Scottish Electrification updates & discussion
QueensCurve
22 Dec 2014
I have discovered that the delay in energising QS to Newbridge is because they realised that in addition to the ensuring that all the bridges etc met the new regulations, there were a large number of other bits of steel adjacent to the railway, every one of which has to be assessed for compliance! My informant confirmed the 23rd June.
That sadly underlines the current lack of pragmatism in the regulators. If the steelwork had been in compliance with the old regulations it could safely have been energised all be it that might have required the preparation of a brief risk assessment.
InOban
12 Mar 2017
I don't know what individual or committee failed ask for a similar derogation from the new EU standards as had been asked for and given from the old ones. This failure has cost the country a fortune, and made future electrification schemes unaffordable until the relaxations can be reinstated.
QueensCurve
22 Dec 2014
The problem is not "the new EU standards" but the fact that the clearances were cut and pasted into the new British Group Standard without taking account of the recognition in the European documents that the British railway is built to narrower clearances and therefore may differ.
Either way the problem is with the UK adoption of the standard not with the standard itself.
What nobody has answered as far as I can tell, is the question of why, if a mistake was made in the UK, the UK can't reverse it.
GaryMcEwan
20 Aug 2013
Bridgeton, Glasgow
I'm probably taking this down the wrong path, but when I was down in London, SWT routes are powered by 3rd rail rather than overhead lines.
Instead of overhead lines, could Scotrail have went down the 3rd rail option?
There have been discussions on here about whether new third rail routes should effectively be banned as is current ORR policy because of the level of risk. However I don't think anybody even there has argued that third rail is safer than OLE.
snowball
4 Mar 2013
Press release
https://www.networkrail.co.uk/feeds...ollowing-completion-of-bridge-reconstruction/
The A71 has now fully re-opened following 16 week programme of work to demolish and replace the road bridge next to the station in West Calder.
The bridge reconstruction was delivered in an intensive period of work from January to hit the 16 week programme and is part of wider activities on the Shotts line ahead of the electrification of the route by 2019
As well as work to demolish and reconstruct the bridge cleared for the electrification of the railway underneath, the work programme also involved extensive mining remediation work under the bridge abutments to ensure the ongoing integrity of the rebuilt structure.
Altnabreac
20 Apr 2013
Salt & Vinegar
GRALISTAIR
11 Apr 2012
Preston Lancs
NR have notified the ScoGov that there will be a further delay in going live. Apparently there's a safey-critical component which is faulty and will have to be replaced along the entire length.
http://www.scotsman.com/news/transp...-rail-electrification-delayed-again-1-4449540
I know stuff happens and it is wise to replace safety critical components - but how many more nails can be driven into the electrification coffin? GWML huge cost and time overrun, GOBLIN huge delays, EGIP delays, etc etc. I am a total electrification fan but seeing it from the other side -it really is not good.
The content of Mark Carne's letter quoted by Yousaf Humza at Holyrood today:
"Regrettably, it is now clear that a safety critical component is susceptible to failure and must be replaced. This will impact the energisation start date.
We are working extremely closely and collaboratively within the Scotrail Alliance to assess how the impact of this challenge can be minimised for passengers and we will keep your officials informed.”
No clue of the extent or cost of the delay.
Not clear if it is accounted for in the last energisation date we heard of (23 June).
It's buried in this: http://www.parliament.scot/parliamentarybusiness/report.aspx?r=10952&i=100153&c=2000466&s=
NotATrainspott
2 Feb 2013
At this rate is there going to be much point using the 380s at all? The first 385s arrive in September.
InOban
12 Mar 2017
From the description of the problem, I would have thought that the cost will fall on the manufacturer, or NR if they specified a substandard item. Certainly not ScoGov.
In any case the supplier of a component is probably only liable for replacing the defective component, not for the cost of swapping them out or the costs arising from delays to completion of the project.
I'm not so sure about that.
