"Doors will open on the left hand side" - whose left?
Starmill
18 May 2012
Bolton
It’s always in direction of travel.
Have you read the thread? The thread discusses extensively how this isn't the case, it's in the direction you're facing when you are looking at the screen. This may be the same as the direction of travel or it may be the reverse when you're facing the rear of the train.
9 Sep 2022
MAN
The Amsterdam metro deals with this non-issue quite nicely. The entire door frames are illuminated on the platform side when the unit pulls into a station.
I also like how it remembers you've pressed the door button indicating your desire to get off at the next stop, and the button stays illuminated until the doors are released......they open without having to press the button again.
I’ve quite forgotten why we even need to press a button for the doors to open.
Can anybody remind, why don’t they just open?
DelW
15 Jan 2015
In modern times its due to not wasting energy with air conditioning.
And in winter, keeping the warmth in, rather than allowing wind and rain in unnecessarily.
I wish the doors on our local trains would re-close more quickly, rather than staying open until it's ready to depart. There are passenger close buttons, but hardly anyone ever uses them.
nilvaj395
11 Oct 2025
…and reducing wear and tear on the mechanisms.
Those too, thanks!
blimmo
30 Jul 2025
West Mids
Imo there should be 4 states indicated on a door:
  1. Broken: use a different door
  2. Not going to open here (other side, SDO)
  3. About to open (button pressed or busy station where doors always open)
  4. Waiting for a button press
There should also be a differentiation between doors about to close to keep the hot/cold air in and those about to close because the train is departing. Perhaps sharing indications 4. and 2. respectively.
TUC
11 Nov 2010
But so many doors are likely to have passengers wanting to leave that having the individual door opening mechanisms potentially uses more energy.
Yes, but as said multiple times, most of us have the common sense to know that the only consistent logical meaning is the direction of the train.
Falcon1200
14 Jun 2021
Neilston, East Renfrewshire
Maybe I have misunderstood, but surely all trains have individual mechanisms for each door or pair of doors?
The last trains in Scotland to have all doors opening regardless of need were the Class 314s, and when these stood at Neilston for 20 minutes they got very cold!
In every case I can think of, the "open" button is illuminated when the door closes but can be re-opened.
andy33gmail
23 Mar 2025
cambridgeshire
5. About to time-out and close (press it again)
6. About to close and lock (panic)
Starmill
18 May 2012
Bolton
It's your personal view that it's common sense. It's not a factual point.
Pnerick81
5 Jan 2024
Bamber bridge
I hate to think what would have happen if we had slam doors nowadays. Folk just don’t have the same level of common sense .
I also think it’s common sense too . It’s the only left side that makes sense .
TUC
11 Nov 2010
We would probably have threads on 'how hard should I slam the door?' and 'whose responsibility is it if I don't manage to close the door properly?'
Pnerick81
5 Jan 2024
Bamber bridge
Christ we would have full
Topics on doors . Sub topics . Handleless doors from the inside!!! Can I get the same train back to my station? Quick response needed !!!!!
Starmill
18 May 2012
Bolton
That's as may be. But I am not sure your opinion has anything more to do with the answer to the post I was quoting than TUC's does.
Belperpete
17 Aug 2018
On 197s it's triggered by door release at multi-platform stations. Also when running "bang road" (during engineering work for example) the signs will show the normal side and update when the guard releases the "wrong side" (but right in this circumstance) doors.
Are you sure? I have just had a trip on a 197 where the displays consistently showed the wrong side for every station! Fortunately the doors themselves opened on the correct side.
Krokodil
23 Jan 2023
Wales
Occasionally you get a confused unit.
Baxenden Bank
23 Oct 2013
Okay, explain this photograph.
The photograph shows two in-carrriage display screens, both facing the same way, but showing arrows in opposite directions. Someone designed (wrote) that, someone signed it off, someone installed it and checked it during unit introduction, someone hasn't changed it (or turned it off) since. For the avoidance of doubt, Cil-y-Coed / Caldicot has platforms on the left, only.
Sorry for the upside down photo, it's correct when I open it on my computer.
JamesT
25 Feb 2015
Are there any screens in those units that face the other way? I would expect that there's a config option somewhere as to which way a screen is pointing in order that the arrow points correctly. Clearly on one screen that's been done right and one wrong.
Similar to this screen I saw in Oxford a couple of weeks ago. There were a couple of engineers poking at the wiring, so presumably thinking it's in Plymouth is some sort of default.
FrontSideBus
11 Feb 2025
I really think we have too much information being fed to us these days. How did we cope before?
styles
7 Dec 2014
Gwynedd
I think there's an argument to say accessibility wasn't a primary concern previously, whereas it should be.
But obviously announcing the wrong doors opening is worse than not announcing them at all.
occone
8 Apr 2023
Manchester
Let's make it 7 pages on a complete non-issue...
How about a generic "doors will open on the platform side" announcement, they way it's always right and needs next to no cost or information around whose left is whose
Baxenden Bank
23 Oct 2013
But only if you press the button, not automatically.
Western Sunset
23 Dec 2014
Wimborne, Dorset
Surely that'd be a pointless announcement, stating the b------- obvious.
