Guards location for working on Southern 377's Vs SET 377's
Alex-JER/LGW
21 Jan 2013
I am a regular traveller on Southern 377's between East Croydon & Gatwick Airport & on SET 377's between Tonbridge & Sandwich.
I have observed that nearly always on the Southern 377's the guards spend the time at different sets of doors throughout the train performing the closing procedure,I don't think that I can recall ever seeing a guard in one of the empty drivers cabs.Contrast this with SET 377's & again I have never seen the guard performing the closing procedure from any of the passenger doors-in fact they tend to hide away in the empty often rear drivers cab to close the doors from there. They don't exactly seem to be proactive in moving through the train performing ticket checks either.
Is there a different way of working for SET guards vs their Southern counterparts on the 377's? Or is this simply my experiences?
ChilternHenry
6 Nov 2012
Princes risborough
If the cab is empty no wonder you haven't seen a guard in one! However if they're hiding in the rear cab, than that can't be empty either. ;) I hope you found this usefull in answering your question :lol:
P.S. sorry couldn't resist
TheJRB
14 Feb 2011
Ashford, Kent
I can't say that I've shared your experience on Southeastern. In almost all of the journeys I've made on 375s the guard has been at one of the doors (moving through the train as the journey progresses) and they've checked my ticket on almost every occasion. Putting my pedant hat on it's 375s that Southeastern use (not 377s even though they're almost exactly the same) and SET (rather than SE) refers to the government run company South Eastern Trains (2003-2006).
tsr
15 Nov 2011
Between the parallel lines
Southern guards do use rear or (as applicable) middle driving cabs - it seems this is generally during times of exceptional overcrowding. Also, just because a guard is in the passengers' areas of the train doesn't mean they will do a ticket check whenever you see them (they may not have time to do any meaningful checks if the stops are close together or if they are updating themselves on any service disruption, to take two examples). They are always a good thing when publicly visible, though, because it gives a sense of security.
Alex-JER/LGW
21 Jan 2013
Thanks for the clarity-yes I did mean South Eastern 375's vs Southern 377's.
Post was not clear - thank you
455driver
10 May 2010
375?
377?
They are all the same anyway!
Except the /3s as they are a bit short.
notadriver
1 Oct 2010
Well there are a few little differences. 377s have DOO cameras and the first class areas have a door partitioning them off from the rest of the train. Also (unless this has changed) the conductors panel in the cab of 377s is not wired up for the conductor to close the doors thus he/she must be in the passenger saloon. In 375s the panels are wired up. But in my experience guards regularly patrol SET 375s unless its late at night.
pendolino
22 Nov 2010
They are wired up on a 377, but can only be used in the active cab with an EP key on (and you can't have 2 keys on at once as I am sure you are aware). Which seems a bit daft really. There is a keyswitch for the signal bell which uses a T251 so when the train is too rammed for the conductor to get to the saloon panel they can give the driver 10 bells from a non-active cab.
notadriver
1 Oct 2010
Ah right i see. That conductors key in a 375 also livens up the panel so the conductor can close the doors and give the signal bell from a rear or intermediate cab.
Class377/5
19 Jun 2010
Actually SET have 377s. They borrow them off FCC every single day. Including the once a day London Victoria - Ashford International.
pendolino
22 Nov 2010
This can't be true? I've seen many 377's dispatched from Shepherds Bush from the rear cab by the guard.
10 bells. The guard is not actually closing the doors, he/she is just giving the 1-2 bell code to tell the driver to close the doors. Driver repeats 1-2 back and closes the doors, guard gives 2 when all doors are shut and the train is ready to leave, driver gives 2 back. And off we jolly well go.
3+3+2+2=10.
Pumbaa
19 Feb 2008
Good posts this morning.
Only thing to add is Southern policy - which I believe is Guards to be in the passenger areas at all times. If the train is too busy, they have to ring control and tell them they're going into the cab. Perhaps Sarahj can confirm either way.
15 Aug 2010
They tried to get guards to call control before working from the cabs except because everyone was trying to do so during the peak period no one could get through, that was about 4 years ago though, needless to say that instruction was quickly dropped, control weren't interested anyway they normally had a lot better things to deal with especially during disruption, there again you were lucky to get through to them anytime
Safety365
8 Dec 2010
They are wired up on a 377, [...] There is a keyswitch for the signal bell which uses a T251 so when the train is too rammed for the conductor to get to the saloon panel they can give the driver 10 bells from a non-active cab.
5 bells - 1-2 (Close doors) + 2 (Ready To Start) = 5
driver repeats = 10.
/pedant
Because they're rammed full.
I tend to find that 375s are white and blue, whereas 377s are either white and green or blue and pink. :P
377s in FCC colours are not blue, they're purple!
377/1 No glass sliding doors
377/2 No glass sliding doors
377/3 I can't remember
377/4 Yes glass sliding doors
377/5 Yes glass sliding doors
Galvanize
8 Jun 2005
South East london
If the conductor is working the train from the cab on a 377, they usually let the driver know their gonna be using the 10 bell system. So they'll let them know that the train is busy, and where they expect to return to dispatching from the door panels.
Only time I believe they tell control is if the train is short formed, IE 8 vice 12 or 4 vice 8, and the FC sections have to be declassified.
bicbasher
14 May 2010
I've travelled on a 375 between Charing Cross and London Bridge where the guard has worked from the rear carriage using the final set of passenger doors.
I've also noticed that some Southeastern guards on this stretch have sat down in a passenger seat for this final stretch of the journey.
