Trivia: Services calling twice at the same station
Bill57p9
1 Dec 2019
Ayrshire
This thread got me thinking: which passenger services call at the same station more than once, excluding services which circle back to where they came (e.g. Fife Circle, Dartford loop, Wirral lines)?
The only current one I can think of is Far North with Georgemas Junction.
Back in the 90s Cross Country had southbound services from Edinburgh using the WCML that ran via Glasgow Central and called at Motherwell twice.
No doubt Haymarket has had some double calls in the past for WCML to Aberdeen services.
Any others?
joncombe
6 Nov 2016
I think Southern trains that run into Eastbourne and continue to Hastings callat Hampden Park twice.
Ken H
11 Nov 2018
N Yorks
Back in the day Skipton - Leeds trains would come off the main line to call at the present plat 5. The driver would change ends and the guard would go in the cab at the bradford end. He would use bell signals to tell the driver to set back onto the line to Bradford to what was then Shipley Bradford Junction, now Shipley South Junction. Once the signals cleared, he would then go back to go through platform 3 and on to Leeds. Sometime he would stop there, other times he would just run straight through.
Of course it was all absolute block then, classic DMU and no platforms 1 & 2
But about half of the time the train would stop at Shipley twice.
Wilts Wanderer
21 Nov 2016
There used to be a Gunnislake to Liskeard stopping service that called at the local halts between St Budeaux and Plymouth twice. It was also the only direct service between the two St Budeaux stations, for which a (rover) ticket could be purchased for the princely sum of £13! A better alternative would be to simply cross the road on foot. The fare was withdrawn once discovered I believe.
Further back in time, the IC CrossCountry ‘Devonian’ ran to Plymouth via Paignton and therefore called at Newton Abbot and Torquay twice. It was much quicker to change onto a Paddington-Plymouth service than to travel through, which I imagine was planned for unit balancing purposes only.
Old Yard Dog
21 Aug 2011
Many years ago, there used to be a Leeds - Shipley - Bradford FS (rev) - Shipley - Morecambe working which I think ran on summer Sundays only
IanD
18 Sep 2011
Newport Pagnell
Also there was a Sunday service (maybe up to 2017) from Lancaster to Leeds via Morecambe which called at Bare Lane twice, plus a similar service Monday-Friday
greaterwest
23 Nov 2014
If this includes services altered because of engineering works, SWR London Waterloo to Reading via Weybridge services will make two passenger stops at Virginia Water, one on the Chertsey side and one on the Reading side as the train has to shunt between lines there.
Ken H
11 Nov 2018
N Yorks
here you go, look for 0948 from Leeds top right.
March 78 BRPTT
Bill57p9
1 Dec 2019
Ayrshire
Thanks for the nominations.
I should have thought of the Devonian as I mentioned the overnight version on the other thread.
dastocks
3 Nov 2021
Hove
Hounslow loop services call at stations between Waterloo and Barnes (inclusive) twice.
30907
Neither thread (I checked!) has mentioned the one-time 0102 Blackfriars-Orpington via Bromley North which - in the days of my not-very-misspent youth - called twice at Grove Park. The move is no longer possible.
Eccles1983
4 Sep 2016
Merseyrail wirral line services call at james street and hamilton square twice in the same service.
bristollh
29 Sep 2019
Warrington
Circa 20 years ago, there was a Transpennine service Mon-Sat that ran Manchester Airport (1730 ish) - Middlesbrough (2020 ish) before continuing up the coast to Newcastle, calling at Thornaby twice. IIRC there was an equivalent morning service in the opposite direction, too.
Jeff
nw12398
19 Dec 2021
Devon, United Kingdom
Salisbury to Romsey SWR services I think
Yes, starting at Romsey they go clockwise towards Chandler's Ford and Eastleigh and all stations in Southampton west of the Itchen. After Redbridge they continue north to get complete a loop at Romsey, after which they go to Salisbury. After Salisbury they go back the same way that they came - back to Romsey and anticlockwise to Romsey again. At Romsey, clockwise trains have a stated destination of Redbridge - i.e. one stop before it gets back to Romsey - despite being the long way to Romsey. Similarly, anticlockwise trains at Romsey have a stated destination of Chandler's Ford.
BoroAndy
11 Jan 2020
Scarborough
In the early days of TPE, the first train from Scarborough in the morning started in Filey, so went FLY-SMR-SCA-SMR.....
Taunton
1 Aug 2013
Current Circle Line Underground services call at Edgware Road twice. But the old Circle Line service, still run occasionally in disruption, calls at all its stations countless times.
Hophead
5 Apr 2013
Paddington as well, though some may regard the sub-surface platforms as separate stations.
Mitchell Hurd
28 Oct 2017
To and from Inverness and Wick - calls at Georgemas Junction twice when running to and from Thurso doesnt it?
davidknibb
30 Oct 2012
When I was a student in Manchester - I travelled from St Pancras to Manchester Central in about 1966. The route was via Trent station (now closed) to Nottingham, and then to Derby stopping at Trent again -and then onto Manchester - and via Chesterfield - and not the more direct route via the still open Buxton line. Interesting route - but no good if your were in a hurry - and yes it was a Sunday
Ken H
11 Nov 2018
N Yorks
Trent station?
Wilts Wanderer
21 Nov 2016
I believe in Cardiff Valley Lines days (possibly Regional Railways prior to that) the Coryton line service went to Cardiff Bay (alternating with a Caerphilly local service) and the City line between Cardiff Central via Ninian Park was served by extending through other Valley lines services from the Queen Street direction via Central and on to Radyr. Anything to/from Treherbert, Merthyr, Aberdare or Pontypridd would have called at Radyr twice.
davidknibb
30 Oct 2012
Yes, near Long Eaton. it has its very own web page . The following is an extract from the first couple of lines from the web page
' Station was opened by the Midland Railway in May 1862 solely as an interchange station. It was not designed to serve any local community, and for this reason it is the only station in England named after a river, rather than after a town or village.'
