"Doors will open on the left hand side" - whose left?
cats_five
19 Sep 2021
<snip>
As for arrows on signs vs. "left/right" in words, arrows are larger so are clearer in suboptimal conditions. At least an arrow degenerates into a fuzzy blob which is bigger at one end than the other, whereas words just turn into fuzzy blobs. And things on electronic display screens (emissive) are much more likely to turn into fuzzy blobs than things on ordinary signs (reflective).
If there are two arrows that could be illuminated, either side of the centre line, they add that directionality as a clue.
Tester
5 Jul 2020
Watford
Pakenhamtrain
26 Jan 2014
Melbourne, Australia
Starmill
18 May 2012
Bolton
If it is sensitive to facing backwards or forwards, it would be clearer to say doors will open on this side plus an appropriate arrow, although I suppose this wouldn't happen because it would fall foul of accessibility regulations for blind and partially sighted people.
On German trains, next stop announcements are that doors will open on the right or left side in the direction of travel which seems a very sensible solution.
They do omit that part on occasion and just say "please exit on the left". Or the S Bahn sometimes abbreviates it to literally "EXIT LEFT" and it's just assumed you know that it means the part where they say facing the travelling direction.
It is so wonderfully concise, compared to the English equivalent.
Does anyone know any other languages' equivalents that are actually in use?
I've heard "Débarquez la gauche / la droite" in Wallonia.
Unrelated to the above, I think London Overground operate with Correct Side Door Enable don't they? So that should be able to feed 100% accurate information for this system if they provided it.
28 Oct 2017
The dynamic displays will have "Doors are opening this side of train" or Doors are opening other side of the train"
Merseyrail 777 have acquired this in a recent update to their PIS, although the screens are not especially visible in the vestibules (they are a long way above eye line) so many passengers have not yet noticed. These displays are on the sides of the train above the doorways so the wording is unambiguous (and should be very useful on the loop, which is single bore tunnel and the platforms switch sides).
Tester
5 Jul 2020
Watford
And that is the fix.
Nobody needs to know which side the doors will open prior to being in the area of the doors. At that point 'This Side' or 'Other side' unambiguously provides what is needed.
TUC
11 Nov 2010
How does 'this side' or 'other side' at all work as verbal announcements for visually impaired people?
Tester
5 Jul 2020
Watford
In exactly the same way as the signs which started this thread (quoting left and right relative to the orientation of the reader).
Information for visually impaired people by definition cannot be done by visual information, and is done by announcements - this is well established, and is not the subject of the thread.
Left and right relative to the reader isn't applicable to verbal announcements. They either have to be left or right in the direction of travel, or not attempt to announce the side. In that case the visually impaired have to distinguish which side the door opening beep is, or be guided by any other passengers trying to use that door. I think I can tell which side the beep is when standing in the vestibule, but not being visually impaired I've not had to rely on it.
Cell2025
28 Jul 2025
LEEDS
I always assumed within transportation that it means on the left ‘in the direction of travel’.
Three pages in, but for me this is the simple answer. I'd never even considered that there was another way of thinking.
Every day's a school day, even in the holidays!
Ian Hardy
18 Nov 2009
Remember that commonsense isn't that common.
Gaelan
3 Apr 2023
Edinburgh
In Seattle, the (automated!) light rail announcements use the phrasing “exit to my left”. It’s a little goofy but I think it conveys what’s needed quite concisely.
Recessio
4 Aug 2019
Even if it wasn't obvious to someone, once their train has stopped at least once, they'll realise the announcement is in relation to the direction of travel when they see which side the doors open
1955LR
11 Dec 2019
Hereford
I also have never considered the issue. It may be because I have worked in the Auto industry all my working life , where left & right of the vehicle always refers to facing in the forward direction of travel.
Starmill
18 May 2012
Bolton
When the 197s were introduced this confused me because I was waiting to open the door then saw this notice so I darted to another door, only to realise it's not actually an error, despite it being in red and possibly in caps (though my memory in that is hazy).
On Northern trains most regulars have learnt that the 'door not in use' sign lighting up does not mean that the door is not in use. Indeed I have had to reassure people several times that just because there's a door not in use sign on it certainly doesn't mean that the door isn't in use.
As I'm sure you can understand it's led to people missing their stop on other types of train because they assumed, quite sensibly, that the door not in use sign didn't mean that the door wasn't in use.
On a CAF train, if the door is actually not in use, the green button will light up red in addition to the door not in use sign. Presumably that's something everyone is meant to know telepathically...
It doesn't (or shouldn't) display at multi-platform stations, as it has no way of knowing which platform the train will arrive at.
In practice it's very difficult to determine what drives it, if it's the door release or something else related to it. It seems almost random when it does and doesn't show. Perhaps it's different on different units for all I know. At some other operators the driver has to enter the platform number which seems utterly bananas to me.
S101
7 Dec 2025
West Yorkshire
So I just noticed this on a Transport for Wales service.
I am travelling in a backwards facing seat. On the wall at the rear of the carriage is an electronic display.
As we approach stations, it will say, "Doors will open on the left-hand side". This is your left-hand as you face the screen which means the left side when looking towards the rear of the train.
Either this is a fault, or the side it says doors open on is dependent upon whether the screen you're looking at means you're looking at the front of the train or the rear.
Assuming it's not a fault (because I'd expect all the station info to be wrong also), to me this doesn't make sense. Consider for a moment that TfW might decide, like TfL do on some Tube services, to put it out over the public address system - you wouldn't be able to do this unless you made sure only to have screens facing one direction within each carriage.
Surely logic dictates that left hand side or right hand side is relative to forward direction of the train? Or am I going mad? Or is this just a fault and I can stop questioning life?
In direction of travel, surely....
tfw756rider
30 Nov 2024
Wales (sometimes in England), thanks for replying!
Missing their stop because they assumed that the sign meant that the door wasn't in use, surely? (or didn't mean that it was)
JamesT
25 Feb 2015
It would never have occurred to me to expect anything else! Nor to most people, surely, because a moment's thought would show that passengers are seated facing both ways so the doors cannot possibly open on everyone's left.
But this thread all started off with displays in the carriages. Left or right relative to the display makes the most sense as that's the direction the passenger is facing.
Starmill
18 May 2012
Bolton
No. Usually the sign saying the door isn't in use doesn't mean you can't use that door. That's the problem I'm trying to call attention to.
Russel
30 Jun 2022
Lichfield
That doesn't make sense at all, as soon as the passenger stands up, picks up luggage etc, they could be facing a different direction....
Direction of travel works universally, why add in any layer of complexity?
rmHawk765
8 Apr 2025
ECML South
Transport for london announcement says " Doors will open on the -------- side in the direction of travel" I believe.
They don't explicitly mention the part about direction of travel, but it is indeed the left/right in the direction of travel, as surely makes most sense.
JamesT
25 Feb 2015
You see a sign that looks like:
<——- Doors opening on the right
Is that not more confusing?
Is it too much to expect that someone will remember which side the arrow was pointing at?
Ethano92
26 Jun 2017
But if they were, the screens facing the opposite direction will still having arrows point to the same side of the train, just with the word ‘left’ or ‘right’ switched.
NCT
18 Apr 2025
Where an arrow display is used, the overall display should purely be visual.
PeterC
29 Sep 2014
Same here but there is always somebody who will manage misunderstand the simplest instruction.
tfw756rider
30 Nov 2024
Oh, now I get you. The "other types of train" part hadn't sunk in.
