TfW Class 67+Mk4 sets: trip planning/experiences, diagram updates etc
aar0
13 Sep 2016
They also do breakfast on certain services, something I am keen to try once the service is more reliable from Cardiff.
I’m semi regularly on 1W55 and have only been let down once in the last year for breakfast. (Due to a lack of Mk4).
Jez
22 Jan 2011
Neath
Thats good to know. That would most likely be the one id catch up to Manchester or the Swansea starter now its a MK4.
37052 xb mr
6 Dec 2023
Stockport
I am guessing Monday will only
Be 4 sets at best ?
With set 1 at Holyhead
& Set 4 & 6 still OOS at Crewe.
Cheers
37052 xb mr
6 Dec 2023
Stockport
67020 set 3
1V70 9.30 Manchester - Swansea
Still sat at Crewe, arrived early
Now 40 minutes late
Waiting train crew
sd0733
7 Nov 2012
Be 4 sets at best ?
Cheers
Should be 5 now with HD04 and HD06 expected to come available through the day, this will also enable HD01 to head back to Crewe with 67017 tomorrow now a bit earlier than I expected.
All 7 are planned to do something:
67017+HD01 ecs Holyhead to Crewe
67015+HD02 diagram starting 1W13
67020+HD03 diagram starting 1V31 then stops for tyre turning.
67010+HD04 diagram starting 1W11 or 1V37 at Crewe
67016+HD05 Diagram starting 1V91
67013+HD06 Ecs Crewe ETD to Crewe ATC
67014+HD07 Diagram starting 1V33
37052 xb mr
6 Dec 2023
Stockport
Thank you
sd0733
7 Nov 2012
67014, unsurprisingly for that one at the moment had issues so swapped out. Seems V31 was cancelled as a result and HD03 put on V33 instead, as that's booked onto the ETD lathe tomorrow a swap at Cardiff, with it picking up the 10:52 Manchester Seems likely.
Welshguy1048
6 Apr 2023
North Wales
Morning @sd0733
Is 67017 still due to go ecs to Crewe today?
Dave
sd0733
7 Nov 2012
Morning @sd0733
Dave
It was, but now sets haven't left this morning it seems unlikely for now. if it moves there it will potentially overload Crewes normal 4 set limit so until something else leaves/gets swapped out it's basically going to be full there.
Welshguy1048
6 Apr 2023
North Wales
@sd0733
Okay
Thank you
Dave
1V91 (Holyhead-Cardiff) has diverted between Chester and Shrewsbury via Crewe, because of the landslip near Gobowen.
So the set will be in reverse formation without the usual Chester reversal.
Currently 38 late leaving Shrewsbury.
37052 xb mr
6 Dec 2023
Stockport
MP393
28 Jun 2021
North West
@sd0733
Is this the ECS move of 67017?
I know you said it wouldn't run today...
Dave
It’s showing internally as 67016+HD01,
Looks like 016 & 017 possibly swapped sets in Holyhead as 017 is showing as working 1V91 with HD05.
Topological
20 Feb 2023
Swansea
1W11 & 1V37 197122
No 67010 set 4
So out of 3 working days in 2025 0 days have featured Mk4 for the complete 5 diagrams. I do hope this pattern will change soon.
Maybe the move to 5 diagrams was a little ambitious for 7 sets.
sd0733
7 Nov 2012
@sd0733
Dave
Apologies, been yet another change with 67014+HD07 moving over to the ETD which frees up space for HD01 to arrive.
All a bit messy and confusing Current state of play unless it changes again seems to be:
HD01 is now on its way to Crewe ecs, HD02 is in service
HD03 has swapped to a Crewe finish, will swap locos overnight to 67029 and head to Crewe ETD, due a heavy exam in a few days so I'd be suprised to see it back before it's exam.
HD04 didn't enter service as expected and is now expected tomorrow on v33
HD05 swapped diagrams and now finishes Canton.
HD06 made its way to Crewe ATC
HD07 has gone to Crewe ETD.
Tomorrow has 4 diagrams with HD01,03,07.all out now out of service. HD02 should start out of Holyhead, HD04 off Crewe on 1V33, HD05 from Canton on 1W13 and HD06 out of Crewe on V31. Plenty of time for that to all change and be proven wrong!
sd0733
7 Nov 2012
They did swap in Holyhead over the weekend but seems somewhere that got missed when the allocations were put up.
Welshguy1048
6 Apr 2023
North Wales
@sd0733
Thank you for the update
Dave
sd0733
7 Nov 2012
Being realistic, it's not going to have 5 diagrams for at least a few days, if not a couple of weeks now.
Jez
22 Jan 2011
Neath
If we are looking at working days and not including Bank Holidays or Weekends (when there are generally less diagrams anyway) then at the moment we are up to 78.5% availability (Thurs 3 out of 4 diagrams covered, Friday and today both had 4 out of 5, so of a total of 14 diagrams across the 3 days 11 were covered.
Personally I am happy to see the 5 diagrams, even if they cant always achieve that the intention is there and they cant continue to sub the early Swansea service for a unit forever.
Jez
22 Jan 2011
Neath
Hopefully if they do have to sub one diagram for a unit it will be a different one most days rather than it always being the Swansea starter that was always subbed until recently.
Topological
20 Feb 2023
Swansea
It is good to have 1W13 as a Mk4. However, I long gave up on that train as I can leave home at the same time and be in Manchester an hour earlier driving to Pontypool. The economics of it may change, but the M4 is nice and quiet and no worries about Cardiff connections/platform waits.
11/14 diagrams covered is still poor, though I do understand that the 197 figures are arguably worse (a bit harsh counting the number of 5-car run as 5-car when some 197s are covering other units elsewhere).
