Thameslink Brighton to Cambridge start
A Challenge
24 Sep 2016
It does apply to thameslink trains, and I believe on the Sutton loop services it is both sections declassified?
adamedwards
4 Apr 2016
Sutton trains are announced as declassified at St Albans before departure. This route used to have 2nd class only 319s.
Failed Unit
26 Jan 2009
Central Belt
Come May timetable change all 700 operated services will be classed at TL so the rear first class will be declassified including the odd couple that run in or out of Kings Cross.
It won't be the odd couple that run out of Kings Cross. The Cambridge - Maidstone service will remain separate until at least 2020. So will be at least a service every 30 minutes from Kings Cross. The Welwyn Garden City - Sevenoaks peak service will also run into Kings Cross so 4x class 700s in the peak.
The later should be 100% standard seating.
If these trains ever go through the core remains to be seen, but that is a different debate.
The 2nd service to Cambridge is at an interesting time, leaving St Pancras just before 4pm so useful for some of the earlier commutors using Blackfriars. I have used the service from Finsbury Park - Blackfriars myself. But for now I will stick with changing, ticketing is easier for a start and more services. At the moment from my very limited experiece timekeeping is poor and they hit Finsbury Park with a 5-10 mins delay (all recovered by London Bridge)
Pardon my ignorance. But what is the reasoning logic behind declassifying the rear first class.
There's too much first class, but the advantage of declassifying it at the rear rather than removing it from one end or permanently declassifying one end is that it's always at the front even if a unit ends up turned.
And does the same rules apply for thameslink trains
Yes.
Hadders
27 Apr 2011
Because the trains were specified by the DfT with more 1st class provision than is needed. Combine this standard class that has fewer seats so more people can stand meant that the decision has been taken to declassify the rear 1st class compartment.
On the classic Thameslink route the rear 1st class compartment has been declassified since the trains were introduced (well over a year).
Yes.
Again, on GN this is inferior to what came before. On a 12/365, there would be six separate small sections of first class, so on a down journey one could choose the one nearest the exit at destination station. On a 12-car Undesiro theres now the scope to be coming up the 250m from the platform exit if at the wrong end.
jamesontheroad
24 Jan 2009
Umeå, Sweden
Useful for people going from Anglia to Gatwick though
Doesn't look good for National Express. Cambridge - Gatwick by coach takes about four hours, versus about 1h 40m by train.
From Norwich - Gatwick by bus, there are about 6 departures a day, and the journey takes between six and six and a half hours. Although the train is limited with just two roundtrips a day to begin with (and nothing to get you there in the morning), you can now leave Norwich at 09:40, change at Cambridge and get to Gatwick at 13:11, in just three and a half hours.
Can I ask - when will the Cambridge service go all day, and what will be the first arrival time into and last departure time from Gatwick?
EDIT - I can answer my own question; it's the May timetable change. But then the Norwich connection described above will stop working. Hourly trains from Norwich arrive in Cambridge between xx:52 and xx:01, and the Brighton trains depart at a clockface xx:54 all day long. Bugger. That's a shame.
whoosh
3 Sep 2008
At some point, probably December, those Cambridge to Brightons will be twice an hour instead of only once.
amateur
23 Feb 2014
Yes.
okay. Just wasn't sure if it was cos they didn't want too many plebs (if you could excuse the expression) loitering near the drivers end.
camflyer
13 Feb 2018
Yes, the service is going to be very useful for getting to Gatwick (and Heathrow via Farringdon). I usually have to drive from Cambridge to Gatwick as getting there by train was too much hassle and the National Express is so slow. The bus is just about bearable for Heathrow but you can forget it for Gatwick.
B&W
12 Aug 2013
Myself and a friend did Cambridge to Brighton on Monday, can't say I was entirely enamored by the seats, back pain by Finsbury Park.
Your gluttons for punishment with those seats.
Car for me every time, new car seats get more comfortable as each new train gets more uncomfortable.
PermitToTravel
21 Dec 2011
Groningen
Was anybody making either of those journeys by coach?!
rebmcr
15 Nov 2011
St Neots
This makes zero sense — how on earth will they be able to reach Maidstone or Sevenoaks via Kings Cross?
rebmcr
15 Nov 2011
St Neots
What is this 'core' of which people speak? :s
It's not the Big Apple is it? ;)
The Thameslink route between St Pancras Low Level and Blackfriars, where all of the services between northern and southern destinations come together.
gallafent
23 Dec 2010
… or just go Norwich - Gatwick in 2h41m, via London, taking Northern Line the two stops from Moorgate (an extremely short walk from Liverpool Street) to London Bridge (says google maps!). That might be considered a bit more annoying if one has too much luggage in tow, of course, but it's almost an hour faster still.
rebmcr
15 Nov 2011
St Neots
If we're comparing journeys after the full Thameslink service opens, the optimum is probably via Farringdon, changing to Crossrail at Stratford to reduce the interchange a bit (vice Liverpool Street).
jamesontheroad
24 Jan 2009
Umeå, Sweden
Yes, enough to sustain a direct bus every 2-3 hours day and night. Don't forget that Norwich has two universities with about 18,000 students, including many international students. Norwich (NWI) is handy for Schiphol and KLM, but many people choose to save the hassle of carrying luggage by train and go by bus direct to Heathrow or Gatwick.
Failed Unit
26 Jan 2009
Central Belt
Have a think about it. It will move to St Pancras when/ if it ever runs. Until then it goes to Kings Cross.
Trainfan344
13 Oct 2012
I can't get booking engines to offer me a route on the direct trains between Cambridge and Brighton yet. Anyone else had any luck?
Hadders
27 Apr 2011
Put in via City Thameslink. It works on Webtis sites - not checked any others.
