Locomotive Services Fleet (LSL) updates
The Prisoner
22 Aug 2012
Just had an email from LSL offering a free rerun of the Avocet Achievement on Wednesday 7th October or a full refund. Bravo LSL/Intercity
neil65
15 Jul 2022
Huddersfield, Kirklees, United Kingdom
89001 Avocet yesterday at Crewe before its failure at Warrington
Neil
Paul AC
3 Aug 2025
Timperley
If LSL have made it work like that.
It's not really anything to do with LSL as such; any unpowered "AC Loco TDM" fitted vehicle (loco or DVT/DBSO) must "pass through" the two TDM circuit wires from one end of the vehicle to the other. It does this via normally-closed Line Closing Relays (LCRs) in the TDM Rack.
The TDM Rack in the Master vehicle in the formation (the one with the driving key inserted and turned) opens all the LCRs by sending out a burst of carrier wave, then messages the next nearest TDM rack in each direction to confirm if a TDM-fitted vehicle is there. If there is one, it gets configured as a Slave, then it closes its own LCR; the Master then searches for another Slave etc etc. In this way any combination of vehicles can be "configured" in front of and behind any driving cab; and each one knows which way is 'forward'/'reverse'. Any unpowered TDM-fitted vehicle is ignored. Configuration usually takes less than one second.
Any combination will configure, though of course many combinations are inadmissible for overhead current draw or other operational reasons.
So, DVT 82139 could technically have controlled 90001 via the dead 89001, but as I understand it there are operational reasons for not doing so.
norbitonflyer
24 Mar 2020
SW London
Would the LCRs function properly on 89001 if, as reported, it had a failed battery charger and was therefore electrically dead ?
28 Oct 2017
So the answer is yes, that is what "normally-closed" means here: if there is no power to the relays , it sits in the contacts closed (switch on) position, which bypasses the whole locomotive and connects the RCH jumpers at the two ends together (just like on each normal coach of the train).
Power is needed for the locomotive to respond to the carrier wave and become an active part of the driving system, but without that the loco falls back to being a very heavy coach. Clever design and obviously carefully thought through.
47286Dan
27 Dec 2018
Saturday morning tours/movements
50050 LSLO KIRKCALDY 031Z251622 U CHESTER N
40013 LSLO CREWE HS 420Z251I22 F CHESTER N
57302 LSLO BEDFORD 621Z071522 U KINGSWEAR N
47593 LSLO BEDFORD 621Z071522 U KINGSWEAR N
Dan
Nym
2 Mar 2007
Somewhere, not in London
This does of course all depend on the wiring being in the right place in the loco that it can work from either end or through the loco, not just the fundamentals of how it was designed in the first place.
Welshguy1048
6 Apr 2023
North Wales
Filmed at Prestatyn, North Wales
22/08/26 - Class 50 - 50050 (D400) "Fearless" T&T Class 40 - 40013 (D213) " Andania" Kirkcaldy to Llandudno - The Thistle & Dragon
22/08/26 - Class 40 - 40013 (D213) "Andania" T&T Class 50 - 50050 (D400) "Fearless"- Llandudno to Kirkcaldy - The Thistle & Dragon
neil65
15 Jul 2022
The Thistle & Dragon at Chester 22nd August 2026
D400 brought the tour down from Scotland & D213 Andania was attached at Chester to Llandudno
Iskra
11 Jun 2014
West Riding
I also caught this tour amongst other yesterday at Chester, Rhyl and Wigan. D413 always looks stunning!
HertiageFan
30 Jul 2025
Wakefield
Strangely the 40 hauled some of the trip solo, and the rake had no generator coach, how was the Central Door Locking powered? Thank you in advance for any information
Iskra
11 Jun 2014
West Riding
Possibly from the carriage batteries....fed by the carriage dynamos?
That would be my assumption too
Worth noting that it was a fairly light load by railtour standards
47286Dan
27 Dec 2018
Wednesday morning tour
47593 LSLO CHESTRFLD 271Z321626 U CARDIFCEN N
57302 LSLO CHESTRFLD 271Z321626 U CREWE N
Coaches
3091, 3140, 1666, 3107, 3125, 3148, 3100, 80044, 3122, 3045, 17013
50050 replaces 57302 at Crewe
50050 LSLO CREWE HS 420Z321C26 F CREWE N
Dan
Bank Holiday ECS move
47712 LSLO CREWE HS 425Z901H31 E NORLOWLEV N
47805 LSLO CREWE HS 425Z901H31 E NORLOWLEV N
Coaches
17056, 3229, 3188, 80043, 3438, 3312, 3426, 1863, 3344, 3348
Dan
HertiageFan
30 Jul 2025
Wakefield
Coaches
Dan
Coaches
Dan
It seems that 47805 has been removed and replaced by 57003
fgwrich
15 Apr 2009
Hampshire
So the ones that Porterbrook completely re-built and / or haven't been in LSL's tenure very long?
830 is a recent returnee to the mainline, whilst 810 I’m sure had an overhaul not so long ago. I’m not sure what’s up with 805 - there was a suggestion that it had slipped tyres on a recent trip to the West Country, hence it being left at Westbury. But then seems to have come out again, and yet again found itself left behind.
Of note, both 805 and 810 are both ex DRS machines, although prior to that 805 was Riviera whilst 810 was Cotswold.
