TfW Class 67+Mk4 sets: trip planning/experiences, diagram updates etc
BillStampy
6 Jan 2024
Llanharan
I don't want to jinx things (!) But exams are now much better balanced and if a set does have to wait a day or 2 it's now held at Crewe ETD rather than Holyhead which saves ages. Also using the wheel lathe there rather than Canton saves an age too, as it doesn't have to travel from the exam and also the Crewe lathe will take the rake as it comes but the Canton one requires it splitting and putting back together.
That's reassuring, I'll ask closer to the date about set availablity as I really don't fancy a long while on a 197 to Crewe. Good to know that Holyhead isn't used and whatnot, keeping it closer to base (by a long shot) is always ideal.
jonb
8 Jun 2005
Essex
Taking a trip out tomorrow to sample this, just a couple of advance queries if anyone can confirm please and thanks in advance!
- Likely allocations for 1W55 (08:49 ex Cardiff) and 1V37 (08:30 ex Manchester)
- Is breakfast service available on 1W55?
31 May 2018
Manchester
Can't disagree with you there!
But it raises an interesting debate about reliability of different forms of transport
Are you seriously trying to compare the maintenance of trains compared to aircraft?
They're two completely different forms of transport, the latter having much much more stringent and stricter maintenance procedures.
sd0733
7 Nov 2012
1V37 is planned for 67025+HD06
1W55 is planned for 67015+HD01
1W55 is planned to have a full catering/first class service available from Newport to Manchester.
jonb
8 Jun 2005
Essex
Thank you very much, greatly appreciated!
sd0733
7 Nov 2012
06 should also work 14:49 Cardiff to Manchester and return vice 197 tomorrow.
That plans been put on the back burner to cover the PM bit of diagram 5 until the diagram comes in properly due to it not being a Mk4 diagram so crews often cover who don't sign it. The only time it's likely to run until then is if sets need moving between Crewe and Canton like happened on Tuesday.
37052 xb mr
6 Dec 2023
Stockport
1W11 Turned at Wilmslow
1V37 started at Wilmslow
Due to late running
1W11 Spent 40 odd minutes at Newport.
67020 Set HD04
Seems to have died at Canton
RTT saying Brakes !
1W57 starting at Crewe with a Unit.
67029 back at Crewe from Toton.
sd0733
7 Nov 2012
Due to late running
67020 Set HD04
RTT saying Brakes !
1w11 was delayed by a freight slipping to stand in the Cwmbran area needing rescuing
67020/HD04 unable to get brake release on Canton, hoped to get spare set 67008/HD05 to work 18:55 Cardiff to Manchester to balance things for tomorrow, 04 was planned to be the Crewe spare tomorrow.
67013 has also been released from exam at Crewe so hopefully those 2 should head back to TfW soon giving good loco coverage and allow 67007 to go back to DB.
37052 xb mr
6 Dec 2023
Stockport
Thanks,
Yes 67008 Set 5 now allocated
To 1W65 & 1J76
BillStampy
6 Jan 2024
Llanharan
What's the 2nd loco of the two, 013 and..? Still good to have some loco coverage again though.
sd0733
7 Nov 2012
Oh! That's brilliant! So it's back in the pool I'm assuming? If it is then get that thing on a set :lol:
Not just yet but shouldn't be too far away. With it being out for so long it's likely to have a test run before officially going back out.
37052 xb mr
6 Dec 2023
Stockport
67015 set 1
Caught in an issue on 1V33
57 minutes late at Longsight, 42 late at Stockport, wires down had to go back to Manchester then via Style,
Left Crewe 79 late.
BillStampy
6 Jan 2024
Llanharan
Supposing diagrams will remain normal tomorrow due to VOG diversions, unit to Cardiff and then a set off to Piccadilly and vice versa.
HD02 is headed to Holyhead this weekend and HD03 is swapping in to Crewe
sd0733
7 Nov 2012
Look to be the same other than the Swanseas start/finish at Cardiff, HD01 and 04 should be the Cardiff starts and HD03 and 05 on the Crewe starts, 05 is on it's last day before stopping for heavy exam from Sunday.
The swap was planned so that the loco on HD03 can have an exam overnight at Canton on Sunday.
BillStampy
6 Jan 2024
Llanharan
So HD05 will be out of action, HD07 too if I'm not mistaken? That leaves 5 sets, so one spare? How long do these heavy exams normally take on average out of my curiosity
sd0733
7 Nov 2012
Yes both of those will be on heavy exams. There's nothing else coming up for exam until next Sunday so 4 of HD01/02/03/04/06 will be in service each day with a spare set kept on Canton each day (Crewe will be full with 2 in service and 2 exam sets).
The B exam takes around 2 weeks so HD07 will likely be released around a week on Monday, possibly a little quicker or slower depending on workload from repairs on other sets.
37052 xb mr
6 Dec 2023
Stockport
67029 has had a LD test run Friday afternoon 0Z67
Crewe TMD E - Stafford - Crewe TMD E
sd0733
7 Nov 2012
Its Planned to be back on hire to TfW today to act as North standby for now. Will head across to ATC today or tomorrow.
67008+HD05 are heading in the opposite direction going from ATC to Crewe ETD for storage tomorrow whilst HD07s exam is completed. Likely to be there a week or so. This will free up space or Crewe would be at capacity every night and no spare could be kept.
Once this round of B exams are complete (HD07 to complete then HD05/06/02 to have theirs) then the intention is to move onto reactivating HD08 with that work expected to take approximately 12 months so is likely to be late 2025/early 2026 when that appears. Just in time to act as cover for the other 7 sets going through heavy overhauls during 2026 (if everything stays to schedule!) It is thought to be repairable at this point.
37052 xb mr
6 Dec 2023
Stockport
67013 went back to Toton on 0D54
With 67005 on Thursday
After 67005 had brought 67029
To Crewe on 0K54
Jacob Porrett
28 Jan 2022
Telford
When will we start to see the red sets going black?
