Class 185 refurbishment for TPE.
ash39
8 Feb 2012
185132 has been done, so we are now looking at this:
185101, 185102, 185103, 185104, 185105, 185106, 185107, 185108, 185109, 185110, 185111, 185112, 185113, 185114, 185115, 185116, 185117, 185118, 185119, 185120, 185121, 185122, 185123, 185124, 185125, 185126, 185127, 185128, 185129, 185130, 185131, 185132, 185133, 185134, 185135, 185136, 185137, 185138, 185139, 185140, 185141, 185142, 185143, 185144, 185145, 185146, 185147, 185148, 185149, 185150, 185151.
185145 is definitely in the old livery as it was working a Liverpool to Scarborough service yesterday with 185109 (which is a repainted unit).
126 is also still old livery, just seen at Oxford Rd
IanXC
Emeritus Moderator
18 Dec 2009
Much as I think there is a bit of a build quality issue at times, Turbostars are quite a bit cheaper, would have been more useful for cascading to other TOCs, have a better interior layout with excellent window alignment, are more fuel efficient and can use SP differentials. I would suggest they should actually have ordered (at least some) 4-car Turbostars instead of 3-car 185s.
Siemens no doubt cut costs to get in on the bid (hence the design issues), but I personally think they made the wrong economies in doing so.
So having worked out that they could come up with a potentially winning design for the TP DMU, you're saying Siemens should have thrown up their hands and said they're not going to because a Turbostar 'would be better'? I'm sorry but you're clearly living on another planet.
Fudgefrog
10 Feb 2009
Would 170s have been powerful enough on the steeper Pennine climbs to match the speed and acceleration of the 185s, though?
It's worth remembering that the eco mode enabled a few years after introduction reduces fuel consumption quite a bit by effectively switching an engine off when it isn't needed. It'll also be interesting to see if the trains are judged to be better when new engines are fitted.
I personally don't see an issue with the windows. The only legitimate problems with them came down to spec - too short.
BMIFlyer
13 Mar 2017
The class 170 on two engines was slow up the hill from Huddersfield to Marsden. On one engine they were utterly shambolic and were mostly caped at Huddersfield or Stalybridge due to the performance issue in that respect.
From a standing start the class 170s weren't much better than a class 158, when TPE had both fleets for a period before the 185's arrived.
No, I'm saying that TPE selected the wrong bidder, or possibly set their criteria wrongly.
BMIFlyer
13 Mar 2017
185101 will be in traffic on Monday. Unable to confirm the diagram yet however.
Next unit for the internal refurbishment is 185150.
gimmea50anyday
8 Jan 2013
Back Cab
So if we caped 170s due to the performance over marsden why do we send single engined 185s across the hills?
BMIFlyer
13 Mar 2017
Because they can make it over the hills to (usually) return to Ardwick or York.
The 170 engines are awful power wise in comparison, running a unit on single engine over the hills usually made it overheat, hence why on occasion you would end up seeing the errant unit coupled up to a working unit - 3 engines ok out of 4 was doable.
The 170 didn't have the advantage of electrical cross feed so you would lose either head or tail lamps depending on which engine died if you let a single unit work on one engine only. Hence why they were fitted with an emergency headlamp in the tool cupboard.
BMIFlyer
13 Mar 2017
It'd be funny if it ends up on a Blackpool diagram!
Shouldn't happen, as it will commence its working from York. I should probably think it will be on a York to Airport shuttle diagram or attached to another unit and sent to Liverpool.
Philip
27 May 2007
Manchester
Just had a look at TRUST; the 185 booked to work the first Blackpool (05:27 from the Airport) starts off from York depot and works the 02:52 from there to the Airport. Perhaps they will deliberately not diagram it for this working, although I seem to remember 185108 ended up on a Blackpool working rather soon after it had been unveiled in silver.
BMIFlyer
13 Mar 2017
Yep, sorry I should have stated hopefully it will not be allocated onto a crossover diagram. I know that those in HQ are keen to showcase it on the main TPE network this week. So...
ValleyLines142
25 Jul 2011
Gloucester
This goes back to what I mentioned in Post #298, where photos of supposedly revinyled units have been uploaded but it isn't actually those units!
So, pending all uploads are accurate, we should be as follows:
Philip
27 May 2007
Manchester
My call that '110 would be the final unit to be done still looks on! It'll be in the vinyl shop next week now that I've said this...
TC60054
3 Mar 2016
Doncaster
The only time that I personally have seen a 185 running on only one engine, it was on a Hull service that was "looped" at Marsden to let the Liverpool past, terminated at Huddersfield and given a helping hand by the ex-Middlesbrough service behind it through to Piccadilly so that it could return to Ardwick.
IanXC
Emeritus Moderator
18 Dec 2009
So the claim changes yet again eh!
As has been said by a number of people these units are eminently suitable for the route and are performing exactly as intended on a challenging route.
The fact that you don't like them is neither here nor there, and the sooner you accept that the better!
gimmea50anyday
8 Jan 2013
Back Cab
Had one a few weeks ago. Wet and slippery tracks as it was raining on a 2 engined unit which drops to one at Guide bridge. Managed to get second engine fired up on the curve but had conked out again at stalybridge. "Keep going" came the call from control so up towards Diggle we went. 30mph we struggled to reach until inside standedge some 10 mins late. After that with the downhill run to Huddersfield she moved like the proverb until the second climb to morley tunnel lost a further 5 minutes and the service was caped at York.
Managed to push a 185 up to 88mph with just the rear engine on the ECML one new year's day. Came off York with 3 engines, lost one at thirsk and the second died at Thornaby on the way back - both no coolant. F&S out of Yarm we slipped and struggled up the bank into Northallerton where I disgorged the punters on to the following EC service just in case the final engine gave up. No flux capacitor was fitted but you could feel the heat coming through the saloon floor from that effort!
Blindtraveler
28 Feb 2011
Makes you wonder if empty with akl 3 engines and a streight run what sort of speed they could do?
driver9000
13 Jan 2008
For those interested 185101 is out in service today and currently working 05:54 Middlesbrough to Manchester Airport due in at 08:40 which is then booked to work 08:55 to Cleethorpes.
