Unusual delay reason shown on departure board
johnr57
29 Mar 2013
Seen at York this morning - any ideas what happened?
Image shows delay reason "Due to a coach becoming uncoupled on a train"
Coach uncoupled!
John
Geeves
6 Jan 2009
Rochdale
I don't think on the Ketech system there's a delay reason for detaching a part of the train so you could use it at a push!
skyhigh
14 Sep 2014
So what was the issue then?
A freight train divided, I don't know how or why so I won't speculate on that.
i've re-worded it slightly.
You don't just press the uncouple button 'by accident'. To accidentally uncouple you'd need to go into the coupled cab, key in, cancel the AWS, set the desk up correctly and then press the uncouple button (and on modern units such as 195s and I suspect 80x the train will automatically recouple if not moved apart a certain amount of time since they were uncoupled). You don't just accidentally push a button from the front cab and leave a unit behind on the move!
Geeves
6 Jan 2009
Rochdale
On a 195 once the button is pressed even if the trains stay together they won't move again (together) till the full recoupling process has been completed. Computer says no. :)
LowLevel
26 Oct 2013
A freight train split into several sections north of Peterborough causing one line to be shut and some delays whilst it was rectified.
Not common nowadays, but freight trains dividing unexpectedly have been a thing since the railways began - the main thing is that the portions come to a stand safely, which they did - unlike the bad old days of loose coupled trains without a continuous brake which could quite easily run away.
skyhigh
14 Sep 2014
Thanks for the clarification. I was definitely told they recouple but not to let it happen as it upsets the computer... either way you're not accidentally leaving coaches behind!
Geeves
6 Jan 2009
Rochdale
Like you say the only way things are getting left behind is someone forgets to actually couple the sets or isn't told, that wouldn't be the first time ha! It's usually the other way round where stuff isn't detached and then suddenly at departure time of the xx:05 you're minus a train! Woops
Intercity110
31 Jul 2022
64Mi 64Ch (Approximately)
thanks for letting me know, as i’m not in the railway industry, i had no idea that was how (my only idea was from an Old wessex traind training video fpr 153s uploaded onto youtube)
Future
28 Nov 2021
Devon
Train involved was 6E30 0212 Ripple Lane West SS - Tinsley SS. Ended up running 190-ish late once resolved.
Poor excuse.
"a freight train becoming uncoupled" (for example) is no longer.
But I don’t know if that’s one of the auto-populated reasons available to whoever is operating that PIS. It might not be their fault. It’s still better than “operational incident”!
sheff1
24 Dec 2009
Sheffield
If it isn't, it should be - I would think a freight train uncoupling is a more likely occurrence than a passenger train doing so.
Northampton
The delay code will probably be something like 'train divided', because fundamentally from an operational POV there's no real difference between a passenger or a freight train dividing.
sheff1
24 Dec 2009
Sheffield
In which case, Train becoming divided (or uncoupled) would be fine as an accurate reason on the PIS
Northampton
Indeed, but in this case the PIS was set (whether manually or by default) to replace it with a message that sounds potentially a little less dramatic.
Rescars
25 May 2021
In a past era, especially with unfitted freights, hearing the bell code for "train divided" would be bad news enough for a signaller, but not as alarming as " train running away on right line", or worse still "train running away on wrong line". Not something which would have been made known to the travelling public I'd guess, even if there had been a system which was capable of doing so.
Scott1
29 Apr 2015
More options means more work to find the right one, it's a balance.
TT-ONR-NRN
30 Dec 2016
Cambridge
Poor excuse.
“Poor excuse”
You’re wording it as if it’s a serious matter. Whether they’ve said carriages or coaches, or sections or parts, you get the gist of what its saying and that’s what matters.
kacper
27 May 2022
honourable mention
Parallel
9 Dec 2013
Did that take a few goes to get the timing exactly right, or is it from a video? :D
That one will be ‘an unusually large passenger flow’, it’s just the word ‘flow’ has been cut off.
Most TOCs are using newer delay reasons with the equivalent reason for this being ‘overcrowding’.
