Can anyone help me to complete this list with vehicle types and ensure the frequencies are correct? Thanks.
Key
| Sd | Single-deck vehicle |
| Dd | Double-deck vehicle |
| Route | Route | Frequency (mins) | Type |
| 1 1A 1B | | 10 | |
Services combined for stated headway...
| 1 | 30 | |
| 1A | 30 | |
| 1B | 30 | |
...made up of these individual services.
| 227 | | 30 | |
| 227 | 60 | |
Full route runs on lesser headway. Additional journeys operate part-route for increased headway.
1-19
| Route | Route | Frequency (mins) | Type | Changes/Comments |
| 1 1A 1B | | 10 | Sd | Doesn't seem to be too affected by cancellations. |
| 1 | 30 | | |
| 1A | 30 | | |
| 1B | 30 | | |
| 1C 1D | | 10 | Sd | Doesn't seem to be too affected by cancellations. |
| 1C | 20 | | |
| 1D | 20 | | |
| 2 | | 12 | Mix | Reduce to every 15 mins and convert to doubledeck operation. |
| 3 | | 15 | Dd | Reduce to every 20 mins. |
| 4 4A | | 20 | Dd | Unsure if possible to reduce to every 30 mins (each branch every 60')?
Extend from Broomhill to Knightswood fully replacing X4. |
| 5 | | 15 | Dd | Reduce to every 20 mins. Extend from City Centre to Drumchapel fully replacing 6A. |
| 6 | | 15 | Mix | Reduce to every 20 mins and convert to doubledeck operation. |
| 6A | | 15 | Mix | Withdraw, fully replace with 5. |
| 7 7A | | 12 | ? | Reduce each branch to every 30 mins (combined frequency every 15 mins). |
| 8 | | 30 | ? | |
| 9 9A | | 7.5 | Sd | 9: Reducefrom every 15 mins to every 30 mins and run with doubledecks.
9A: Unchanged @ every 15 mins Buchanan - Penilee.
10: Renumber 9B and reduce to every 30 mins.
9 and 9B combine on common section for service every 15 mins. Adding 9A brings to every 7.5 mins.
Run entire thing with doubledecks. |
| 10 | | 20 | ? | Renumber to 9B. |
| 14 | | 60 | ? | |
| 16 | | 30 | ? | |
| 18 | | 15 | ? | Reduce to every 20 mins. |
| 19 | | 20 | ? | Reduce to every 30 mins. |
20-39
| 21 | | 30 | Dd | |
| 31 | | 30 | ? | |
| 34 | | 15 | Sd | Reduce to every 20 mins. |
| 38 38A | | 15 | Dd | Unsure if frequency can be reduced at all? |
| 38 | 30 | | |
| 38A | 30 | | |
| 38B 38C | | 15 | Dd | Unsure if frequency can be reduced at all? |
| 38B | 30 | | |
| 38C | 30 | | |
| 38E | | 30 | Dd | |
41-59
| 41 | | 15 | ? | Reduce to every 20 mins. |
| 43 | | 30 | ? | |
| 46 | | 30 | ? | |
| 49 | | 60 | ? | |
| 57 57A | | 10 | Dd | |
| 57 | 20 | | Reduce to every 30 mins. |
| 57A | 20 | | Reduce to every 30 mins. |
| 59 | | 60 | ? | |
60-79
| 60 60A | | 15 | Dd | Can't really reduce frequency at all as each branch is already only every 30 mins. |
| 60 | 30 | | |
| 60A | 30 | | |
| M60 | | 15 | Sd | |
| 61 | | 15 | Dd | Run as-is Summerston to City Centre, then as per current route 64 to roundabouts at southwest corner of Sandyhills Golf. Route splits: 50% of journeys (every 30 mins) follow current 61 route to Sandyhills; other 50% follow current 64 route to Carmyle. |
| 64 | | 30 | ? | Withdraw route (fully replaced by modified 61). |
| 65 | | 30 | ? | |
| 75 | | 12 | Dd | Reduce to every 15 mins. |
| 77 | | 15 | Dd | Is it possible to reduce City - Braehead to every 20 mins or every 30 mins with one an hour going to the Airport? |
| 77 | 30 | | |
80-99
| 81 | | 15-20 | Dd | Reduce to every 30 mins. |
| 87 | | 20 | Dd | Reduce to every 30 mins. |
| 88 | | 20 | Dd | Reduce to every 30 mins. |
| 89 89B | | 20 | Dd | |
| 89 | 20-40 | | |
| 89B | 60 | | |
| 90 | | 30 | ? | |
| 93 193 | | 60 | ? | |
100-199
(no services)
200-219
| 201 | | 15 | Sd | Reduce to every 20 mins. |
| 206 | | 15 | Sd | Reduce to every 20 mins. |
| 208 | | 45 | Sd | |
220-239
| 226 | | 15 | Sd | |
| 227 | | 30 | Sd | Reduce to every 60 mins over whole route. |
| 227 | 60 | | |
| 229 | | 60 | Sd | |
240-259
| 240 | | 12 | Sd | Section City to Baillieston increase to every 10 mins and use doubledeckers. This section needs to be frequent due to removal of route 61 from Bellgrove and Tollcross area. Every second journey (every 20 mins) continues as per current route to Overtown using doubledecks. |
| 241 | | 7.5 | ? | Reduce whole route to every 15 mins. |
| 241 | 15 | | |
| 242 | | 20 | Sd | Reduce to every 30 mins. |
| 244 | | 60 | ? | |
| 251 | | 60 | ? | |
| 254 | | 15 | ? | Reduce to every 20 mins. |
| 255 | | 30 | Sd | |
260-279
| 263 | | 30 | Sd | |
| 266 | | 7.5 | Sd | Reduce each branch to every 20 mins (combined frequency then every 10 mins). |
| 266 | 15 | | |
| 266 | 15 | | |
| 267 | | 15 | Dd | Reduce to every 20 mins. |
Other
| 500 | | 15 | Dd | |
| M3 | | 60 | Sd | |
| M4 | | 60 | Sd | |
| M11 | | 30 | Sd | |
| U1 | | 30 | Dd | |
| X3 | | 20 | Dd | Reduce to hourly if possible? As alternatives exist (Stagecoach). |
| X4 | | 30 | Dd | |
| X8 | | 30 | Dd | |
| X11 | | 30 | Dd | |
| X85 X87 | | 15 | Dd | |
| X85 | 30 | | |
| X87 | 30 | | |
Edit: I apologize for the really rubbish formatting of the tables. In the editor they are formatted neatly but when I pressed the button to Post it compressed all the tables which is not what I wanted.
Edit 2: Think I've got the formatting as fixed as I can get it.
Edit 3: Added suggestions for where services could be cut to improve reliability.
