GWR Class 230 Information, Movements & Discussion.
martin butler
9 Oct 2018
So, Is this hoped for exemption a one off, or are GWR planning to introduce an small fleet of 230 battery units, as a stop gap, to replace 150's on the branch lines in Devon and Cornwall, with fast charging technology and then wait until a new multi-mode emu is developed by one of the manufacturers
norbitonflyer
24 Mar 2020
SW London
The derogation application specifically mentions the characteristics of the Greenford shuttle's platforms, so it probably won't be enough to allow wider use.
MotCO
25 Aug 2014
What accessibility issues are there? The carriages used are, as far as I know, the same as used in Wales and the Isle of Wight.
Ashley Hill
8 Dec 2019
The West Country
More likely to release the turbo for other work.
martin butler
9 Oct 2018
Has any of the stock GWR obtained when it purchased Vivarail been scrapped, If the 230 Battery train proves to be reliable in service, and replacement battery units are going to be years away, Surely it makes sence to replace the older DMU's with battery units, or where its not possible to fit fast recharging apparatus to keep a couple of the deisel 230's they have, to replace the older stock, such as the 150's, used in Devon, and Cornwall, as well as the thameside branches.
Another option might be to convert the remaining units, to 3rd rail, / Battery for Reading to Gatwick services, and that will free up turbo units to be cascaded to other GWR services?
REVUpminster
3 Jan 2021
Paignton
I think they need to keep the 230s at Reading for the Thameside branches. I did think they could be used on the Cornish branches but there could be too many weather related problems such as flooding at Looe.
Exeter does a good job keeping the 150s going that we are stuck with them until a new battery electric train arrives.
800301
29 Dec 2022
Essex
230001 was used to prove the technology, that was all, but while GWR have it they might as well use it in service, I can’t see it being fitted to older trains as they’ll only be around for a few years anyway so essentially a waste of money and making simple trains more complex and the extra cost for infrastructure, whole DMU replacement is a much better idea ideally FLIRT’s
John R
1 Jul 2013
I recall that somewhere up thread there is a very definitive statement from someone who is clearly closely involved in the project that there is no chance of further units being restored to service.
D365
29 Jun 2012
I concur. It would require an entirely new production line to be set up as the original manufacturing facility (and personnel) at Long Marston has been disbanded for several years now.
The exile
31 Mar 2010
Somerset
Though there was an equally definitive statement that this one was not going to enter passenger service, so who knows….
Very much doubt this will ever be more than a one-off, though.
Peter Sarf
Croydon
The is all in speculation territory about re-using further D-Trains and the ex Marston Vale 230s. Not sure I should add to it BUT there are plenty of indications that GWR only see 230001 as a test bed for proving the fast charging concept. Also lately there are indications that they will pursue using it (the one and only 230001) in service. Makes sense for GWR to use 230001 if it is usable (seems so) and see how it fares with the dreaded passengers using it. Especially if the Turbostar it replaces could be used elsewhere.
DelW
15 Jan 2015
Greenford and Windsor are the ideal branches. I don’t know how many GWR have but 2 plus 1 set spare seems ideal.
There is only one battery set in existence, no 001 tested at Greenford. GWR also have the ex Marston Vale diesel sets which have been stored OOU since Vivarail collapsed.
GWR had said originally that the turbo would be kept on standby locally when the battery set was in use. Though everything seems to be fluid with these plans ...
Peter Sarf
Croydon
The ex Marston Vale 230s have the engines on removble rafts which I think leads people to think that it is just a matter of swapping the rafts for ones with batteries on. But there are plenty of differences - at least the rest of the control equipment. So I agree that makes the ex Marston Vale 230s very different.
The way I look at it is that if GWR use 230001 on the Greenford branch then it does not eliminate the need for a spare Turbo (class 165 unit) that was presumably covering the Turbo that was in use but it eliminates the need for the Turbo that was actually in use. So as long as GWR view 230001 as being as reliable as a Turbo then it follows, one way or another, that one less Turbo is required at the London end.
The least of it is that using 230001 keeps the fast charge concept alive, allows more experience and saves a bit of pollution.
stadler
5 Jun 2023
Horsley
A. It’s self contained.
B. It’s short.
C. Can 230s only run as two cars?
No, 230001 and the Welsh ones are 3 car
They can also run as two units coupled to make up longer trains. Island Line have run 484+484 formations in passenger service to make up a 4 coach train. So the 230 could potentially work fine on the Windsor branch if they did this.
DelW
15 Jan 2015
I don't think there is a standby spare for the normal service (other than whatever is available at Reading). So using the battery set with a local standby wouldn't release a turbo set for use elsewhere.
