West Coast Mk1s
WesternLancer
12 Apr 2019
Could they use MK1s alternated in formation with CDL fitted MK2s and only allow access to the MK1s via the door & vestibule of the adjacent Mk2s with the Mk1 doors locked out of use? Or are there issues with emergency evacuation that would not allow such a strategy? I don’t think there’d be much issue with things like loading and dwell time given passengers are probably not carrying a lot of luggage or detraining at intermediate stations.
I suspect the problem with that sort of approach is that in an actual emergency with confusion / possibly fire / whatever / going on people's instinct is to just go for what looks like a door near where they are and then find they think they are trapped and don't know what to do to exit quickly - so it's probably not acceptable approach from a safety evacuation point of view. - Just my hunch.
Spaceship323
24 Jan 2020
Nuneaton Trent Valley
The rules state that a passenger vehicle on the mainline must have CDL. I think we're beyond trying to find a solution to allow otherwise
Wilts Wanderer
21 Nov 2016
I think they’ve done the alternating Mk1 / Mk2 thing on the Jacobites in the last year or two but it’s pointless as the Mk1 coaches can’t be used to carry passengers.
28 Oct 2017
From an authenticity point of view I can appreciate it looks and sounds odd to see (say) a Black 5 with an air pump on the running plate slapping away while the loco is stationary but it’s better than not seeing the loco in use at all!
If you want to avoid the looks, I believe Tornado has the air pump it hidden somewhere in the tender. Presumably it would not be impossible to fit an uprated electric turbo-generator and then hide a modern electric air compressor somewhere out of the way, if the exhaust beat is that much of an issue. Although having your Black 5 start up like a class 508 might be even weirder!
Wyrleybart
29 Mar 2020
South Staffordshire
Good idea but.
WCR don't have an agreement to operate 60163 anymore
You would still need bright orange ETH jumpers and cables on the buffer beams
The turbo genny would need to be quite substantial to provide ETH to the coaching stock
I very much doubt the A1 company would agree to using 60163 on the Jacobite, particularly as it would not be the easiest of locos to run 50% of it's time in reverse with that tender leading.
The idea loco for the Jacobite was Ian Riley's "pocket rocket" 76079 with wonderful tender cab vision, and I wonder why he sold it.
43096
23 Nov 2015
Good idea but.
I thought we were talking about fitting air brakes, rather than fitting ETH to a kettle?
28 Oct 2017
Yes, the suggestion was getting the kettle to haul air braked stock. If you need ETH as well, then add a generator van. I wonder if you would be allowed to provide brake air pressure from a compressor on the train as well? Or does that have to come from the loco? The loco would still have the control for the brake system, just a different source of pressure for the reservoir pipe.
Chris125
12 Nov 2009
Isle of Wight
Cutting nose off to spite face still! I don’t remotely understand the logic of expensively-overhauled locos with 10-year boiler certificates sitting in a yard unused, on the basis of the cost of fitting said locos and the rolling stock with the air equipment.
Vintage Trains have fitted their vacuum braked fleet with CDL, the issue isn't fitting air equipment.
renegademaster
22 Jun 2023
Croydon
Yes but West coast likely thinks that's too expensive. The logic being fitting air brakes to 5 locos would be cheaper than fitting CDL to 20 coaches.
Wether it actually works that way I have no idea. WC have probably come to the conclusion that running Tangmere/Clan Line and the Black 5s weekly til they fall apart is cheaper than doing either of the other options. Their Vac break locos can circulate around the steam gala circuit
Yeah, you wouldn't need the locos to provide ETH , WC trains almost always have a 47 on the back
Wyrleybart
29 Mar 2020
South Staffordshire
And that is the problem to those of us who wonder.
A Mk1 is an infinitely simpler vehicle to maintain even if it might need a lot of new steel welding in. The vehicle has it's electric lighting supplied from an axle driven belt drive alternator. The bodyshell sits on a separate chassis so is easier to repair in a workshop.
The Mk2 on the other hand is an integral vehicle and relies its bodyshell for strength, which means that if major structural steel repair / replacemernt is needed then the bodyshell needs support to achieve it. From a WCR point of view the Mk2abc are the most useful vehicles because the windows provide ventilation and they retain the axle driven alternator to keep the batteries charged.
Adding CDL as prescribed by the ORR is obviously not a difficult issue because every one of WCRs; competitors manage it, although perhaps it needs saying that Vintage Trains are the only one who run vacuum braked trians on the mainline with CDL. In a similar vein, all of Vintage Trains' fleet of steam locos are only vacuum braked, so WCR could adopt the model if it wanted to, particularly as the VT active fleet of coaches is probably only eleven or twelve coaches - the equivalent of two Jacobite rakes.
Except the Jacobite services where each hired in black five and WCR rake runs once a day, seven days a week. Four trains per day in peak season. The WCR fleet of black fives 44767 44932 and 45110 could operate the Jacobite unmodifed if WCR were to adopt the "Tyseley" CDL mod, but I am assuming WCR chief prefers to hire Ian Riley's dual braked black fives in.
