Passengers treated just like peasants...
Tetchytyke
12 Sep 2013
Isle of Man
Legal tender is a bit of a red herring, in that it only relates to payment at court of a court debt.
People entering into transactions are free to specify what they will and won't accept as payment, and what the terms are. However if they are to insist on onerous terms, e.g. no change, then this should be made clear at the time of purchase.
A train company could set up a TVM to say "no change", and this would be fine. But the reputational damage means that they don't.
Bus companies with an exact fare policy usually promote what those fares are, those without exact fare usually don't. I don't mind either, so long as I know in advance how much change I'll need. IIRC bus companies will offer a refund voucher where you have to overpay due to a lack of change, though bus drivers probably don't like issuing them.
One last thing: you still have to use the roadside machines in London where one is present. My local route, the W7, was the trial route for the roadside machines and the drivers are not permitted to sell tickets on board. Cue several recent trips where the bus has stopped several times to allow a passenger to buy a ticket, after several of the machines had failed. I can't wait to see the back of them.
Deerfold
26 Nov 2009
I've yet to see a bus company that's exact fare only that won't issue a credit note if you overpay - usually to be exchanged at the company's offices somewhere.
Butts
16 Jan 2011
Stirlingshire
I suppose it depends on the amount you have overpaid , and where to draw the line.
If the fare was £1.80 and I only had 2 Pound Coins this would mean I was 20 pence down. However I would view it as my own fault for not having the correct change.
Same would go with a car park machine.
22 Sep 2013
Timbuktoo
The Machines should also display what denomination the change will be given in prior to the customer accepting to purchase the ticket.
I.e Order Ticket,place money into machine,machine says we can only give you change in 10 x 20p's and 30 10p's. You can then accept or decline.
Alternatively use your cash card.
jon0844
1 Feb 2009
That seems unnecessary to add. Could you refuse to buy on the account of not being happy with the way the change is given, for example?
At the end of the day, these machines are set to give change - using an initial float and then topped up during the day. They can only give back what they take in, and what's to say someone else hadn't opted to pay in small denominations?
When they can't pay enough back, they go exact money only. Even with loads of coins, it only takes a few people to buy £2 tickets with a £20 note.
I know you can't overpay even if you wanted either. If you did when it was exact money only, it gives an error and dumps all the coins back to you!
talltim
17 Jan 2010
Trouble with exact fare on buses is that how do you know how much it will be before you get on?
22 Sep 2013
Timbuktoo
Like an ATM that has run out of £10 notes it will either offer an alternative (higher/lower amount)or you can cancel the transaction and use an alternative one.
If there was Two machines available at least you would get this option before actually proceeding to complete the transaction if you do not wish too then use a Shop/Pub/ or buy off Guard.
The Machine should know what change it has available as it has to count it.
The problem with Coins is it costs business's money to''Bank it'' and in the Railways case with small denominations not so easy or too pointless to bother redistributing them through it's business's in forms such as in Floats to Conductors(do they have a way for them to give change to them or a Bus Driver?)so they just give them too the passenger
Perhaps it has been programmed by an Ex Conductor where they want Change at the start of a shift and Notes at the finish too it makes it easier to ''cash up'';)
22 Sep 2013
Timbuktoo
That's a problem with a lot of Bus Drivers and companies.
They just assume everyone travelling is a regular or local,and will be aware of fares and policies and which stop they will need to use.
Many times I have needed to get somewhere by Bus in an unfamiliar City and even though I try to carry as much change that I think will be enough it can often not be which will mean me asking the Driver the Fare and which stop I will need to get off at and if possible tell me when I'm at the required stop all while recounting my change to get to the right amount.
Yet a lot of times they do none of the above and I have to rely on and hoping a Passenger can help.
I often get a blank look that you see more increasingly similar to checkout Girls who get confused if you talk to them who have either got stuck in a routine of only saying what they have been trained to say.
ATM's will tell you what notes are available and whether you wish to take an alternative figure or not and use a different ATM.
If the Ticket Machine tells you that you will get X amount of 5p's,10p's,20p's before you confirm then that will give you the option to either use another machine or Buy On-Train or at destination.
Or perhaps they are programmed to get rid of it's ''shrapnel'' to Passengers rather than having to cart it around themselves when it's emptied.
It has probably been programmed by an Ex Guard who wants to take the change at the start of the Day and lose it at the end when it comes closer to ''cashing up'?;)
district
4 Aug 2011
SE16
For some reason, the company that collects money at my work give us too many bags of 5ps, which means sometimes you have to get a bit ''creative'' about getting rid of them. Last time I counted a float, I had 237 x 5p coins. :( A lot of people get very shirty when I give pound coins or lower denominations in change though, but I suppose that's what happens when you pay for a cheeseburger with a £20 note!
Agreed. If bus companies didn't keep their fare stage tables so secret perhaps people would have a chance to get the right money together!
22 Sep 2013
Timbuktoo
It costs money for business to change it at the Bank but not the general public.It appears they are just ''passing the Buck or 5p's ''so to speak in more ways than one.
Mojo
7 Aug 2005
I must be an odd character then as I tend to prefer coins to notes other than £5s. If the place takes American Express then I will always pay with that. If they don't take American Express, then for any small purchases (up to maybe £3 or £4) I will pay with cash, if not I will pay on my Visa debit card. It's extremely infrequent I am in somewhere where I have to spend something over £4 and they don't take cards. The only exception to my 'rules' above is that I will tend to pay in pubs or discotheques that don't take American Express with larger amounts of cash.
22 Sep 2013
Timbuktoo
''Discotheques''?Have you ever been in one since Credit Cards were invented?8-)
Flamingo
26 Apr 2010
On a similar vein, I once had a chap come up to the buffet first thing in the morning and ask for a coffee. When I told him it was £1.60, he produced a £50 note, picked up the coffee, and said "I'm taking the coffee, I'm offering you payment and if you can't change it I'm entitled to take it free".
I thought a second, said "I can change that sir", took out my second (unopened) £50 float, took £1.60 out of it, and handed the rest over to him -£40 in pound coins, £10 in assorted silver, less £1.60!
He picked it up, said "What do you expect me to do with that?", so I replied "You'd better check it's correct before you leave the counter, mistakes can't be rectified afterwards", and went to serve the next person (with a huge grin on my face)!
29 May 2008
Featherstone, West Yorkshire
Our flat fares are displayed quite clearly above the timetable at just about every bus stop we serve (probably all, but there may be a small number without) where I believe it also tells you that no change is given.
There are also posters on plenty of city centre stops which are a guide to using our buses in multiple languages for tourists, which include a part about having the exact fare.
We still get people asking what the fare is and then trying to pay with notes (or occasionally by card). :roll:
TOCDriver
24 Jan 2013
LOL I was about to make the same point! Mojo, son - how old are you? lol
Never know you guards to be the shop service too! Multi-talented or wot! lol
Deerfold
26 Nov 2009
I don't think he remembers before credit cards. Lol.
WillPS
18 Nov 2008
The Self checkouts at supermarkets have separate hoppers for change and money paid in (both for notes and coins)
Not true of the sort installed widely since about 2010 - I doubt there are very many older ones left in service now. Perhaps the Morrisons/B&Q/IKEA Nixdorf ones are different.
I've never known NCT to offer one, although that's probably to do with their staff's colossally poor attitude toward their customers.
island
30 Dec 2010
I understand TfL is consulting on removing the facility to pay cash for bus tickets.
Deerfold
26 Nov 2009
The NCT conditions of carriage at https://www.nctx.co.uk/customer-services/information-centre/terms-conditions-of-carriage/ say:
36. Excess fare receipts are available on request for passengers who are unable to tender the correct fare. The excess fare can be collected from the NCT Travel Centre.
Flamingo
26 Apr 2010
You would be amazed what I can turn my hand to! I think I was travelling, and was covering the CH having a widdle-break.
pjnathanail
1 Sep 2012
Loughborough
I have had one, but it wasn't offered, it was grudgingly given after I requested one.
I only knew about it because I was chatting to an old NCT driver who drove my school route and she told me about it
nomis1066
6 Sep 2013
Hastings
Hmmmm, not sure something like that would prompt me to write to the local rag - but he has every right to brassed off at getting his change in such pocket ripping quantity.
I recall in my relief clerical days - working a shift back in NSE days at Tunbridge Wells - a woman very abruptly asking for a £2 single to somewhere or other and slapping a crisp new £50 note onto the turntable. My colleague who had perfectly politely said "That's £2, please" waited a second to see if Madam might just say she was sorry but that was all she had or words to that effect. This was not forthcoming - so the large note was whisked into his hand, exchanged in the float safe for a £50 bag of pound coins from which - in front of her - he took two and then slowly whisked the remaing 48 coins and ticket round to Madam who's manners got even worse.
Whether she felt compelled to write to the local paper, I don't know.
Flamingo
26 Apr 2010
I've just remembered the two "young gentlemen" on a late train, from their behaviour obviously up to no good, who would not buy tickets until whoever was on the phone to them told them to buy tickets after I threathned BTP. A roll of £20 notes the size of my fist was produced, and one handed over with a smug grin - which was wiped out when I gave the £4.90 change in 5p's (without bag)!
jon0844
1 Feb 2009
As I said, the change given out from a TVM is what went in. While I'm usually in too much of a rush, I can see why some people might see vending machines as the ideal way to get rid of shrapnel. Have a few people do that, along with a few others paying with £20 notes and you end up with this situation that obviously has some people running to the papers!
quarella
7 Dec 2009
Familiarity means I don't notice the signs if they exist anymore but most buses (NBC, ex NBC and other large operators) used to have a sign stating "Please tender exact fare." Those commenting that they don't know what the fare is can still make an effort by having a selection of coins and notes available to be able to provide payment in something to make change easy and not just present £20.00 notes. In a staff handbook for a large operator I saw a long time ago there was a section on cash with regard to provision of a float and carrying personal money while on duty.
Many moons ago I sometimes drove a local authority subsidised bus route to a school. The council set the fares and had increased them by a percentage with no rounding up or rounding down so everyday I would have 30+ children presenting me with £1 coins for fares of 34p and 28p. Living in a seaside resort I would go to one of the amusement arcades and stock up on 2p pieces.
Later in life I worked in a large station booking office. I have paid in £200.00 worth of £5.00 notes even after selling some to staff still on duty. Conversely I have seen a similar amount disappear in my last hour of duty and on one occassion did have to give a sealed bag of 5p pieces instead.
Buttsy
20 May 2011
Hanborough
I use the bus infrequently and tend to have a range of notes available and ask if the driver can change it as I never know the fare and am happy to wait if he doesn't have enough change at the time.
I also don't complain when I'm given a lot of change for a note as I view it as 'it's all money in the end'.
dk1
2 Oct 2009
East Anglia
Perhaps I'm a bit anal as if I know I'm getting a bus tomorrow I'm worrying about having the correct fare today. My rucksack is usually well stocked for change at station coffee bars so I rarely have a problem. How I love Oyster though.
