XC HST
27 Jan 2006
I presume XC are using Trolley's any idea of how they are working? They the same design at FTPE's new ones?
me123
9 Jul 2007
I think they are using trolleys (couldn't tell you which type) but on the NXEC hire-outs, they're also using the buffet.
P156KWJ
26 Nov 2007
Nottinghamshire
I went on the EMT set on 9V57 today and it was an old VT trolley, no buffet at all, all SO and FO coaches.
also, anyone know why after sheffield the service was diverted back north on to the freight-only barrow hill loop, to chesterfield, was worried i was on the wrong train :shock: was a mystery tour though :)
37402
15 May 2007
"We are sorry, but the trolley is unable to travel through the train today, please fight your own way down to First Class at the other end of the train to make your purchases."
XC (or rather DaFT who are pulling the strings) have decided that it is too expensive to offer food and drink so have dressed it up as "the survey says that people want it brought to them". So it's goodbye to the buffet cars in both the HSTs and shops in the Voyagers, goodbye to hot food and goodbye to chilled food and drinks. Probably better to bring your own food when travelling with XC from now on...
27 Jan 2006
I bet the catering staff are loving heaving a trolley upand down a busy train whilst they are usually cosy in their shop! Not for much longer...The old VT trolleys cant hold much...i see a problem coming...
P156KWJ
26 Nov 2007
Nottinghamshire
yes they're rubbish, I use one for when I'm doing the catering at the GCRN (it's an old virgin one too) and all they have is 2 baskets on the front (which I use one for displaying snacks on offer and the other for tea/coffee/hot chocolate making stuff like spoons, the cup dispensers, a tap, water boiler and plumbing, and the baskets below where I actually give the people their products (I'm anal on how I display things and hate it when someone just takes something like a bag of crisps that's on display :lol:
you'd be suprised that one of those trolleys with the water boiler and pipework is worth about £4-500 :shock:
Techniquest
19 Jun 2005
Nowhere Heath
The trolleys on XC HSTs aren't up to the job as they just don't hold bugger all. Practically empty on 9S66 last Friday up to Bristol, where they loaded up a bit and got all of 3 sandwiches to last to Brum. They were gone by Cam and Dursley. Cue a call to Rail Gourmet for them to get more on. Dodgy trolleys too, which had problems circumnavigating the end of the train and refused to reverse at one point! Then there's the difficulty in having enough hot water to keep a train full of passengers going, and having no cold drinks annoyed my endlessly on 9V57 on the same day. Putting up with rather warm Coke was not part of my plan, but the weather causing problems put a stop to a Spar move!
Quite simply, I believe the trolley service is an absolutely awful idea.
Did 9S66 and 9V57 from Tiverton Parkway to Cheltenham Spa and Cheltenham Spa to Tiverton Parkway respectively last Friday. 007 and 184 were, quite simply, monsters. I'll not soon forget the very lively departure of 9S66 from Cheltenham. The sound on the video is nowhere near as good as the real thing was, but it gives you a damn good idea. Mind, he was 28 minutes late by that point.
You should have asked the friendly guard! He said the radio had failed on the leading cab so they had to run it round. He said it would be fixed in Penzance tonight. (he'd better be right.. ;) I am posting this from a loft conversion thanks to someone kindly allowing access to their wifi in Penzance, providing the laptop is next to the window I just about get a signal!)
I am going to be on it Camborne to Bristol Temple Meads this Friday, will be in TGS.
you need to be at the rear then as the set got turned round. will look out for you!
BlueGrey
23 May 2008
Does anybody know what kind of MTU engines (I thought I saw somewhere there are more than one type) are going to be on the XC refurbished PCs? Are they likely to make any noise at all?
5872
28 Jan 2007
A6-EHF
If its the same as FGW and NXEC, expect no thrash :grin: :roll: <(
theblackwatch
15 Feb 2006
You must get your ears checked - I've been linesiding recently and can hear the NXEC ones approaching from some 1/2 mile to mile away.
Max
8 Jun 2005
Cambridge
They are quite noisy at high speeds, but it's just when they accelerate from low speeds that you can barely hear anything.
class 313
10 Dec 2005
St Albans
VP185s are a bit of both, the rumble of the MTU and the scream (at higher speeds) of a Valenta.
Techniquest
19 Jun 2005
Nowhere Heath
Indeed. Its all froth when people say MTUs make no noise - they do!
I was recently(ish) heard to be saying:
"Who the f**k said MTUs were quiet, eh?"
(this being as 43040 was idling on the rear of a service to Paddington at Bristol TM)
Some MTUs are rather noisy, 071 being one of my favourites on that front. Then again, some are absolutely awful, like 309.
Put a good driver up front and he will make those MTUs perform properly. Quiet? I don't believe it. Quieter, yes, but not silent!
voyagerdude220
13 Oct 2005
So is the Saturday 09:40 Newcastle-Newquay always going to be an XC/ ex MML set, and if so, is it always going to be non-MTU HST power cars?
Are any of the services definately going to be formed of a double non-MTU powered set?
Also, did yesterday's 1V29/1M28 have the MTU at the Standard Class, or First Class end? Does anyone know what the fault was with the train yesterday morning, causing it to be 20 late off the Picc?
Thanks in advance for any info...
They will be MTUd some time this Summer. No-one seems to know when but 'get them while you can' applies if you want Valentas!
Techniquest
19 Jun 2005
Nowhere Heath
With "sometime in June" being the quote going round t'internet at the moment. I'd personally guess that we have approximately...3 weeks left of totally Valenta-fitted HSTs on XC.
djw1981
10 Jul 2007
So its taking about 6 weeks to do each pair? How about the carraige refurb? I assume that we could end up with MTU'd PC pulling the unrefurb stock for a bit - some more 'mix n match' liveries at EC!
Techniquest
19 Jun 2005
Nowhere Heath
I would imagine that to be the case. We shall have to wait and see.
In the meantime, I'm back to planning desperate moves to get a pair of Valentas out of Glasgow!
Jim
11 Jun 2005
Wick
43290 with a good bloke up the front, did start to challenge some SPM driven Valentas, last summer!