Chris125
12 Nov 2009
Isle of Wight
WCRC almost certainly have far greater financial means than VT (last year alone they purchased both Riviera Trains and Kolhapur), they don't have to do their whole fleet at once and there may well be economies of scale too.
renegademaster
22 Jun 2023
Croydon
LSL tours are also considerably more expensive. Would they still be able to sell standard class tickets for £115(while the other main steam operator would charge £150 for a comparable tour) if they decided to pay for CDL on ancient vac braked rolling stock rather than use the stock they already own which was pre-fited.
Krokodil
23 Jan 2023
Wales
I doubt it (though Yorkshire farmers are notoriously tight-fisted). The cost would easily be covered by what he's losing in revenue because of an inability to run trains. Smithy thinks that he can run his train set like it's still 1968 and doesn't want things like air brakes or CDL gubbins dispelling that illusion.
Wyrleybart
29 Mar 2020
South Staffordshire
You are going with the agenda I fear !!! WCRs Mk2 aircons were introduced around 1971-1972 but the last Mk1 TSOs on the 50xx series were very early 1960s IIRC so there is around a decade of age between them.
There is a not a long wrong with vac braked Mk1s provided they are cared for and WCR's Mk2Fs are over 50 years old, so maybe corroded and needing more specialist "chop out and weld" care. I am guessing that if WCR's proprietor were willing, he could probably have less than 20 vac or dual braked Mk1s fitted with vaccy CDL as Vintage Trains are fitting, and runing WCR's own steam locos with them.
Additionally,. AIUI the Jacobite could also be operated by the vacuum only LNER K1, which seems to be a desire.
renegademaster
22 Jun 2023
Croydon
That makes no sense.
His train set didn't run maroon mark 2s paired with a pre war steam engine .
He's just tight, on RTC tour tight the staff were moaning about ORR and arguing that they should pay for it like NR did with toilet tanking a few years back
Krokodil
23 Jan 2023
Wales
Does it need to make sense? If he was applying logic he'd have got on and fitted it when the ORR told him too. Some of it is just plain stubbornness, he resents having to cooperate with the modern world and its safety regimes.
james_the_xv
29 Oct 2019
West Midlands
Hardly an unusual sentiment in the preservation world.
But a completely unforced error when running mainline charters. You can argue until the cows come home about whether increased safety regimes are 'right', but that doesn't change the fact compliance is necessary to avoid losing market share and business.
renegademaster
22 Jun 2023
Croydon
He's complied , but just not in the way that keeps the mark 1s, which makes the whole tosh about how he ideologically opposes health and safety false. He just opposes spending money where he doesn't have to.
Chris125
12 Nov 2009
Isle of Wight
...but 'wasting' money is a major reason why some people, especially in business, have an ideological opposition to modern H&S.
It must be noted that CDL isn't the only confrontation between WCRC and the ORR in recent years, the following was 2016.
BBC: West Coast Railway steam train firm banned from operating
Last March safety equipment was allegedly bypassed on the Tangmere locomotive, which caused it to pass a signal at danger. A high-speed train had passed over the junction less than a minute before. The ORR said a number of incidents leading to safety concerns had occurred since the incident, despite the company being warned to improve safety.
It has issued a prohibition notice, which prevents WCRC - based in Carnforth, Lancashire - from operating trains. Ian Prosser, HM Chief Inspector of Railways at ORR, said the decision to revoke the company's safety certificate, external had "not been taken lightly".
"However, my concerns about West Coast Railway Company's lack of appreciation of the seriousness of a collective range of incidents over the last year, coupled with ORR's concerns on the company's governance, regrettably make this prohibition necessary.
Scotty Dog
7 Apr 2021
Both 5239 and newly converted Mk2e 3232, now fitted with Mk 2 opening windows, will be making an appearance in the North East this coming weekend on the charters involved with the S&DR 200th anniversary celebrations.
Also now fitted with CDL is 5419.
The conversion of 3232 seems a very ingenious way to overcome the Air Con issues when using later Mk2 fitted CDL coaches.
Is there a picture? The windows on Mk2e coaches are shallower than on the earlier Mk2s with opening windows.
sprinterguy
4 Mar 2010
Macclesfield
See the seventh vehicle in the train in this Youtube video shared in another forum post:
Scotty Dog
7 Apr 2021
I understand it's full depth Mk2 windows.
I would imagine they are the right width whereas Mk1 windows would be too narrow to retrofit?
Apparently out this weekend on first working since conversion so hopefully photos soon.
It didn't look like there were any new conversions in the videos I saw of the Lune Rivers and RTC trips today. It looked like 5239 was in the formation of the former with two of the ex-Riviera standard class coaches with opening windows, and the other ex-Riviera opening window coach was in the formation of the RTC trip.
37069
11 Jun 2025
Cumbria
3232 should be on the Boulby trips tomorrow.
Windows as seen in this video of the ECS move today -
