Great Western Livery
PHILIPE
14 Nov 2011
Caerphilly
Amend 150202 to New GWR Livery. Arrived back at PM from Doncaster last night. Thanks
fgwrich
15 Apr 2009
Hampshire
Good, that confirms that 202 / 216 are staying, with potential for 212 to be staying as well once rebuilt with a new lav & conversion to 52xxx car.
superalbs
Verified Rep - Superalbs Travels
3 Jul 2014
Kraków
Interesting to note that, like the Class 150/0s, the front door by the cab is in green, rather than silver as it is on the rest.
spark001uk
20 Aug 2010
It's not the only class they do that on. It's done primarily to disguise it to the passengers, ie that this is not a door for public use.
Except on a /2 coupled to another gangwayed unit it is a passenger door! Not a common use case, though, and probably a sensible move.
Sent from my iPhone using Tapatalk
fgwrich
15 Apr 2009
Hampshire
It's a bit of an odd one, and another little anomaly on the FGW Fleet. All the Wessex, Local Lines & first versions of the Plain Blue 150/2s had the crew door painted in the same livery as the bodyside to as you say, distinguish it from being a standard passenger door.
Then, in the last round of repaints in FGW Blue, the crew door started to be painted Rubine Red to match the passenger saloon doors. This seems to have continued through the First GWR Repaints - Oddly stopping on this unit.
superalbs
3 Jul 2014
Kraków
It could be that Doncaster was following the same painting specification for the Class 150/0s, thus resulting in the front door being treated as non-passenger door and being painted green. Although the photos I have seen don't show the word 'Private' on the door, so I don't know.
96tommy
18 May 2010
I went on a refurbed 166 the other night from Reading to Paddington and noticed lots of the seat backs weren't attached to the seats itself. Is this a common problem on the fleet what have been refurbished?
59CosG95
18 Aug 2013
Beeston (Notts)
Not sure on that score, but Deepgreen will definitely take note if he hasn't done so already!
spark001uk
20 Aug 2010
Dunno but I'm pretty sure this one I was on yesterday is somewhat in need of an interior Refurb!
If memory still serves I think it was either 165130 or 118.
fgwrich
15 Apr 2009
Hampshire
If it's the fully refurbish Turbo then it does seem to be a problem on the refurbished stuff - LA15 still has a lot of it's seat backs lose in the Grammer seats, despite being refurbished well over a year ago.
Sadly it's becoming a common scene in some of the Turbos now! That just has ripped moquette on it's side panel, one I had last week had the trim between the window and this panel completely missing. And don't look at the floors either!
sd0733
7 Nov 2012
With northern forming up 3car 150s and I believe taking the toilet out the centre cars would it not be logical to swap those 2 coaches with a 2car northern 150/2 to save 1 vehicle having to have a toilet fitted while others are taken out. I know they've got to have new ones anyway but must still be quite a lot of plumbing and pipework missing on a non toilet car
greaterwest
23 Nov 2014
I can certainly confirm this is an issue with 166205 (the one with the interior refurb) - the cushions are slightly smaller and slightly less square.
As for the HST, it was holding up well last time I used it, though that was last year.
387star
that's bad! someone said tables are being ripped off walls too?
96tommy
18 May 2010
Thats the one, didn't realise only 1 had been done
PHILIPE
14 Nov 2011
Caerphilly
The present toilets have all got to be ripped out and replaced with new ones and CET Tanks to comply with PRM Regulations.
fgwrich
15 Apr 2009
Hampshire
Shouldn't be too much of a Problem for Wabtec anyway, they've just installed and moved toilets around in the 32X fleets anyway, not least the ex LM321/4s for ScotRail.
spark001uk
20 Aug 2010
I think they're even scrapping the older gravity-fed CET toilets now in favour of vacuum ones aren't they. The 158/159 refurbs are an example of this.
83G/84D
28 Oct 2011
Cornwall
43194 has quickly returned to service.It is now in Plymouth with an all green set and 43188.Due to work 1542 Plymouth to Paddington via Bristol.
Parallel
9 Dec 2013
Carriages 212 and 209 have been fitted with wifi so I'd assume they're staying. I wish they'd change the seating and add tables in though - that applies to 150202 and 150216 as well!
PHILIPE
14 Nov 2011
Caerphilly
The seating cannot be changed to 2+2 if that's what you mean. When they were transferred in together with the 150/1s, the DFT specified by quoting the number of seats. They could then say we are providing an additional XXX number of seats in order to give a good impression.
iantherev
3 Apr 2011
Brecon Beacons
There must be a period beyond which this doesn't apply. Otherwise no- one could ever change anything.
Presumably seats had to be altered to put the PSVAR bog in.
fgwrich
15 Apr 2009
Hampshire
Good, I reckon that confirms 212 then as a future GWR 150/2 again then.
Not quite as such sadly, as both the prototype 150/0s, Northerns 150s and the 319s have shown. They just take out a few of the double rows leaving singular seats, along with a random facing seat as well.
I'd like to hope that one day they'll be brought up to standard though to match the Ex Wessex /2s, otherwise it'll remain a little disappointing to see those to remain as such. There must be enough of those Chapman seats out there In storage!
Deepgreen
12 Jun 2013
Gomshall, Surrey
It certainly seems as if the 166 fleet has been completely abandoned as far as any attempt at passenger information/uniformity is concerned. What a shambles. To those who (and they will) insist that the priority is to keep the trains running; I say - employ people who can spot the huge number of quality control issues and correct them, given that the 'right first time' mantra clearly doesn't exist at GWR, despite their very high profile livery/corporate identity re-launch!
'Broken record' it may be, but the current position with the 166s is diabolical. I've never known a fleet of trains (and therefore their passengers) to have been treated with such disdain by their operator.
455driver
10 May 2010
None of the refurbished sets have had the cabs modified to Wessex standardso I cant see the interiors being changed, its easy to tell the original spec ones because they have both markers and a headlight lit but the ex Wessex ones only have one marker and a headlight lit.
59CosG95
18 Aug 2013
Beeston (Notts)
I think Trenitalia's regional fleet of coaches would be in contention for that title. Never seen a country with such a graffiti problem.
FGW_DID
23 Jun 2011
81D & 81E
All right Victor Meldrew, deep breaths, you'll do yourself a mischief!:lol:
Sounds like you're after a job? I'll find out who the sticker contractors are for you and you should apply.
Shall I also let the rest of the team know, we've got it all wrong with the 'keeping the trains running priority', fancy wasting our time making sure there are units to cover the service, heavens forbid! :lol:
