Locomotive Services Fleet (LSL) updates
D6130
12 Jan 2021
West Yorkshire/Tuscany
I haven't been closely following this thread, but if trying to divert around the incident area at Lewes, and keep the lead engine leading, you could run like so:
Haywards Heath
Keynes Junction continue towards Brighton
Preston Park
Spur to Hove
Reverse at Hove
Brighton platform 3
Reverse at Brighton
East Coastway to Lewes
And continue towards Eastbourne or wherever the tour heads
Presumably you mean Keymer Junction. Unfortunately platform 3 at Brighton is only long enough for four cars to and from the Hove direction....but why bother going to Hove for an additional reversal when you can just run straight down the main line into any of platforms 3-8 and make a single reversal onto the Lewes line? With a loco at both ends it's not a problem.
MiNi
22 Sep 2019
Sherborne
Haywards Heath
Preston Park
Spur to Hove
Reverse at Hove
Brighton platform 3
Reverse at Brighton
yes via Brighton both ways
712\593
Dave61
8 Mar 2026
Long Eaton
712\593
That's how we did it via Brighton
47 712 Lead the way down, 47593 coming back. we were stopped at East Croydon for about 45 minutes whilst the checked a "problem" which turned out that 593 was simply overheating but in the time we were stopped it cooled down enough to continue and was OK after that. They were considering moving 47712 to the front when they could but conditions cooled down enough I guess.
As we passed Harpenden on the way down the MML we saw a EMR class 810 stopped at the station with doors open (including the drivers) and people milling around, took a moment to realise that it was not supposed to stop there and guessed it was having a reboot as about 20 minutes later it passed us again. Looks like it was 810012 on the 1C20 07:34 from Sheffiled looking back as RTT
gazthomas
5 Jun 2011
Llandudno
I'm travelling on the tour with 89001 tomorrow (Tuesday, 18 August 2026). The paths on Real Time Trains suggest that the 89 will be pushing in one direction as there are no paths to leave Glasgow Central and I'm not sure a run around of locomotives is possible there. Can anybody confirm? I believe a mark 3 DVT has been included in the rake of carriages in the most recent test run (and possibly all test runs this year)
Paul AC
3 Aug 2025
Timperley
I can confirm that the formation is 89001 (north end) - 9 Mk.3 passenger vehicles - DVT 82139. So 89001 will lead northwards, 83139 southwards.
Though the Tebay test runs included the DVT, that was only for convenience with shunting at Crewe. The 89 ran round the train at Tebay on both runs to ensure that both driving cabs got a good workout.
gazthomas
5 Jun 2011
Llandudno
Thanks Paul. Looking forward to it, what a fantastic achievement!
28 Oct 2017
The recent test trip to Stafford worked DVT leading on the way out on a video I saw, which was my first confirmation that DVT running was available.
HertiageFan
30 Jul 2025
Wakefield
Strangely there is a path from Crewe H.S. to Carnforth Steamtown on Wednesday, and apparently it is pathed to use the turntable (the path is 5Z41)
Paul AC
3 Aug 2025
Timperley
82139 also led Crewe HS - Stafford (with just 87002 in between, as backup) as 5Z89 on 24/11/2025; and also on the Tebay test trains between Crewe HS and Crewe Down Refuge Siding as 5Z31 on 18/03/2026 and 20/03/2026. Also, not only did the DVT lead the test train Crewe - Stafford last Friday, it also led the test train Crewe - Gresty Green "on the way home". Part of the work in getting 89001 ready for traffic was ensuring that the TDM system works correctly. The run to Stafford and back last Friday was as much a shakedown for the carriages as for the 89+DVT.
Iskra
11 Jun 2014
West Riding
Railway Herald suggests this is a steam locomotive, but that goes against the current steam ban.
D6130
12 Jan 2021
Given the change in the weather, I suspect that the steam ban may be about to be overturned....if indeed it has not been already.
The Prisoner
22 Aug 2012
On the Railtour. Failed at Warrington due to a battery charger. 90 on the way. Will be terminating at Carlisle and spinning back.
Opened the doors at Warrington - probably here some time.
Live scenes. Northbound pendolinos having to use P4 @ Warrington Bank Quay as we are blocking 3
90 just arrived so on the way to Carlisle soon
18 Mar 2018
Train manager just came through saying contact the email address regarding a refund, they can't help the 89 going bang but how they handle the fallout they can help
Lets see what happens
The Prisoner
22 Aug 2012
Tbh I would have been happy heading to Glasgow behind the 90. Guessing they were hampered by paths, but moving departure back an hour and leaving less than an hour turn around in Glasgow was asking for trouble.
gazthomas
5 Jun 2011
Llandudno
Bigger issue was lack of run around at Glasgow Central. 90 can't talk to the DVT with the 89 in the way so needs somewhere it can run around
hexagon789
2 Sep 2016
Shouldn't need to be next to the coaches to 'talk' to the DVT, can send TDM signals through the 89's jumpers.
At least, the normal set up of TDM permits a dead loco to send signals through.
gazthomas
5 Jun 2011
Llandudno
I'm just going on what the driver and train manager communicated
Mollman
21 Sep 2016
Preston
Managed to see the Badger at lunchtime. Railcam reporting that the 90 was having break trouble on the return leg.
