TfW Class 67+Mk4 sets: trip planning/experiences, diagram updates etc
37052 xb mr
6 Dec 2023
Stockport
Anyone know what’s up with
67017 & set 2 please
Not worked since arriving at
Cardiff on yesterday 1V91
Thanks
sd0733
7 Nov 2012
Thanks
A minor brake gauge fault so HD03 replaced it yesterday.
67017 is due an exam, it's now in the wrong place so will head light engine to Crewe ETD today, 67029 is planned to go to Canton tomorrow to replace it.
AntoniC
28 Dec 2011
Southport
I was lucky last Friday (11th Oct 2024) and yesterday (14th October 2024) to travel First Class between Manchester Piccadilly and Cardiff Central and return.
I caught the 12.30 from Manchester to Cardiff on the 11th and the 10.52 from Cardiff to Manchester yesterday.
The first class return fare was £70.00 (an absolute bargain).
On the outward leg I had the 3 course meal for £25.00 - I had fishcake for starter, steak for mains and cheesecake for desert - all were gorgeous.
On the return leg I had the snack menu and had sausage roll with a Welsh cheeseburger , again delightful.
The service from the First Class Host was attentive but not intrusive.
Both trains ran to time.
JakeMurphy
30 Aug 2018
I take it 029 is going to go on HD02 then?
sd0733
7 Nov 2012
Great to hear it, when do we expect it back in service ?
Shouldn't be long once it's at Canton, usually the spare sets there are rotated rather than have one there for long. 2 sets run out of Canton on a Saturday so even if it doesn't show on Thursday or Friday it's likely to be out on Saturday.
Jacob Porrett
28 Jan 2022
Telford
Today at Crewe depot (15/10/24):
Same as yesterday pretty much,
67029 light engine
67014 connected to HD07.
sd0733
7 Nov 2012
67029 light engine
All leaving today.
67029 is now at Canton to go on HD02
67014+HD07 heading to Crewe ETD tomorrow for tyre turning after its exam but will be replaced by 67008+HD05 heading the opposite way tomorrow morning for it's exam.
BillStampy
6 Jan 2024
Llanharan
Absolute chaos is unfolding as of right now as both routes between Crewe and Shrewsbury are blocked, 67020 + HD04 has terminated at Shrewsbury on 1W19, now running on 1V44 Tenby service, probably as far as Cardiff. HD01 is sitting around at Chester following the diversion route it was following flooded too. HD06 is doing some swapping to end up on 1V62, unsure if it'll get to Canton based on if the flooding clears. HD03 is still planned for the Holyhead but again, unsure how it'll turn out.
EDIT: HD01 now taking a stroll to Holyhead on 1Z93
Jacob Porrett
28 Jan 2022
Telford
All leaving today.
I've got to empty the kitchen out on Friday on HD05.
Thank you for the update/information.
BillStampy
6 Jan 2024
Llanharan
Can someone give me a general idea of how tomorrows diagrams will work following this chaos today?
37052 xb mr
6 Dec 2023
Stockport
By my Reckoning,
67015 set 1 Holyhead
67029 set 2 Cardiff
67012 set 3 Cardiff
67020 set 4 Cardiff
67008 set 5 Exam Crewe
67025 set 6 Brakes Crewe
67015 set 7 Lathe Crewe
BillStampy
6 Jan 2024
Llanharan
By my Reckoning,
67029 set 2 Cardiff
67012 set 3 Cardiff
67020 set 4 Cardiff
Thanks, unsure if 029 will jump straight back in since it hasn't worked with a set for a while, but that's on my judgement. 1V33 and 1V31 will probably be units and then a set will jump in from there, thanks!
sd0733
7 Nov 2012
By my Reckoning,
67029 set 2 Cardiff
67012 set 3 Cardiff
67020 set 4 Cardiff
Yes those all look to be correct
sd0733
7 Nov 2012
That's presuming all the lines reopen overnight, that's not a certainty yet.
Edit- Many lines shut until at least 0900 so likely a write off diagram wise.
HD05 should still head from Crewe ETD to ATC for exam later following storage but little else currently looks to be out.
BillStampy
6 Jan 2024
Llanharan
Yikes, that's not good. Can't really blame anyone though, natural causes. Hopefully we get HD07 back in at some point in the next few days too, what's the next set planned out for exam and when? (excluding HD05)
sd0733
7 Nov 2012
HD07 should be back off tyre turning by Monday at the latest, it's been much quicker on the actual exam which is a positive sign.
Next should be HD01 on a light exam at the weekend then HD06 the next heavy one which is due after the following weekend so if all goes to plan 05 should be back by then.
Jez
22 Jan 2011
Neath
TFW have put an update on X/Twitter that no First Class services will run today.
Jez
22 Jan 2011
Neath
RTT is showing the 0849 has departed Cardiff however I assume this is a unit. It doesnt indicate the service will be cancelled at Hereford so has the line reopened?
