Class 455 with AC Motors
TEW
16 May 2008
It does tend to, yes. It normally feels as if the AC unit is pushing or pulling the DC unit or 456s, so you feel the different units crashing into each other as they pull away from stations or brake.
Keith Jarrett
10 Aug 2010
No longer in London
I also ran into 5703+5722 yesterday evening - both those were retractioned. So with the other reports above, that leaves 5702, 5704, 5710, 5712, 5717, 5718, 5730 & 5739 still to be done (unless anyone knows better)
43096
23 Nov 2015
5730/39 are both done.
Keith Jarrett
10 Aug 2010
No longer in London
Picked up 5702 with shiny Vossloh boxes last night (14th February).
That leaves according to my records, only 5704, 5710, 5712 & 5717 of the 57xx units still to be done.
Class455
19 May 2016
Then they'll probably switch their attention to the 455/8's.
TEW
16 May 2008
Working 5712 this evening with AC Traction equipment fitted.
TEW
16 May 2008
And now also working 5704 which has AC equipment. So that's just 5710 and 5717 not seen with AC equipment of the 57xx series.
Class455
19 May 2016
Anyone know which unit has taken the place of 914 at Vossloh?
Class455
19 May 2016
5914 becomes the 3rd member of the 455/9 sub class to be retractioned. Noted yesterday on 17:12 ex Waterloo
Also I'm pretty sure other 455/9's have been done, 455 904 and 455 915/16 have been done (I think)
TEW
16 May 2008
5903 also in traffic with AC Motors this evening.
Class455
19 May 2016
455871 has returned from Overhaul at Bournemouth. I believe 455 869 is there at the moment as I haven't seen it in a while.
Has the exact reason for the contractors moving their workplace from Eastleigh TRSMD to Eastleigh Works ever been made known?
TEW
16 May 2008
Wasn't the original plan to do most the units at Wimbledon Park Depot, after the first few were done at Eastleigh?
I read the opposite initially, that the few trial units would be done at Wimbledon and then the production line would be set up at Eastleigh, in the TRSMD.
A couple of posters were emphatic that it would be the TRSMD rather than the works, which is why I was surprised by the move across the road half way through the project..
Class455
19 May 2016
455 908 now with AC motors, while 455 869 has been overhauled.
Roast Veg
28 Oct 2016
So with today's announcement confirming the replacement of these units (which was already believed to be true upthread), what could be the plan for them? Will they go to Southern, or will Vossloh take back the motors for retractioning other stock when they are retired instead?
Class455
19 May 2016
Think the 455/8's and maybe the 456's will most likely end up at Southern Not sure about the rest. But if Southern need extra stock (which they do), then these are now available to take.
GW43125
8 Dec 2014
It surprises me they want to replace these given how much has just been spent on retractioning them.
I think that Southern don't need extra stock, as a number of their current routes get subsumed into Thameslink and that releases 377s for the rest of their remaining routes.
Taking on SWT's 455s has been ruled out by TSGN insiders quite a few times before now, even when people suggested using them vice 313s on the coastways...
D365
29 Jun 2012
I think the suggestion is that Southern replace theirs with units that have received the AC traction package.
Domh245
6 Apr 2013
nowhere
But there won't be many 455s needed post Thameslink changes, which will come before the point at which any SWT 455s get released. It doesn't make much sense either to use the SWT 455s in place of the southern ones as there will be plenty of parts available for them and it avoids the need for any works needed (eg retrofitting door controls to driving panel, digital destination display, etc) and other training costs.
Yes, but I was attempting to respond more to the point about SN allegedly needing more trains generally, which I just don't see being reasonable...
Class455
19 May 2016
What I was thinking was there could be more 455's at Southern to extend all current 455 diagrams to 8 cars (maybe even some 12 cars at peaks but that will require an OBS) as well as possibly cascading 377/3's to the coast to replace the 313's.
Also, there's about 27 455/8's at SWT, and plenty of 4 car 455 diagrams at Southern, so it would seem pretty logical.
