Our new ticketing site is now live! Using either this or the original site (both powered by TrainSplit) helps support the running of the forum with every ticket purchase! Find out more and ask any questions/give us feedback in this thread!
Sounds correct to me and shows what a versatile unit they've been with quite a few interior permutations as well. Given they were BR's first MkIII based AC EMU you would have thought they would have more interest. Some are over 40 years old now although may not have done those years in traffic as they were stored initially due to DOO dispute on BedPan although 701's will take the accolade now for being stored longest before passenger use.
Not as if they’re all being scrapped like the 455s will most likely be - at least one of the DTSOs from 345 was preserved by the East Anglia Railway Museum. Don’t get me wrong, I’ll miss the 317s, but it’s not as if I won’t be able to see (part of) one again!
Usually one booked on the 0900 1200 1500 Stratford to Bishops Stortford services and the Meridian Water workings in between. Those services they work. However Usually also locally on 1209 1409 1609 ex Hertford East to London Liverpool Street as well. 1153 1513 ex Cambridge services as well.
To London Liverpool Street have been previously all this week.
Personally when those services work out which time at Tottenham Hale including the return working to corrosponde with them and can catch from there or even Broxbourne.
1200 will be 317511+317337 and 1209 up from Hertford is 317340+317339. Someone has been busy putting up labels on 317340 which read "Farewell British Rail Class 317."
Mad isn't it. Publish an end date and the world and its dog points a camera. The 317s are basically 455s but have toilets, go faster, have louder motors and are driven much more enthusiastically. Yet they will fade away and hardly anyone will notice. On a note of trivia, I think they have worked out of more London termini than any other straight AC EMU, namely St Pancras, Moorgate, Euston, King's Cross, Liverpool Street and Fenchurch Street. I managed to have 317342 out of four of them.
Reading the above post got me thinking - does anybody know if all 48 of the first series units worked out of both Fenchurch Street and Moorgate at some point?
I know the LTS had, in theory, dedicated units with a green stripe in lieu of a red one - but I seem to recall Thameslink used 1 or 2 pairs daily for peak Moorgate workings.
Yes moorgate did to Bedford and in the peak can remember in first capital connect days. Also remember occasionally to Norwich. But quite common also earlier to Harwich on the boat trains. Moorgate can remember the 3173 series most certainly there the ones allocated to First Capital Connect.
Also St pancras high level if low level was ever closed.
The first series were built for the Bedford route in the early 1980s.
As regards Fenchurch Street, there were about 20 units based at East Ham in the late 1990s. They moved away when the 357s arrived but then the 357s were grounded for a few months so three random pairs of 317s were hired in from WAGN each day. I can personally account for around 30 of them so it seems likely that all 48 did run to Fenchurch Street. However I have no way of proving it.
The first build of class 317s were originally for the BedPan service which included trains to/from Moorgate so all of 317301-348 will have worked there.
The first chapter of class 317 operation to/from Bedford ended with the start of Thameslink in 1988, but class 317s to/from Bedford have had more comebacks than Frank Sinatra which I think are off topic here.
317347 317504 the other pair in action on the 1513 from Cambridge North to London liverpool Street also will form the 1735 and 1905 Express from Broxbourne to London liverpool Street this evening.
Recently just Saturdays only since early April only one diagramm was used with a pair on the Stansted Express. However last Saturday sadly non was out. Even weekdays this week has only 6 out. It could be a strong possibility now no more out at weekends. Unless a Very short term use of one is needed ie 720 failure. However weekends looking like possible they could have finally finished on booked workings.
TUESDAY 31ST MAY 2022.
1409 2035 Hertford East to London Liverpool Street was 317339 317340
2S36 1500 Stratford to Bishops Stortford was 317502 317506
2H43 1513 Cambridge North to London Liverpool Street was 317343 317501.
From a good source of mine who travelled on them that day.
Friday 03rd June 2022.
317347 was with 317504 again on the Hertford east lines.
