bluegoblin7
None have moved north for conversion yet - this is probably still the plan because they wanted some complete units to arrive (built from ex 460 vehicles only) before releasing any 458s.
I haven't seen any up to date diagrams, but if there are more than 24 in total in service per day I'd be surprised, the utilisation of the class hasn't generally been too high.
There are no rovers that I can think of in the area, but the main use apart from Waterloo - Readings is going to be the Guildford - Ascot shuttles - the latter uses 2 trains per day IIRC, and if you wanted to see them the only easy answer seems to be a spell at Ascot?
Two are used on Guildford-Ascots as mentioned above. They'll generally stick around on the shuttles for a couple of weeks before they get swapped. The rest will all be out on Waterloo-Reading or peak Waterloo-Aldershot via Ascot services. The best place to get them is the Travelcard Zones and then make a trip to Ascot or Guildford for the other two. If you want to ride them all the best bet is Clapham Junction-Richmond moves, it's a fairly short connection at both ends. The two on Guildford-Ascot services can be done in half an hour since they follow each other. Catch one Guildford-Ash and the other back. You'd need to leave Guildford at 0800, 1030, 1300, 1530, 1800 or 2030.
Usually three of four parked at Wimbledon depot each day as well, visible from anything on the main line.
Thanks to all for your help with this - I'll be heading out in the next few days and hopefully the trip will be fruitful. Cheers!
