Wigan-Bolton services after electrification?
darylyates17
8 Nov 2015
St Helens
Am I right in thinking the Southport services will go via Atherton instead of Bolton once the timetables change?
GhostManDN91
2 Oct 2022
Wigan
From what I've heard it might be a Blackburn and Manchester Oxford Road to Southport via Atherton from May timetable change but I'm not sure of the official plans though.
cle
17 Nov 2010
What is the long term plan for the line, just the 2tph Wigan NW - Stalybridge EMU?
Or could more tph turn at Wigan, or something run onwards towards Preston also?
childwallblues
3 Jul 2014
Liverpool, UK
Northern currently can't even run two trains per hour Liverpool -Newton-le-Willows without having to find additional staff to run an additional service north of Wigan.
GhostManDN91
2 Oct 2022
Wigan
Will confuse alot of passengers at Wigan when all the Bolton trains switch to North Western I'll imagine.
DAL1189
4 Feb 2024
Manchester
Walkden is my local station and I was just checking Real Time Trains to see what was passing by this time of night and lo and behold - https://www.realtimetrains.co.uk/service/gb-nr:G33437/2025-01-03#allox_id=0
Don't know if this is a regular service but this train apparently is running all the way to Southport!
pokemonsuper9
20 Dec 2022
Greater Manchester
Gricer99
21 Jun 2020
Hindley
It would make sense to run Southport and Kirkby services to Manchester and beyond via Atherton and run the Leeds and Stalybridge services fully electrically via Bolton. That leaves the hourly service to Oxford Road (or hopefully extended to the Airport) as the big question mark. Would they dare to swap one of the half hourly Blackpool Airport services for a Wigan NW service?
Manutd1999
21 Feb 2021
2ph Wigan-Stalybridge seems a sensible long-term solution. 3ph Southport/Kirkby DNUs would then run to Rochdale or elsewhere via the Calder Valley.
The spanner in the works is Southport's vocal desire for a Castlefield link, which means an Oxford Rd shuttle could be kept as a compromise....
Gricer99
21 Jun 2020
Hindley
I can't see there being 5 tbh. My guess is the Leeds Wigan 158s will be extended to Southport and the Blackburn Calder Valley service might alternate between Kirkby and Southport. A lot depends on how reliable they can make the 769s.
pokemonsuper9
20 Dec 2022
Greater Manchester
The Northern 158 fleet is already maxed out is it not? Would mean needing other DMUs to support.
As unreliable as they are, the 769s wound be displaced by this and could run #8's Rochdale-Southport.
If 6 of 8 769s were reliable enough you could probably have that service exclusively 769s, since it's just under a 5 hour round trip.
Gricer99
21 Jun 2020
Hindley
Just a thought- why cant they run an extra Blackpool to Man Airport service via WCML, WNW and Bolton?
Gricer99
21 Jun 2020
Hindley
But if you could run one of the Blackpool to Manchester Airport trains via Wigan and Bolton you have the same capacity.
AMD
6 Dec 2017
But how are you going to keep the same number of stops for Horwich and Chorley? Other than reinstating the Vic to Preston stopper.
jonnyfan
6 Apr 2013
Manchester
From what I have read in various posts on these forums I think the service plan proposed is something like:
1 TPH Wigan North Western - Bolton - Stalybridge (323s)
1 TPH Southport - Bolton - Oxford Road (769s)
1 TPH Southport - Atherton - Victoria (diesel stock/maybe 769s)
1 TPH Headbolt Lane - Atherton - Victoria - Rochdale - Blackburn (diesel stock)
The hourly Wigan - Victoria - Leeds will change to Salford Central - Victoria - Leeds, using the new turnback facility being built near Salford Central.
cle
17 Nov 2010
That should happen regardless.
Do we know when Rochdale is due to be wired? Is that the next section (other than TRU) ?
Maybe taking up Huddersfield stoppers is another S bahn-esque route for some of these services to run through Vic, like the aforementioned Preston EMU stopper.
Halish Railway
26 Apr 2017
West Yorkshire / Birmingham
So 2tph via Bolton and Atherton. Pre-May 2018 there was 3 tph via Bolton; One from Huddersfield/to Stalybridge to Wigan Wallgate, one from Blackburn via Todmorden to Wigan Wallgate doing the stops between Salford Crescent and Bolton and one from Manchester Airport to Southport.
The Atherton services came from Kirkby and Southport.
Knowing this and with the third platform at Salford Crescent I think three trains per hour via Bolton should be possible, with one Southport to Manchester Airport service would by Sprinters and 769s and 2tph Wigan Northwestern to Stalybridge, all calling at the intermediate stations between Bolton and Salford Crescent, worked by 323s.
Farigiraf
23 Jul 2023
Bridge on the River Cam
Which of these services would have the parliamentary Clifton stop twice a day?
507020
23 May 2021
Southport
If this is correct, what does it mean for Southport - Bolton, 769s to Blackburn, the Wigan North Western - Stalybridge Sunday service and Headbolt Lane services?
Northern’s point blank refusal to alter the holy MRTF Option B+ timetable despite it being completely unfit for purpose, offering no connectivity or flexibility for electrification work that was planned still doesn’t mean they should run anything as unambitious as this.
pokemonsuper9
20 Dec 2022
Greater Manchester
769s to Blackburn
Would this be on the Rochdale - Blackburn via Bolton services?
It does seem like a decent place to send them next, but one failing to move to diesel (as one did on Monday) at Bolton would be much worse than when one sets down in P5, as P1 is used much more frequently (and the backup is the also busy P3).
I don't see why that'd be impacted, if anything that might turn to EMU first if they're ready a bit before timetable change? (very big question mark on that one though, since the trains would probably need different ECS paths to depots/sidings)
Change at Hindley, it could probably be timetabled to be a quick connection.
Personally I'd be a big fan of 3tph on the Atherton line, but pretty much everything here is speculation, they could run it as a shuttle to Wigan (although that'd probably need 2 units due to otherwise having very tight timings).
themiller
4 Dec 2011
Cumbria, UK
What’s the problem with 769s not changing mode? Thameslink services change mode on much busier tracks daily and TGVs change from ac to dc and vice versa. Can Northern maintenance teams not sort the problems on what are relatively ‘agricultural‘ units.
