Exactly what I was thinking. Battery trains have their place but Oxford needs wires.Used by some (govt) as an excuse not to electrify to Oxford?
Is it impressive? Electric buses are going further in the real world and they have far greater rolling resistance with rubber wheels rather than steel.Important to realise that this was done without any internal train lighting, heating or air-con, no doors opening and closing etc.
Still impressive but more a PR stunt than real life.
I believe it's max speed is 60mph, and based on the RTT schedules, it stopped at Paddington (twice), Reading (twice), Slough and Oxford.How fast did this battery train go? And it maintained a constant speed throughout?
Imagine doing that during the daytime in between service trains :It was limited to 40 mph on this run as that was the best speed to minimise drain on the batteries.
To be honest, I don't understand why the public sector is spending any money on battery train trials at all. Surely it is for the private train manufacturers to demonstrate that their products work if they want to win tenders?
I think that's why they did it as an all nighter!!!Imagine doing that during the daytime in between service trains :![]()
The main point of the 230 battery trials seems to have been to try out the fast charging possibilities for a train that spends little or no time on overhead 25KV AC. The main feature was that the supply of electricity from outside the railway only needed to be as much as is required in a normal built up area. So the power available to charge the batteries was limited. The fast charging is achieved by steadily charging fixed batteries at the charging station that the local supply can accommodate. Then when the battery train arrives the fixed batteries discharge a lot more quickly into the batteries on the train.Completing Vivarail's work on a charging system for recycled 3rd/4th rail EMUs did make sense if such trains were likely to be used...
...but now new trains seem the only game in town for which overhead charging looks simpler, more flexible and is already well proven.
There were several speed profiles in use depending on whether the train was running early or late and in response to anything In expected on the network. The speed profile was meticulously planned to get the most miles out of the battery and fit in between service and freight trains running with only the relief lines being in use due to a main line block being in place.It was limited to 40 mph on this run as that was the best speed to minimise drain on the batteries.
Conditions Estimated range SuperMode – Highest efficiency 200 miles All efficiency measures but running at full speed (60 mph) 100-120 miles Typical branch line operating conditions based on Greenford trial 50-80 miles
This was a three vehicle train with batteries under only the two end vehicles.The press release included a table of estimated ranges. It stated the estimated range for a typical Greenfield branch type usage was 50 to 80 miles which would be useful for many self contained branch services.
The full press release is available here.
Oxford - Milton Keynes or Oxford - Bedford. Those routes will have 25kV at both ends when Oxford is eventually wired so maybe those @Mr 196s can be replaced by BEMUs. I bet they would get a good 20 mins 25kV charge on each Bletchley - Milton Keynes - Bletchley trip as well as a quick turnround boost in Oxford. Good for subsidised passenger trains but NBG for freight.Well if battery trains are deployed for routes on which they are most suited (like the Thames Valley branches), that's not a massive issue.
If it is seen as some sort of replacement for continuous OLE work, then it's a much bigger problem.
Actually 200.5 miles for the record.3Q83 is back on Reading TCD so that should be 230001’s World Record in the bag at approximately 202 miles!![]()
Why are they still doing driver Training, I thought they decided they weren't going to run it in passenger service?230001 is back out and about. There will be Driver training runs on the Greenford Branch next week.
Realtime Trains | 5Q43 1633 Reading Traincare Depot to West Ealing Emu Sidings | 12/09/2025
Real-time train running information for 5Q43 1633 departure from Reading Traincare Depot to West Ealing Emu Sidings on 12/09/2025. From Realtime Trains, an independent source of train running info for Great Britain.www.realtimetrains.co.uk
Never say never!Why are they still doing driver Training, I thought they decided they weren't going to run it in passenger service?
Explains why they're still doing driver training on it then.Aparently GWR have applied to the DfT for the relevant derogations allowing 001 to enter service.
The detail, for anybody that is interested: https://www.gov.uk/government/consu...at-western-railway-class-230-fast-charge-unitAparently GWR have applied to the DfT for the relevant derogations allowing 001 to enter service.
Great to see that this might actually happen and isn't just wishful thinking!The detail, for anybody that is interested: https://www.gov.uk/government/consu...at-western-railway-class-230-fast-charge-unit
I see the consulatation periodm for the exemptions from accessibility requirements expires on 24th October, so presumably we won't see it in service until some time after that date.Great to see that this might actually happen and isn't just wishful thinking!
The December timetable change would seem to be a logical time to make the switch.I see the consulatation periodm for the exemptions from accessibility requirements expires on 24th October, so presumably we won't see it in service until some time after that date.
Ahhh, and you did not even say which yearThe December timetable change would seem to be a logical time to make the switch.
So it definitely won't be then.
