TfW Class 67+Mk4 sets: trip planning/experiences, diagram updates etc
Topological
20 Feb 2023
Swansea
I may have missed it, but what is the logic of 1V62 being a Mk4 now? I am not complaining as that is one of my options when heading south, but I had resigned myself to a 2-car 197 on cover being the 18:30 option.
sd0733
7 Nov 2012
The diagrams have swapped back as of tomorrow (normally the set off the 06:27 from Manchester), 1W61/1V62 are back on a Mk4 diagram. Not too sure the reasoning behind it!
37052 xb mr
6 Dec 2023
Stockport
Cancelled today, should now run tomorrow with 67016 now hauling 67014 and 67013.
Couple more diagram swaps tomorrow, plan should be:
67017+HD01- 1V31 1W55 1V42 1W63
67010+HD03- 1V33 1W57 1V46 1W65
67008+HD04- Crewe ATC-Crewe ETD for tyre turning then back to.ATC in the evening
67012+HD06- 1V91 1W61 1V62
67015+HD07 1W13 1V37 1W96
Cheers
37052 xb mr
6 Dec 2023
Stockport
1V31 cancelled at Shrewsbury, 66 late, 67017 set 1.
1Z99 - 67025 to drag it back to Crewe
Jacob Porrett
28 Jan 2022
Telford
Today at Crewe depot (8/7/25):
HD05 - no loco
HD04 connected to 67008 has gone for tyre turning
HD01 connected to 67017 and 67025 after it failed this morning.
Swaps:
67025 now connected to HD01
67020 now connected to HD05
67017 light engine
sd0733
7 Nov 2012
Tomorrow should see a return to 5 diagrams, earlier than originally planned.
Only 1 set at Canton so expected for HD04 to enter service at 09:10 from Crewe.
HD03 then stops tomorrow, hopefully HD05 will be ready to step in on Thursday to replace it.
67012 is planned to swap off in the down time at Canton with 67029 replacing it.
aar0
13 Sep 2016
Great! I was debating between the 0853 and 1053 from Cardiff, and was gambling on the 1053 as the 0853 didn’t run as a MkIV today. Then 10/12/1440 back from Stockport on Friday - again depends which will have a MkIV!
Topological
20 Feb 2023
Swansea
Great news.
Though the 18:30 from Manchester today had door issues at Hereford. Assuming that is the only set at Canton then let's hope that the door issue was not too serious.
A Mk4 on the 18:30 is useful to Northwich but then it is something of a luxury after that as the train really empties.
37052 xb mr
6 Dec 2023
Stockport
1V31 off Crewe is 197124
Not 67025 Set HD07.
1V33 is 67010 Set HD03
Cardiff diagram finish, so will need to
Change.
sd0733
7 Nov 2012
Not 67025 Set HD07.
Change.
Not the best start!
HD01 had a static convertor fault.
HD03 and HD07 are planned to swap diagrams, 03 will go back from Cardiff on 1W57, 07 on 1W61.
Doubts about 04 being ready too, if it doesn't go on v37 hoped to go on w59/v50 instead.
37052 xb mr
6 Dec 2023
Stockport
Not the best start!
Ok thanks
37052 xb mr
6 Dec 2023
Stockport
1V37 gaining a 2nd unit at Shrewsbury
To make a 5 car set.
67008 set 4 is back at Crewe
From wheel lathe.
Jacob Porrett
28 Jan 2022
Telford
Today at Crewe depot: (9/7/25):
67017 left 0T23 guessing the ETD?
67008 on HD04
67025 on HD01
67020 on HD05
Loco Central today haha.
sd0733
7 Nov 2012
67008 on HD04
67025 on HD01
67020 on HD05
Correct, 017 going to ETD.
67025 also coming off HD01 later to go to the ETD, 67016 planned to go onto HD01.
HD04 will work 1V42 and then swap to 1W96 today.
4 diagrams tomorrow as HD03 stops and HD05 isn't ready. 67012 will have an exam as its finished early so the swap with 67029 wont happen, the diagram starting Canton on 1W11 will be subbed with a 197.
37052 xb mr
6 Dec 2023
Stockport
Cheers
Jacob Porrett
28 Jan 2022
Telford
Can confirm 67016 has gone onto HD01.
