Robinson
Personally I would argue that no penalty should be given, as the wording of the clues was meant to indicate that 2 types of traction were represented at the station required.
Due to this station's bizare platform numbering system, I am now about to lose 6 points. However, to keep the game alive, I will reword this as follows:Clue 3:
This station's number of platforms in passenger use has two distinct prime factors. The number of number platforms not in passenger use also has two distinct prime factors, both of which are different to the prime factors of the number of platforms in passenger use.
Preston (Lancs)?
Not east of Edinburgh ?
A prime factor is a factor of a number which can't be divided down further. For example, 20 has 3 prime factors, 2, 2, and 5 (as 2x2x5=20), so two distinct prime factors (as 2 is repeated). Hope this helps.I don't understand clue 3, so won't be posting again in this round ...
I make it just east of Edinburgh
Edinburgh is 3.2 degrees W
Preston is 2.7 degrees W
(both figures given to 2 significant figures)
The reason I think that two should be applicable is that I have provided two dud clues, the original clue 3 and the replacement clue 3.I think the best way forward is for clagmonster to accept the Penalty (I don't see why two should be applicable), and then a new clue.
You have understood correctly.This is not an answer.
Just to make sure that this is the way you intended clue 3 to be understood. Stratford Domestic has 21 platforms, including 2 disused ones. Therefore. for Clue three, the prime factors are 19 for the first part of the clue, and 3 and 7 for the second part. This is just an example.
Is the correct answer.In which case, I'm going to guess at Bristol Temple Meads.
14 platforms in existance (counting the fact that east and west are seperately numbered)
1 platform disused, giving 13 platorms in current use
Prime numbers are 13, 2 and 7
The reason I made the first mistake (thinking there are 15 platforms), is that I didn't account for the fact that platform 15 isn't split into 14 and 15, as the others are, thus meaning there is no platform 14.
