Class 139 at Stourbridge
aal7
16 Oct 2013
Do both 139's fit in the shed at Stourbridge Junction? How do they swap them over when one breaks down - it looks like a single track.
driver9000
13 Jan 2008
I'm not sure if they both fit in the shed but the units are swapped over using a small headshunt just outside Stourbridge Junction station.
Crossover
4 Jun 2009
Yes I'm pretty sure they can both fit in the shed. As said above they use a headshunt to swap them, in front of the signal box (if that's still there?) - actually the connection to the mainline...you'll see a limit of shunt sign on it
FQ
Quizmaster
4 Oct 2013
I have a question.
Can you see both from Stourbridge Junction station if one is at Stourbridge Jcn on the Stourbridge town shuttle and the other is in the shed?
Alistair G.
16 Jun 2013
Leicester
No, when one of the units is out the other stays tucked away and the shed door closed. Failing a break down I believe they get swapped once a week on a Sunday morning, that will be the only time both are out
Shed is really the literal word for it, it looks like something bought from B&Q....
FQ
Quizmaster
4 Oct 2013
Thanks!
bb21
Emeritus Moderator
4 Feb 2010
Yes, Sunday morning is when they are swapped over, according to a driver.
6Gman
1 May 2012
Surely they just get a bloke on each corner to lift them on and off?
:D
61653 HTAFC
18 Dec 2012
Another 139 query here...
If ever there was some sort of event in Stourbridge town centre, would it be possible to run both 139s in multiple? (assuming that any checks and repairs on the spare unit had been carried out).
FQ
Quizmaster
4 Oct 2013
I guess they will have to be able to work in multi, in cast one of them failed at Stourbridge Jcn.
Crossover
4 Jun 2009
I'm not sure it'll be permitted - looking at the front at them it wouldn't surprise me if "multiple working" consisted of dumping a bolt through the eye on the front bracket of the unit. Cannot see anything that would allow through connections for power etc. Maybe someone can advise, though
Also, a few pics I have found on the web
Shed shot
PPM Rescue (literally the only picture I can find of them coupled up - and it is from 2010!)
Changover time!
455driver
10 May 2010
Um no!
Why does a rescue train have to be able to multi up with whatever it is rescuing?
All they have to be able to do is physically be able to attach to each other, no air or electrical supply required, there are lots of rules and regs to follow but thats easy enough!
I doubt they can work in multi and if one of them had failed then it certainly wouldn't. I imagine one unit can haul the other one dead if necessary.
WatcherZero
25 Feb 2010
Yes think they can rescue, don't think they have the connections for multiple.
WestRiding
21 Mar 2012
Do 'real' trains still ever use the branch in place of the PPM's? Is the link still maintained to the national network even?
ANDYS
21 Feb 2011
Chesterfield, Derbyshire
I have to disagree with earlier replies. The 139's can sometimes be seen out together. Me and my son were there on 28th October (a Tuesday) and 139001 was running up and down the branch. When we got back up to Stourbridge Jcn 139002 had come out of the shed and was parked in the platform. My son was desperate to get to Stafford so we did not stay for long but 001 was still plying up and down when we left.
Have a look at the photos
photolist-pULc1P-pCnKay-pUzWSz-pCsJxG
or have a look here:-
https://www.flickr.com/photos/66737297@N06/15693285435/in/photolist-pULc1P-pCnKay-pUzWSz-pCsJxG
Andy S
The link hasnt been taken out though AFAIK. If it was going to have been it would have been done under Stourbridge resignaing.
185143
3 Mar 2013
I can confirm 139002 is on the branch today.
Source-travelled on the 11:55 lol
Crossover
4 Jun 2009
How were the 139s delivered originally? By road and then craned in? Did they come by rail from the main line?
Craned in I believe - from pics I have seen it was done at the town end
Maybe it is just me but I'd love the chance to thrash one on a mainline!
bb21
Emeritus Moderator
4 Feb 2010
I wouldn't call that buzzing sound a "thrash".