However 317338 was with 317508 on the bishops stortford to Stratford services but only to around mid day due to a fault on 317508. Which on Friday afternoon saw 720568 take over.
However 317347 might have been Friday 03rd June 2022.
Unless it was out Saturday 04 june 2022. Because a pair on Saturday was on the Hertford east turn due to a 720 playing Stansted Express.
Last day for 317347 was Friday. I would assume that 317504 is safe otherwise why split it off 317347? It seems likely that the other scrappers are 317507, 317510, 317884 and 317886.
I would say so. Also 317886 and 317507 haven't been in service in ages.
Surprisingly 317347 has been pulled.
317884 has been away a little as well.
317510 has run recently but not for past fortnight or so? Plus also hasant been in recent health.
However if today can produce 10 sets.
Leaving no spare capacity whatsoever if anything else fails 317 wise or 720 wise?
Obviously you need 1 spare for rescue duties. Also with changes of temperature due to weather conditions 720s don't like. Not the best of decisions to send 6 in a large hit to ely.
Especially as 317347 is a good runner.
Saturday 04th June 2022.
1. 317343 317501 performed Hertford East to London liverpool Street services.
Monday 04th June 2022.
1. 1230 2S26 Stratford to Bishops Stortford and of peak services was 317338 317508.
2. 1500 2S36 Stratford to Bishops Stortford the usual 317 was 317343 317501.
3. 1409 2o35 Hertford East to London Liverpool Street the usual 317 was 317339 317511.
4. 317506 solo on 1453 2h41 Cambridge North to London Liverpool Street.
5. 317502 also solo on the 2023 1109 Hertford East to London liverpool Street.
Then back together 317502 and 317506 on the 1628 1h28 London liverpool Street to Cambridge north.
6. Also 1153 2h29 Cambridge North to London Liverpool Street was the usual formed 317337 317347.
4 extra 317s out in the main.
Due to 720523 720536 As a pair on Stansted.
Interesting to see what happens or could happen if to many 317 ely.
Whilst 720 or 745 fail? .
Correction typo error
1153 2h29 cambridge north to London liverpool Street was 317337 317340.
Meanwhile 5q44 1037 London liverpool Street to cambridge ecs was 317347 with 317881. Most likely and a sad end on their final run together under their own power on Great Anglia Western lines before Tommorow beckons.
Yes most certainly would say so 1153 Cambridge north to London liverpool Street is a good one to produce and still usually diagrammed to be one.
Plus hopefully a few more might occur especially as 720 are covering for 745 in Stansteds recently. However 1153 does return for 1513 Cambridge north to London liverpool Street as well. More than sure you will come across one on that circuit.
I went through Cambridge North at about 11.05 and 317343 and 317501 were parked in Platform 3.
When I arrived at Cambridge 317502 and 317506 were heading North.
317881 and 317347 were parked up in the Station Sidings.
I then headed to my meeting but got back to the Station slightly early, at around 2.50, so managed to jump on 502 and 506 to Cambridge North to meet my train South to Kings Cross.
I did pass a pair heading North but couldn’t confirm their numbers by sight.
Also out and about today was
5G44 317884 317886 on the 1037 London liverpool Street to Cambridge final in service move ready for Ely and now of lease.
37800 taking 317347 317881 for storage to ely.
Meanwhile from a very reliable source off mine.
1. 2043 1609 Hertford East to London Liverpool Street was 317339 317511
2. 2H48 1743 London liverpool Street to Cambridge previously having been on the Stratford to Bishops Stortford off peak was 317337 317340.
317s out and about today was 3 pairs on the following.
1. 2035 1409 Hertford East to London Liverpool Street 317506 317507 .
2. 2536 1500 Stratford London to Bishops Stortford was 317337 317340
3. 2H43 1513 Cambridge North to London liverpool Street was 317338 317504. .
3 pairs. 6 317s out today.
We are aware of an issue with emails from the Forum to Microsoft-based email accounts (hotmail/outlook/live.com email addresses). This is being looked into currently, thanks for your patience meanwhile.
