"Doors will open on the left hand side" - whose left?
riceuten
23 May 2018
I asked this once of a conductor of an SNCF train when a similar announcement was made and he said "Always in the direction of the train"
What other interpretation of “door not in use” is possible? I’m struggling a little here :)
Most people would take "Door not in use" to mean it is out of order and can't be used at any station. That isn't the same thing as "Door is in use but won't open at this platform"
Krokodil
23 Jan 2023
Wales
Or indeed "Door is in use but the unit isn't sure which platform it should be arriving at so it's going to show 'out of use' until the guard releases the doors manually".
Peter Mugridge
8 Apr 2010
Epsom
There's one class of trains I've been on a few times - can't remember which - where it shows "door not in use" at all times between stations, and only when in the platform does the light with that message on it go off.
Seems to me that's a very silly way of doing things.
Actually might have been a tram somewhere, but still can't remember which ones...
styles
7 Dec 2014
Gwynedd
Some of the newer TfW rolling stock does it. It confused me the first time!
That's really stupid. Whoever designed it didn't give a moment's through to the human factor.
The whole point of a "door not in use" indicator is so people intending to alight have a chance to see beforehand that the door won't open, and move to another one. That's defeated if the indicator is always on unless the door is released. If they have to do that then "door locked" text would be better.
DelW
15 Jan 2015
TfW 197s do that, showing "door not in use" in red on both inside and outside buttons, until the guard releases them some seconds after the train stops. I don't know what they show if the door is actually broken. It's very confusing when you first encounter it.
For the 197s, it means "door hasn't yet been released" although it may be released imminently.
Tester
5 Jul 2020
Watford
It does indeed, but that flies in the face of any reasonable interpretation.
What were they thinking?
D1511
29 Jul 2023
WCML N
I was thinking the very same thing. What a preposterous idea, that just invites passenger confusion.
Clearly manufacturers are over-thinking this complete non-issue as well.
nilvaj395
11 Oct 2025
Honestly if they just removed the 'out of use' text on those lights it wouldn't be as much of cause for confusion. The staff would know what it means but it doesn't cause the passenger as much anxiety.
styles
7 Dec 2014
Gwynedd
But then it would just say 'door' ;)
The exile
31 Mar 2010
Somerset
it’s bad enough that the manufacturers came up with it and someone accepted it, but that nothing has been done about since beggars all belief.
nilvaj395
11 Oct 2025
Then, by implication, it wouldn't be a door when it was released. As I suggested earlier, Door Locked is the text that best matches the function as described - they probably even have that as a standard product for use in the toilets.
Door locked is much much better.
takno
Verified Rep - Traksy
To be fair "Toilet out of use" increasingly means nothing very much more than "toilet door got a bit confused but will sort itself out if you manually ease it out of the half-open position". Obeying lighted signs on modern trains isn't really a workable option it seems.
Hadlow Road
11 Jan 2024
N E Wales
But this is like Euston, where a large red X and Platform Closed leads one (O.K., me) to think that the platform is closed and out of use. Rather than simply not open just now. There is such a difference and my first sighting did cause a little consternation.
Starmill
18 May 2012
Bolton
Usually when you see the sign light up, but the door is on the platform, the door then opens. It just lights up at every door at most stations with more than one platform. It's very rare you'd see the sign and then not have the door open, though of course if you got caught out...
Or the door isn't currently in use, but wait 1-5 seconds and then it will be...
All of the CAF trains do it.
On 195s the door not in use sign stays lit after the door has actually opened for 1-2 seconds sometimes.
I suspect few if any senior managers at the TOCs affected even understand there's a problem.
CHobbs
15 Mar 2018
So I just noticed this on a Transport for Wales service.
I am travelling in a backwards facing seat. On the wall at the rear of the carriage is an electronic display.
As we approach stations, it will say, "Doors will open on the left-hand side". This is your left-hand as you face the screen which means the left side when looking towards the rear of the train.
Either this is a fault, or the side it says doors open on is dependent upon whether the screen you're looking at means you're looking at the front of the train or the rear.
Assuming it's not a fault (because I'd expect all the station info to be wrong also), to me this doesn't make sense. Consider for a moment that TfW might decide, like TfL do on some Tube services, to put it out over the public address system - you wouldn't be able to do this unless you made sure only to have screens facing one direction within each carriage.
Surely logic dictates that left hand side or right hand side is relative to forward direction of the train? Or am I going mad? Or is this just a fault and I can stop questioning life?
It’s always in direction of travel.
signed
13 May 2024
ROI
The famous Paris Metro Line 14 announcement for the island platform at Gare de Lyon "doors open on the left" is from direction of travel as well
Gare de Lyon, Gare de Lyon, à cette station descente a gauche, doors open on the left, uscita a sinistra
Gare de Lyon, Gare de Lyon, at this station exit on the left, doors open on the left, exit on the left
