TfW Class 67+Mk4 sets: trip planning/experiences, diagram updates etc
Jacob Porrett
28 Jan 2022
Telford
Morning
Can anyone help with which loco - is with which set now please ?
I have lost track again !
Thank you
Dave
TFW 67 & Mk4 diagrams
Expected as - Subject to Change
*Revised Diagrams*
*Revised times at Cardiff*
Services using relief lines
Via Cardiff & Newport
Monday 9th June
D1 - 67010 Set HD03 (Loco CDF end)
1V91 05.27 Holyhead - Cardiff 10.13
1W57 10.47 Cardiff - Manchester 14.13
1V46 14.30 Manchester - Cardiff 17.54
1W65 18.47 Cardiff - Manchester 22.21
*Set Turns Via WBQ*
(5K65 ECS 22.30 MAN - CRE CS 23.41)
D2 - *UNIT* 197105*
1W11 04.32 Cardiff - Manchester 08.13
1V37 08.30 Manchester - Cardiff 11.55
1W61 14.47 Cardiff - Manchester 18.13
1V62 18.30 Manchester - Cardiff 22.01
D3 - 67025 Set HD07 (Loco CDF end)
(5W13 ECS 04.10 CDF CS - SWA 05.21)
1W13 05.43 Swansea - Manchester 10.13
1V39 10.30 Manchester - Cardiff 14.02
1W96 17.11 Cardiff - Holyhead 22.06
D4 - *UNIT* 197042*
1V31 05.12 Crewe - Cardiff 08.01
67008 Set HD06 (Loco CDF end)
1W55 08.47 Cardiff - Manchester 12.13
1V42 12.30 Manchester - Cardiff 15.49
1W63 16.47 Cardiff - Manchester 20.15
*Via Styal*
(5K70 ECS 20.24 MAN - CRE CS 21.09)
D5 - 67013 Set HD04 (Loco CDF end)
*After Set Turns Via WBQ*
(5V33 ECS 05.12 CRE CS - MAN 06.23)
1V33 06.27 Manchester - Cardiff 10.01
1W59 12.47 Cardiff - Manchester 16.13
1V50 16.30 Manchester - Cardiff 19.52
Sunday 8th June
Last Known Date of
Workings & Location of Locos
67008 Cardiff (Sun 8th)
67010 Holyhead (Fri 6th)
67012 Stored Toton (Thur 3rd April)
67013 ATC Crewe (Sun 8th)
67014 Crewe EMD (Mon 2nd)
67015 Spare ATC Crewe (Sat 7th)
67016 Spare Cardiff (Wed 4th)
67017 Repair Crewe EMD (Tue 3rd)
67020 Maint Crewe EMD (Sat 7th)
67022 Spare Crewe (Sat 7th)
67025 Cardiff (Sat 7th)
67028 Mods Crewe EMD (Thu 28th Nov)
67029 ATC Crewe (Sat 7th)
Last Known Date of
Workings & Location of Sets
Set HD01 Exam Crewe (Sat 7th)
Set HD02 OOS Crewe (Fri 23rd May)
Set HD03 Holyhead (Fri 6th)
Set HD04 Crewe (Sun 8th)
Set HD05 OOS Crewe (Mon 2nd)
Set HD06 Cardiff (Sun 8th)
Set HD07 Cardiff (Sat 7th) ——————————————————————-
Locos & Sets
67029 Set HD01 DVT 82226, ATC Crewe 7/6
Set on Exam
Set HD02 DVT 82229, Crewe EMD 7/6
Out of Service
67010 Set HD03 DVT 82216, Holyhead 7/6
In Service
67013 Set HD04 DVT 82201, ATC Crewe 8/6
In Service
67014 Set HD05 DVT 82200, Crewe EMD 7/6
Out of Service
67008 Set HD06 DVT 82227, Cardiff 8/6
In Service
67025 Set HD07 DVT 82230, Cardiff 7/6
In Service
Last known workings date in ( )
Posted in good faith !
Don’t shoot the messenger
Please post any
Updates & Workings,
Thanks.
From the Official Class 67 page on Facebook
Welshguy1048
6 Apr 2023
North Wales
*Revised Diagrams*
Monday 9th June
*Set Turns Via WBQ*
D2 - *UNIT* 197105*
D4 - *UNIT* 197042*
*Via Styal*
Sunday 8th June
Last Known Date of
Last Known Date of
Locos & Sets
Set on Exam
Out of Service
In Service
In Service
Out of Service
In Service
In Service
Please post any
Updates & Workings,
Thanks.
@Jacob Porrett
Thank you very much.
Appreciate all your help
Dave
sd0733
7 Nov 2012
67014 has now come off damaged HD05, run over to ATC briefly before it heads to Canton later.
Jacob Porrett
28 Jan 2022
Telford
Today at Crewe depot (9/6/25):
67014 light engine: Ran 0Z84 from Crewe depot to Canton depot.
67015 light engine
67022 light engine
67029 connected to HD01
sd0733
7 Nov 2012
Any info on the one that hit that trailer?
AFAIK the current thinking is that HD08s DVT will be prioritised for return, that will then go onto HD02 with the damaged one then going onto HD08 when it's fixed.
Lots of factors may change that yet though.
37052 xb mr
6 Dec 2023
Stockport
Hello, Do you know if Saturday diagrams will be down to 3 sets now
With currently only 4 in service
Thanks
Jacob Porrett
28 Jan 2022
Telford
HD02 DVT (82229) is on the back of a Allelys truck seen on the A500 from Crewe. No longer at the ETD. Destination unknown.
sd0733
7 Nov 2012
A couple of loco swaps planned for tomorrow.
After arrival back into Cardiff after 1V39, 67008 will be replaced by 67016 on HD06. HD07 is planned for the Crewe-Crewe Diagram and when it arrives back in the evening should see 67025 replaced by 67015.
Set wise, as theres capacity at Crewe due to HD05s absence, some minor exams are being brought forward, HD03 will be done Tuesday and Wednesday with HD04 down for its exam on Thursday and Friday.
sd0733
7 Nov 2012
Today at Crewe depot (10/6/25):
67022 light engine.
67015 light engine.
67010 connected to HD03.
67015 has had wheelset issues picked up and has been returned to ETD for tyre turning.
67022 will now replace 67025 on HD07 tonight instead.
TT-ONR-NRN
30 Dec 2016
Cambridge
Thanks for that, does that mean coffee and biscuits in 1st or purchase anything you want?
Also I note you don't mention 1W55 14.55 Swansea Manchester-none at all on that one?
You wish. The complimentary offering is so pathetic that it ought to be withdrawn altogether to save disappointment.
The choice is:
- Pecan, raisin and sultana mix
- Vegetable crisps made from dried beetroot, parsnip and celeriac
and that's it.
If you order a hot drink, they will place the world's thinnest organic biscuit on the side of the saucer as well.
Topological
20 Feb 2023
Swansea
I did Pontypool to Cardiff on the 06:27 ex Manchester. 1 other person in first class. The rest of the train was well-loaded as I had been on since Piccadilly. By that point it was too late for freebies, but judging by the state of the carriage there had not been many others there to know. (Two tables had one take away coffee cup on each).
BillStampy
6 Jan 2024
Llanharan
Can anyone confirm HD08's DVT? I'm confused as I'm seeing two answers, 82204 and 82220. I'm aware that the new plan will be to get it onto HD02 when it's ready but I want to know the true answer.
sd0733
7 Nov 2012
The DVT of HD08 is currently in the system as 82220 with 82204 as the spare.
Both are now at Worksop along with 82229.
