GBRf Class 99 - 30 locomotives now ordered
1D54
1 Jun 2019
Thanks for the update. Look forward to seeing it later at Leicester.
4 Apr 2025
Chesterfield
Does anyone know what day and which boat 99007 arrived at Portbury on please? The boats name and/or the IMO (International Maritime Organisation) 7 digit number would be appreciated.
Does anyone know the answer to this question please? From what I've been able to search across the internet so far, no one seems to know the answer!o_O
Current Class 99 locations are the same as posts #1508 and #1509. Nothing has changed since then apart from the arrival of 99007.
themiller
4 Dec 2011
Cumbria, UK
Probably Oregon Highway which has come from Sagunto. IMO 9381665. (From Marinetraffic.com).
47286Dan
27 Dec 2018
Friday morning update
99001 MBEL LESTER SD LESTER SD F B
99002 MBEL PBOROSDGB PBOROSDGB F B
99003 MBEL PBONYGBRF PBONYGBRF F B
99004 MBEL LESTER SD LESTER SD F B
99005 MBEL LESTER SD LESTER SD C B
99006 MBEL LESTER SD LESTER SD F B
99007 MBEL LESTER SD LESTER SD F B
Dan
Minstral25
10 Sep 2009
Dan
See these reports appearing across RailforumsUK, appreciate this is a TOPS report and useful to many but I don't understand all the abbreviations. I can guess some of the meanings (like LESTER is Leicester) and the loco numbers, but not what MBEL means for example. Can anyone link me to an explanation of all of the abbreviations on these reports please.
Peter Sarf
Croydon
There is a list of abbreviations somewhere - I think a thread. Cannot find it at the moment.
FrodshamJnct
14 Apr 2019
Cheshire
wickham
3 Feb 2021
Knaphill
MBEL is the loco pool: PBOROSDGB is probably Peterborough Depot, GBRf. The odd letters reflect the status, but I can't quote what they all are, expect "N" is normal and I think letters like "A" or "B" are Exams. Most of the location abbreviations can be worked out (like LESTER or PBORO) but I must say, some are a bit onscure !
The_Train
2 Jun 2018
WNXX news pages reporting that 6 of the 10 ETS equipped 99s will arrive into the UK in a Belmond livery for use on the posh trains
The Bear
11 Sep 2019
Cumbria
It's been previously known about the Britannic Explorer going over to 99s but I now assume from that, that the Royal Scotsman will also go over to 99s as well?
taken over from dB cargo on the other trains?
Given that GBRF don't do steam I can see the British Pullman staying with DB.
Rail Quest
8 Apr 2023
Warrington
Assume this means the Britannic explorer? Unless someone knows that gbrf have already taken over from dB cargo on the other trains?
Presumably these locos will cover both the Britannic Explorer and the Royal Scotsman, right?
I note that the original report says "livery", as in only one, so are they getting one livery for use on both tours, assuming my assumption above is correct? If so, what would that livery be?
800001
24 Oct 2015
The actuall text from wnxx attached below
Looking ahead at the ten ETS equipped Class 99s (99021 to 99030) being constructed for use by GBRf, it is planned (this will be dependent on contractual things in play at the moment) for six of these to be delivered in Belmond livery. This will allow for the Class to be deployed to both the Belmond Britannic Explorer and Belmond British Pullman operations, the latter currently operated by DBC with Class 67s.
ABB125
23 Jul 2016
University of Birmingham
How many trains do Belmond run they can justify 6 painted locomotives? Is it known if they will be dedicated to Belmond trains (which presumably isn't a very high utilisation rate, but if that's what Belmond want to pay for...) or general use in between Belmond workings?
800001
24 Oct 2015
Royal Scotsman sometimes uses 2, then there is the Brittanic Explorer which uses 2.
I don't think 6 locos which will need painting anyway as brand new is excessive.
And no probably not dedicated, ie Royal Scotsman 66s seen on freight trains frequently
99009
4 Apr 2025
Chesterfield
Thank you for taking the time to answer. 99007 was seen at Portbury on 28th April. I don't know if that's the date Oregon Highway arrived at Portbury, can anyone confirm this please?
Tobytrain10
2 Feb 2026
Lincoln
New test paths for GBRF added all next week with headcode 4Qxx going between peterborough and doncaster, possibly top and tail class 99s because they are pathed into the station with a turn around time of 10 minutes, im pretty sure at least, they are going on both ECML and Via Lincoln line at both day and night from tuesday, it is very possible ita something else entirely but im not sure what else would use both 4 and Q in headcode, we need more info because the loco that gets the wagons at march has headcode 0Z37 not 0Q37 which might suggest its not 99s, im not sure but these paths are really confusing me
Dood75
8 May 2019
If I'm reading Vesselfinder correctly it looks like it didnt arrive Portbury until 30/04/26 06:21
RailwayRookie
28 Jul 2023
Norfolk
A little birdie tells me these all of these paths are associated with the 99s. But 4Q82 is followed by 0E82 from March to Peterborough so who knows.. perhaps they are hooking up to a 66 for the return
Tony2
7 Apr 2019
The actuall text from wnxx attached belowLooking ahead at the ten ETS equipped Class 99s (99021 to 99030) being constructed for use by GBRf, it is planned (this will be dependent on contractual things in play at the moment) for six of these to be delivered in Belmond livery. This will allow for the Class to be deployed to both the Belmond Britannic Explorer and Belmond British Pullman operations, the latter currently operated by DBC with Class 67s.
I thought the plan would be that these would be 99401-99410?
Tobytrain10
2 Feb 2026
Lincoln
Is it also possible the class 99s dont need Q anymore for light loco movements?
99009
4 Apr 2025
Chesterfield
Thank you @Dood75 - assuming that's correct that means it must have been another boat and not Oregon Highway, as the earliest picture I've seen of 99007 at Portbury was on the 28th.
I find it strange that this time no one knows the name of the boat it arrived on and there haven't been any pictures of 99007 with the boat in the docks when on the other occasions there were. Maybe it's because it was delivered on its own.
If anyone does find out what boat 99007 arrived at Portbury on (and what date it arrived) please let me know.
172007
2 Jan 2021
West Mids
Not sure the angle of the question?
Usually a subclass is used to denote / differentiate between a different spec vehicle for operational ease in identificaton and correct allocation to trains.
It makes sense to number an ETH equiped class 99 into a subclas such as a 99/1 but nothing stopping them being made a /4.
