of little importance to regional services in most cases.
I suppose one of the future refreshes they could do with those units will probably be eventually to repaint them into Southern colours, so they more closely match the Class 377s which they are partially displacing, presumably to allow a few to head off to Southeastern, whilst still boosting capacity (presumably) on London suburban routes, given Class 377/3s could be soon be made largely redundant except on Bognor Shuttle and Seaford services (where you can't really justify 4-car trains to the same extent as other routes.
Unlikely they'll get a full repaint with GBR on the Horizon. With Gat Ex 387s running around on the coast.. and on Bognor/Eastbourne to London Bridge peak services, it's a bit of a mess.
I believe most 387s will run services on the coast. What they replace and where those units go is up for debate (apart from the 13 going to SouthEastern).
Personally... I like to see the return of peak Cat and Tatt to Vic services.. and more longer metro trains on Saturdays.
Kite159
27 Jan 2014
West of Andover
387129 even had Southern route maps displayed above the doors, although I will confess into not looking at them in detail to see if they still include Guildford & the Sutton loop services Southern ran Pre Covid.
WiFI was still "Great Northern" though
Peter Sarf
Croydon
My bold - Schtum, that will mean the WiFi will work better as less using it !.
Class455
19 May 2016
Looks like the GWR 387’s are being swapped with another three 387’s as the following moves are in for tomorrow:
A few pictures have emerged of 387172 now wearing a GN logo so it would strongly indicate they’re being swapped, for now anyway.
xxjcz
14 Mar 2024
london
Apparently they have an SDO software issue and will be going back to GN until the new software comes.
4BEP
21 Jan 2022
Loose
Hiya, sorry just to confirm who is “we” and told by who? :)
Expect them to be used on Mid Kent and Tunbridge Wells services as they are intnded to be Mainline stock.The CHX to Gillingham service is a Metro service.
I assume by "Mid Kent" you're referring to the Maidstone East Line and not the Hayes line, the latter being called the "Mid Kent line" (even though it's a complete misnomer).
Blindtraveler
28 Feb 2011
Do we know if the units that Southeastern will inherit have had power socket? Fitment done? The existing 377 that Southeastern have or have been using sporadically. Do not have these yet unless they've done them recently. And whilst it's very much a first world problem, it's also a little bit naughty of them to shout on their website that all mainline units now have at seat power
PGAT
13 Apr 2022
Selhurst
Yes 377121-132 have plug sockets
xxjcz
14 Mar 2024
london
Yes apparently the 377/5’s will be aurora refurbed as well
8 Feb 2023
West Sussex
I suspect that means that all units should get plug sockets fitted if they are not already fitted, given that has happened with pretty much all of the Southern Class 377s, other than some of the /3 subclass which seems like that was last in the queue to be done. Either way, its a pretty light refurbishment anyway, so not much to really be done.
Also, is there any chance they might have the seat covers changed, because it seems they all have Southern seat covers as the units were originally meant for Southern, before basically immediately moving to First Capital Connect, which then became Thameslink before moving to Southeastern. Given if the Seat covers are worn out and need to be changed, they might as well fit something else to them other than that of the neighbouring operator.
Nicholas Lewis
9 Aug 2019
Are the 377/1's moving going into SE stock and their mtce regime or still having to be cycled back to the Southern like the /5's.
8 Feb 2023
West Sussex
While I obviously can't confirm this beyond all doubts, I suspect that will be the case, given Selhurst (and probably other Southern depots) obviously have all of the equipment designed specifically for Class 377s, although I suspect some of the lighter maintenance could easily be done at SE's depots, alongside the Class 375s. That is unless Southeastern or any future operator (of either trains and/or infrastructure) invests in improving facilities at the Southeastern depots to allow Class 377s to be fully maintained there, saving them having to constantly cross over to Southern's network for maintenance. Maybe in the very long term, they could even look at converting the Southeastern Class 377s into Class 375s, in turn allowing those fleets to operate together more easily and be maintained at the same place.
Nicholas Lewis
9 Aug 2019
Is there a material technical difference between a 375 and 377 as i believe its the same traction equipment but not sure about software build.
Siemens Staines
30 Jul 2015
From this evenings list it looks like 387172 & 387173 are back with GN and have been exchanged with 387123 & 387126?
387101 Stabled at Worksop Reception GB Railfreight (arrived 18/08/2023 01:08)
387102 1T48 17:09 Kings Cross to Kings Lynn (arrives 18:58)
387103 At Cambridge Sidings North (arrived as 5C28 at 14:08, departs as 5T55 to Cambridge at 18:45)
387104 Stabled at Hornsey Depot (arrived 23/12/2024 10:03)
387105 2C51 16:56 Cambridge to Kings Cross (arrives 18:21)
387106 2C46 16:57 Kings Cross to Cambridge (arrives 18:23)
387107 Stabled at Hornsey Depot (arrived 19/07/2024 23:59)
387108 At Kings Cross (arrived as 2C47 at 17:21, departs as 1T50 to Cambridge at 17:39)
387109 At Cambridge Sidings North (arrived as 5C28 at 14:08, departs as 5T55 to Cambridge at 18:45)
387110 1T48 17:09 Kings Cross to Kings Lynn (arrives 18:58)
387111 1T49 16:40 Kings Lynn to Kings Cross (arrives 18:32)
387112 At Kings Cross (arrived as 1T45 at 17:32, departs as 2C50 to Cambridge at 17:57)
387113 1T51 17:10 Kings Lynn to Kings Cross (arrives 19:02)
387114 1T49 16:40 Kings Lynn to Kings Cross (arrives 18:32)
387115 Stabled at Letchworth Carriage Servicing Depot (arrived 23/12/2024 10:22)
387116 At Kings Cross (arrived as 1T45 at 17:32, departs as 2C50 to Cambridge at 17:57)
387117 1T46 16:39 Kings Cross to Kings Lynn (arrives 18:28)
387118 Stabled at Hornsey Depot (arrived 23/12/2024 10:03)
387119 2C46 16:57 Kings Cross to Cambridge (arrives 18:23)
387120 1T51 17:10 Kings Lynn to Kings Cross (arrives 19:02)
387121 At Cambridge (arrived as 2C42 at 17:24, departs as 2C55 to Kings Cross at 17:56)
387122 Stabled at Cambridge Sidings South (arrived 23/12/2024 00:01)
387123 Stabled at Lovers Walk T&RSMD (arrived 23/12/2024 11:39)
387124 Stabled at Hornsey Depot (arrived 21/12/2024 12:30)
387125 2C51 16:56 Cambridge to Kings Cross (arrives 18:21)
387126 Stabled at Lovers Walk T&RSMD (arrived 23/12/2024 11:39)
387127 1T47 16:48 Ely (Cambs) to Kings Cross (arrives 18:02)
387128 Stabled at Lovers Walk T&RSMD (arrived 21/12/2024 00:38)
387129 At Southampton Central (arrived as 1N44 at 17:31, departs as 1N51 to Brighton at 17:50)
387172 At Kings Cross (arrived as 3T50 at 17:17, departs as 1T50 to Cambridge at 17:39)
387173 Stabled at Hornsey Depot (arrived 21/12/2024 12:35)
387174 Stabled at Selhurst T&RSMD (arrived 20/12/2024 12:59)
387301 At Kings Lynn (arrived as 1T42 at 17:28, departs as 1T53 to Kings Cross at 17:40)
387302 At Kings Lynn (arrived as 1T42 at 17:28, departs as 1T53 to Kings Cross at 17:40)
387303 Stabled at Hornsey Depot (arrived 23/12/2024 08:59)
387304 At Cambridge (arrived as 2C42 at 17:24, departs as 2C55 to Kings Cross at 17:56)
387305 1T50 17:39 Kings Cross to Cambridge (arrives 18:30)
387306 1T47 16:48 Ely (Cambs) to Kings Cross (arrives 18:02)
Class455
19 May 2016
Yep that’s correct, saw both 123 and 126 outside Selhurst Depot yesterday. They’re now at Lovers Walk I believe
8 Feb 2023
West Sussex
I think there are some very slight differences between them, at least enough to prevent them from working together, and requiring SE Class 377s to have to go to Selhurst. If they were completely identical, then they would have been reclassified to 377s when their couplers were changed from Tightlocks to Dellners.
I believe 377s also don't have clearance to go to Dover via Shakespeare Tunnel, even though the same body profile and end-door provision means they must be okay in terms of evacuation capability (or if they now can there was a time they couldn't).
Mollman
21 Sep 2016
Preston
Might just be one of those paperwork things where the clearance was for 375s as at the time the 377s were also classified as 375s. No one has bothered to update the paperwork to reflect the changes in classification because there has been no need.
TT-ONR-NRN
30 Dec 2016
Cambridge
377s have DOO cameras fitted whereas 375s do not
Which makes sense, considering they’re majority used for Southern Metro services for which DOO is sensible, rather than 375s which predominantly work the mainline routes of SE.
Do the existing 377/5s at SE a) also have DOO cameras and b) utilise them when in operation with SE in DOO areas? (I know they don't in guard-operated areas like the Maidstone East line beyond Otford).
richierail72
15 Feb 2020
Queenborough
Does anyone know if 377121 and 122 are in service today?
377121 & 122 are in passenger service for the first time today, working together on services between Victoria and Ramsgate/Dover Priory via Chatham.
They are still in Southern green livery, but have Southeastern branding down the sides.
I've been told that the 377/7s are the only units left on Southern that is having the Aurora update (power sockets etc.), so that indicates the /1, /2, /3, /4 & /6 units have been done.
Once completed, then the SE 377/5s will be updated.
TT-ONR-NRN
30 Dec 2016
Cambridge
Thank you for this information. What a shame they didn’t escape before Southern ruined the PIS ;)
Oh? Will the work be identical for SE as what Southern ordered? Will we lose the nice PIS from these too?
Southern Dvr
13 Oct 2010
Does the 377 DOO Camera make them wider and thus a problem for the Shakespeare Tunnels?
remember almost all of SN is now DOO not just metro.
xxjcz
14 Mar 2024
london
I believe 387172-387174, 387301-306 and the 379s will be aurora upgraded too. I heard it from a southern worker on a fb group so not sure how true it is but it would make sense to aurora upgrade all electrostars that are with GTR.
I do hope one day they find a way to upgrade the software on the 379s to allow them to couple with the remaining 387s at GN.
Peter Sarf
Croydon
It might be easier to "upgrade" the software on the 9 or so 387s that might want to work with 379s - genuine question ?.
It was so much easier back in the 1960s- 1990s.