Yes, I fully agree it would be desirable to use the unit in real world service. I think that a conversion programme to rebuild the D78s for use on the Thames Valley branches would have been good in principle, but it has to be admitted that both the 769s and the TfW hybrid 230s have been rather more troublesome than was envisaged when the conversions were begun. I don't think there's any possibility of such a programme going ahead now though.
Trainbike46
18 Sep 2021
belfast
I always interpreted the standy unit as an initial measure, during introduction when reliability was still low and problems were being ironed out, which would then be dropped after a while.
Obviously, a standby could also be used to cover for any issues at nearby branches, so it would still have benefits for local passenger service. It may even replace some of the spare/standby capacity at Reading.
Invincible
23 Apr 2022
The tender process for new trains seems be halted (and speculative threads closed) I expect fast charge batteries (and hybrid power small diesel range extender engines?) will be included when tenders are issued, also tenders carefully worded in a way so the current UK factories will get orders.
26 Jun 2019
If the standby was at Reading Depot during the day it would be useful as currently there is no spare Turbo during peak times.
If the spare was simply kept at West Ealing then you are correct it would be of no benefit. Except for getting experience of the technology in service, of course.
Purple Train
16 Jul 2022
Despond
What gives you that idea, unless you mean a double set? Huge loss in capacity otherwise, on what is often a very packed shuttle.
As a Windsor branch commuter, it would actually be a net gain in capacity as the shuttle has been limited to two coaches for some time now. I believe it's due to an issue with the DOO monitors at Windsor & Eton Central, but I think I heard that from somewhere else on the forum, so am happy to be corrected if the situation has changed.
Two coaches is fine for most of the day, except for the 08.30 from Slough in the morning, and the hour from 4pm to 5pm. The shuttle can't be longer than three coaches* because of the platform length at Windsor & Eton Central (there is a spare coach length of platform, but it is fenced off and would require rebuilding to be brought into passenger use).
*During events I believe it runs as a double set, but with extra staff on board as the rear door is off the end of the platform. I haven't actually experienced this first-hand so am not 100% sure.
Personally, I wouldn't mind a 230 on the Windsor shuttle - it has the same layover times as the Greenford shuttle, a shorter journey time, and, if all goes wrong and the 230 needs to be coaxed into a siding, it can be left in the old loop line at Slough, without needing to shunt across the main line. Though, obviously, they'd have to convert a few more of them first! I do hope this idea gets off the ground, but it's looking less and less likely. Which is a shame, because, much as I like the 150s and Turbos etc., I like the environment more!
cactustwirly
10 Apr 2013
Surely a 230 has less capacity than a turbo?
I thought the issue was the lack of rolling stock? There isn't an abundance of 3 car units at Reading
Purple Train
16 Jul 2022
Despond
Much as I did wince at the rather cheesy wording here, I get your drift ;)
I spent ages wondering if I should rephrase it, but decided eventually that nobody would notice my semantic steamrollering. Looking back at it now, I'm wincing just as much... Serves me right for being rhetorical!
Not when it's a 3-car 230 versus a 2-car Turbo, although I did forget that the ex-Marston Vale units are 2-car.
Indeed, hence my cheesy paragraph!
Woods
3 Sep 2021
Guildford
Future 230s for any of the GWR branch lines, if built, either for the Thames Valley, around Bristol, or in the West Country, could be either 2-car, 3-car, or even 4-car. There are enough stored ex-D78 cars to have whatever flavour is required. The 3 ex-WMT units are 2-cars, but there is no reason why they couldn't be extended to 3-car or 4-car if and when converted into BEMUs. There are then a variety of seating options available ranging from moreorless no change from the D78 layout (predominantly longitudinal seating with acres of standing space) to something more like the TfW 230s which have 2+2 'airline style' seating and tables in some areas, and ex-LUL longitudinal seating in other areas. You can also choose to have an accessible toilet or not. The 2-car Class 484s (a.k.a. Isle of Wight 230s) have predominantly longitudinal seating and no toilets, but they seem to have been pretty popular with the customers down there. The nice thing is that GWR own the ex-Vivarail designs and have the Engineers 'in house', so if they ever wanted to build any more 230s, which (contrary to some reports) has not actually been entirely ruled out, they could easily develop their own 'spec' to suit their customers' requirements, quite a unique position to be in for any Train Operator. Short platforms could be dealt with by fitting an Automatic Selective Door Operation (ASDO) system, a project for which is already underway for 230001, which will be the first time such a system has been fitted to any 230. Then it would just be a matter of getting a third party workshop to do the conversion work (it couldn't practically be done within the environment of a running depot). Oh and....funding!
FGW_DID
23 Jun 2011
81D & 81E
No the Slough / Windsor unit is booked to be a 2 car and has been for a while. Has to be a 2 car due to a restriction with the DOO monitors at Windsor.
