Turning a DVT into a locomotive - can it be done?
Could it be converted to a steam locomotive?
Again, since the question was 'could it' with no bounds, the answer has to be 'Yes'.
(And according to quantum theory there exists a universe where it already has been done).
trac
9 Feb 2015
A steam punk universe :)
sprinterguy
4 Mar 2010
Macclesfield
82xxx did exist many moons ago, which could maybe cause issues. I think maybe 93 is the next one that hasn't yet existed?
There hasn't been a mainline registered class 82 for many more years than the minimum required before a new class can be registered under that number: So the higher ranges of class 82 could be used if ever needed, though in this (unlikely) scenario, as a diesel loco the former DVT would presumably be renumbered in a diesel loco range appropriate to it's rated engine horsepower (not that TOPS allocations are often logical).
sprinterguy
4 Mar 2010
Macclesfield
158s have 25+ years service history behind them. The 230 is a new project that needs credibility to succeed. Catching fire within days of starting mainline testing does nothing for that.
True, and if there are other underlying problems (I haven't seen the report) then fair enough, but the one incident often alluded to considered in isolation isn't enough to write the whole project off. I appreciate that this has been discussed ad nauseam on the appropriate thread, though.
TheEdge
29 Nov 2012
Norwich
Does that mean there is also a universe where every suggestion for 442s and 373s has been done? :lol:
daikilo
2 Feb 2010
Possibly, but not neccesarily.
A thought that crossed my mind is the Nk1s BxKs modified to include a generator unit to provide electricity for say steam hauled private owner stock. Some probably said 'no, too complex, not designed for that, cash flow...' and others just did it.
I believe DVTs are designed for buffing loads so probably have more structure than say a Mk3 or 4 coach, but is it in the right place and can it cope with say a power pack (or several)? Also, bogies would need to be modified/chqnged.
BestWestern
6 Feb 2011
From a brochure produced by Porterbrook in 2012 regarding their mark 3 fleet. Sadly, the original link to the document seems to be inactive, and the PDF is too large to upload to the forum.
Fascinating! Was conversion of DVTs into seated accommodation ever a viable option? I thought it was always a no-no.
sprinterguy
4 Mar 2010
Macclesfield
Porterbrook seem to have thought so, although the brochure doesn't go into any more detail than in the image posted by KNotts. It's possible that replacing the existing DVTs with a new build DBSO or DTSO might have proved the more straightforward (if more costly) option.
fowler9
29 Oct 2013
I think you could just about fit a GE 90 Jet Engine in a Mk 3 DVT. That would provide some impressive performance, probably kill anyone nearby sadly.
dgl
5 Oct 2014
It's easy to turn a DVT into a locomotive (well at least part of one) it just requires a trip to Booths first :)
Apparently, the rules changed: when the Mk3/Mk4 DVTs were created the rules said no passengers in the leading vehicle of any train that was capable of >100(110?)mph. That has obviously changed.
BestWestern
6 Feb 2011
Yeah I vaguely recalled it being that. But did that change as a result of more crashworthy rolling stock? I would imagine the same rule would still apply to older designs?
I think it was actually the Mk3/Mk4 designs that were the reason for the rules change. They were so much more sturdy than what had existed before.
BestWestern
6 Feb 2011
I wonder if that would include a DVT?
CosherB
23 Feb 2007
Northwich
As there appears to have been zero interest in converting the Mk3 DVTs into "DTSOs", the point seems to be moot.
SpacePhoenix
18 Mar 2014
I wouldn't want to be a driver driving a train from one, given how badly they fair in a crash. I saw a picture of one after what I think was the Hatfield crash iirc and it was a case of "so where is the DVT?" it was just the chassis left
t_star2001uk
23 Aug 2011
DVT from Hatfield survived. The one at Great Heck was substantially damaged.
cf111
13 Nov 2012
Are you maybe thinking of Great Heck/Selby? The DVT was at the rear of the train at Hatfield and was not badly damaged.
The closing speed at Great Heck/Selby was something like 145 miles an hour, I don't think any rolling stock would fare well at that speed.
D365
29 Jun 2012
Do you seriously think that this is a serious suggestion?
D6975
26 Nov 2009
Bristol
If anyone locates the universe where FGW runs pairs of 37s on all their long distance services, please give me a shout. :) :)
randyrippley
21 Feb 2016
With all these train regeneration projects that have taken place such as the Evolution prototypes of EMU/DMUs, as well as Viva Rail and the Class 73s, would it theoretically be possible to turn a DVT into either an electric or diesel locomotive?
Not a proposal or a nostalgia fantasy thread for trainspotters
When the WCML MkIII DVTs were introduced there were some press reports which stated they had been specifically designed with that possibility in mind and that the floor was strengthened to take the weight of a diesel and generator etc. The intention seemed to be to give a way for the WCML sets to have a "last few miles under diesel" option. There were several claims that the DVTs were HST power cars minus the power.
I can't tell how true the claims were, but they were certainly made at the time
CosherB
23 Feb 2007
Northwich
So would you be happy in a Class 90?
dk1
2 Oct 2009
East Anglia
Against advice National Express had planned to convert the Anglia DVT fleet into kitchen cars back in 2004 after it admitted they would never get passed the safety case to carry passengers in this vehicle. First class was to then to be swapped to the Norwich end but this plan was also abandoned due to the fact that there had to be access for drivers/Senior Conductors to pass through this area & passing through a food preparation area would not be permitted. Any plan to provide alternative access made the cost prohibitive considering how much kitchen space would be lost in what was already going to be a tight fit.
