TfW Class 67+Mk4 sets: trip planning/experiences, diagram updates etc
sd0733
7 Nov 2012
HD04 will work 1W65 vice 1W96, HD06 should be ready for tomorrows V91. HD04 requires stat con and air conditioning repairs so will stand down at Crewe.
That means only 3 diagrams again with HD01 starting 1V33, HD03 starts 1W13 and HD06 on 1V91. HD07 should also head to the ETD for tyre turning.
The loco swap of 67017 and 014 looks likely to slip back again to tomorrow now.
37052 xb mr
6 Dec 2023
Stockport
0Z84, 07.38 Crewe CS - Canton CS
Is that a 67 please ?
Thanks
Looks like 0Z84, Canton - Crewe 17.30 left Canton last night but was turned back at Cardiff Central
MP393
28 Jun 2021
North West
Thanks
67017 on the Crewe - Canton
67014 was on last nights Canton - Crewe, shut down twice in that short space of time and the safest bet was to return it to Canton
sd0733
7 Nov 2012
Any news please on 1W59
67013 set 1
And any knock on effect for tomorrow
Thanks
Traction motor fault on 67013. It was planned on the Canton start tomorrow. Theres a few locos at Canton so Potentially if required could see a loco swap. 67017 (there now to recover 014 and return it to Crewe for repair), 67029 (standby) are there.
67013 was due to come off the set tomorrow night any way and be replaced by 67016.
Other diagrams should see HD04 starting on 1V33, HD06 on 1V37 and HD07 swapping in at some point after it returns from tyre turning, time depends on crew availability tonight and in the morning to get it back from ETD.
Sunday should then see HD04 from Crewe and HD07 from Canton.
37052 xb mr
6 Dec 2023
Stockport
Ok, thank you
sd0733
7 Nov 2012
A change for tomorrow:
67017 now planned to replace 67013 on HD01.
HD04 has now dropped out too so very little looks to be out
67017+HD01 on a Canton start for 1W13, this will also now be the Canton set for Sunday.
67012+HD06 will work the diagram starting 1V33, this will be the Crewe set on Sunday.
67015+HD07 will work 1V50 from Crewe (potentially may take over on 1W59 if ready)
37052 xb mr
6 Dec 2023
Stockport
Cheers
Jez
22 Jan 2011
Neath
Does anyone know what the plan is for Monday/Tuesday? Are we expected to have the 4 full diagrams?
37052 xb mr
6 Dec 2023
Stockport
As long as no issues today
67017 Set 1 Cardiff
67010 Set 3 Holyhead
67012 Set 6 Crewe
67015 Set 7 Crewe
Should all be available.
Others,
67008 Set 4 Crewe - Repair
67016 Set 5 Crewe - B exam
sd0733
7 Nov 2012
67017 Set 1 Cardiff
67012 Set 6 Crewe
67015 Set 7 Crewe
Others,
67008+HD04 planned to run across to ETD tomorrow morning for tyre turning (looks to be the reason HD07 never went to Cardiff yesterday, to balance for tomorrow)
67025 is now on HD05. 67016 is planned to run to Canton tomorrow to collect 67014 and return it to Crewe ETD.
HD03 will have to stop by end of service Wednesday for exam but HD04 should be back by then to take its place, nothing then is due exam for a couple of weeks.
37052 xb mr
6 Dec 2023
Stockport
Thanks
37052 xb mr
6 Dec 2023
Stockport
Is 67014 coming back on its own now please ?
No path in for anything going
From Crewe to Cardiff
Thanks
BillStampy
6 Jan 2024
Llanharan
Thanks
67016 is already on the way down as 0Z16
37052 xb mr
6 Dec 2023
Stockport
FrontSideBus
11 Feb 2025
After having a go of various sets today, the ex Grand Central coaches are much better than the VTEC ones IMO, which are starting to look a little tired.
sd0733
7 Nov 2012
Thanks
Cancelled today, should now run tomorrow with 67016 now hauling 67014 and 67013.
Couple more diagram swaps tomorrow, plan should be:
67017+HD01- 1V31 1W55 1V42 1W63
67010+HD03- 1V33 1W57 1V46 1W65
67008+HD04- Crewe ATC-Crewe ETD for tyre turning then back to.ATC in the evening
67012+HD06- 1V91 1W61 1V62
67015+HD07 1W13 1V37 1W96
