TfW Class 67+Mk4 sets: trip planning/experiences, diagram updates etc
37052 xb mr
6 Dec 2023
Stockport
Yes, nothing can be done about the Wilmslow turn around (much as it is a massive annoyance for those of us coming from Manchester it happens irrespective of stock)
Really hope the sets make it through the rest of the day, but sadly no conclusion can be reached until the last diagram makes it to the end (arrival of the 18:30 from Manchester into Cardiff?)
1W65 last one in
18.53 Cardiff - Manchester 22.24
CW2
7 May 2020
Crewe
1W63 & 1W96 both heavily delayed due signal issues
Both delayed by about an hour due to signalling issues Abergavenny to Pontrilas (and possibly beyond). 1W63 held at Abergavenny then allowed forward at caution to examine the line.
Rhysdabeast
10 Apr 2020
Crewe
Was going to have a trip on 67029 tonight on 1W63 but being terminated at Crewe, one for another day!
sd0733
7 Nov 2012
Some disruption this evening with the signalling issues mentioned above but the sets have run everything as booked without issue themselves.
Tomorrow is planned 5 out again, a minor change is that there is a planned diagram swap in the evening with the 1230 from Manchester with HD04 going on to form the PM Holyhead and HD07 from the 1030 from Manchester forming the 1653 back to Manchester.
This is to allow HD07 to have some electrical repairs, it should be replaced on Wednesday by HD02 which is having some post exam repairs tomorrow.
37052 xb mr
6 Dec 2023
Stockport
1V33 didn’t make it, 197124
sd0733
7 Nov 2012
67013 set 6 confirmed
From Crewe on 1W61
Yes, been ready to go for a while. 67029 has also made its way over to ETD for tyre turning.
There were only 5 sets for a very short period, HD04 having AWS issues at Cwmbran and now expected to head back to Canton.
67022 is due out on test tomorrow running to Shrewsbury and back.
Welshguy1048
6 Apr 2023
North Wales
@sd0733
Evening
What is on 1W96 tonight please?
Thank you
Dave
37052 xb mr
6 Dec 2023
Stockport
Can Canton handle 3 sets tonight ?
5W96, 1V50 & 1V62
Jacob Porrett
28 Jan 2022
Telford
Today at Crewe depot (21/1/25):
67013 was connected to HD03 but has now swapped onto HD06 leaving HD03 without a loco.
67015 is connected to HD02.
Topological
20 Feb 2023
Swansea
It’s failed at Cwmbran
At least that is close enough to civilisation. No one got 8 hours on the set in the way they did with the 197 on Sunday night / Monday morning.
After the success of yesterday, today seems to have been a bit of a drop. 1-13 now on completed days, but plenty of time left for that completion number to shoot up.
sd0733
7 Nov 2012
Any idea if it’s likely there will be 2 off
Canton in the morning please
Is 67020 repaired to replace 67014
If needs be ?
Thanks
Not too sure in all honesty whats the score with either of those.
The original plan was for 67014+HD04 to finish at Crewe tomorrow night for some work for a day on Thursday at ATC so if it does make it out out there's likely to need to be a swap somewhere to get it back to Crewe.
37052 xb mr
6 Dec 2023
Stockport
Ok, cheers
FrodshamJnct
14 Apr 2019
Cheshire
Plan today is:
Wednesday 22nd January
D1 - 67013 Set HD06 (Loco CDF end)
1V91 05.27 Holyhead - Cardiff 09.57
1W57 10.53 Cardiff - Manchester 14.13
1V46 14.30 Manchester - Cardiff 17.44
1W65 18.53 Cardiff - Manchester 22.24
*Set Turns Via WBQ*
(5W65 ECS 22.30 MAN - CRE CS 23.41)
D2 - 67016 Set HD05 (Loco MAN end)
1W11 04.33 Cardiff - Manchester 08.13
1V37 08.30 Manchester - Cardiff 11.38
1W59 12.53 Cardiff - Manchester 16.13
1V50 16.30 Manchester - Cardiff 19.44
D3 - 67014 Set HD04 (Loco MAN end)
*Cape*
(5W13 ECS 04.07 CDF CS - SWA 05.21)
*Starting at Cardiff* 06.46
1W13 05.43 Swansea - Manchester 10.13
1V39 10.30 Manchester - Cardiff 13.49
1W96 17.22 Cardiff - Holyhead 22.06
D4 - 67015 Set HD02 (Loco CDF end)
1V31 05.13 Crewe - Cardiff 07.50
1W55 08.53 Cardiff - Manchester 12.13
1V42 12.30 Manchester - Cardiff 15.43
1W63 16.53 Cardiff - Manchester 20.16
(5K70 ECS 20.24 MAN - CRE CS 21.09)
D5 - 67017 Set HD01 (Loco MAN end)
*Set Turns Via WBQ*
(5V33 ECS 05.12 CRE CS - MAN 06.23)
1V33 06.27 Manchester - Cardiff 09.47
1W61 14.50 Cardiff - Manchester 18.13
1V62 18.30 Manchester - Cardiff 21.52
37052 xb mr
6 Dec 2023
Stockport
Hello
Is 67014 set 4 still required back at Crewe tonight please ?
Possible work 1W63
With 67015 set 2 to work 1W96
Like yesterday switch
Thanks
sd0733
7 Nov 2012
Hello
Possible work 1W63
Thanks
Yes. That's exactly what is planned to happen, hopefully a little more successful than yesterday's identical swap.
Loco wise, 67022 and 67029 are expected back at ATC tomorrow, 022 will go onto HD03 following it's test run earlier and 029 will be spare/recovery for now.
