What is this?
yoyothehobo
21 Aug 2015
I dont know what the yellow things are, but at least there is a datum plate in the photo for forum consistency...
Northampton
Axle counters?
Pat
They don't appear to be connected to a trackside cabinet though, and they're underneath the head of the rail so would they be able to register the changing field?
I note that track is very rusty, even if it looks to be in good condition otherwise. Are they perhaps clearance point markers for a shunt neck or yard entrance? The angle of the photo is not clear but the tracks appear to be converging.
I also wondered about the lack of any obvious cabling. They do look a bit like the yellow Frauscher axle counter detector heads at first glance, but they‘d always come with pretty obvious wiring and securing brackets.
SargeNpton
19 Nov 2018
New rails, sleepers and fixings. Wonder if they are used in conjunction with a tamper or consolidator?
I was ready to type "datum plate" before the photo even loaded. :)
Is it perspective, or is there something 'odd' about the sleepers? They don't seem to line up properly either side of the rails.
SargeNpton
19 Nov 2018
I think it; because some of the sleeper ends are covered by the fresh ballast.
Spartacus
25 Aug 2009
I'm wondering if it's some sort of wireless early warning device for someone working down the line, which would avoid the complications that placing dets could have? No doubt someone will know, but they're new to me.
AndrewE
9 Nov 2015
Maybe installed now, but to be connectd up in a few weeks' time? (whatever they are!)
carlos118
12 May 2016
They are not axle counters but are installed about 5-10 meters away from some...they are also covered in this black grease it looks like but the axle counter does not have any on it. This was on the crossrail line if it helps.
carlos118
12 May 2016
Which axle counters are these? They look similar to the wireless axle counters but not the same from what i have seen before
Hellzapoppin
16 Jan 2016
There's a YouTube vid showing how they work. The channel is RSS Infrastructure.
Think it's Critical Rail Thermometer monitor 300??
