Reading, Basingstoke and onwards to Exeter should be 25kv overhead wired, and linked into an extension of any GW scheme, to extend from Bristol to Exeter,
On Southern routes, BEMU fleets should become the norm, and should be able to operate not just as battery powered but also as convectional EMU, off 3rd rail, where some route has to operate over non electrified sections of line, the 171 fleet can then be cascaded to where more modern DMU's are needed,
Possible operation of the Marsh line, could be an extension of Charing cross to Hastings, but extended to Ashford, and London via Tonbridge, either by combining services, or a redrawing up of services between Ashford and London, to include services that would normally terminate at Ashford, extended operation on 3rd rail should enable the battery packs to recharge, Similar duel traction could be used on Reading to Gatwick possibly using tri mode EMU's to make them a common route type emu,
