TfW Class 67+Mk4 sets: trip planning/experiences, diagram updates etc
sd0733
7 Nov 2012
Afternoon all
I had this information given to me by a Gbrf driver friend.....
Dave
No chance of that I'm afraid, 1 is planned to come in to service in just over 12 months and even that is just to cover the existing sets while they go for overhauls to start off with.
In the long run never say never. It was being looked at as a way of keeping up with and adding capacity/resilience but it's certainly not a given.
sd0733
7 Nov 2012
1V46 cancelled at Manchester
Due to a ill passenger
67012 Set 3 ran ECS to Crewe as 5V46
1W65 showing cancelled as a result
Set now quarantined pending a deep clean.
Terrible Unit availability across all mainline 158/197/Mk4 fleets today so nothing available to cover W65.
BillStampy
6 Jan 2024
Llanharan
1W63 terminated at Crewe, 67014 + HD07 now working 1V62 back to Cardiff to step in for the Canton diagram tomorrow. Will HD03 be ready in time following todays events? Unsure how long a deep clean would take depending on what happened.
sd0733
7 Nov 2012
At least everything is in place for tomorrow. Not entirely sure why it was sent out on the "opposite" diagram this morning but there must have been a reason.
It's hoped to get it out with it getting to the depot early its got the best chance of making it out.
BillStampy
6 Jan 2024
Llanharan
67012 + HD03 showing allocated, hopefully it'll get off depot tomorrow then!
sd0733
7 Nov 2012
There's 6 197s and 6 158s also out of action above the planned amounts this weekend so will certainly be a priority to get it going as cover would be thin on the ground.
37052 xb mr
6 Dec 2023
Stockport
They have found one somewhere
Now showing as 197021 plus
A 2nd one from Shrewsbury 197047
sd0733
7 Nov 2012
Unit availability does seem better than expected today to be fair to the 197s!
HD03 has been deemed needing a heavier clean than Crewe can do so is off empty to Canton tomorrow for a full bio clean.
It does leave things incredibly short for tomorrow with only 1 full diagram and 1 part diagram covered, both the Crewe starts are units and the Holyhead start diagram will finish in Cardiff when it arrives at 17:50.
HD01 is now on minor exam, HD02 stored and HD05 on post tyre turn repairs but 67025+HD06 are planned out on test tomorrow following exam and it's failure pre-exam which should increase availability from Tuesday.
67017 is also back available and should head over to ATC later, loco availability isn't too bad but the rakes themselves are having a dreadful time.
37052 xb mr
6 Dec 2023
Stockport
Thanks
37052 xb mr
6 Dec 2023
Stockport
Signal problems Newport area
67010 on 1V91 over 50 minutes late.
Replaced on 1W57 by 197005
Off 1V33 turned at Newport.
BillStampy
6 Jan 2024
Llanharan
67012 + HD03 showing as allocated to 1W65, meaning we should have 3 sets out now. Better than 2!
BillStampy
6 Jan 2024
Llanharan
67012 showing as being taken off HD03 tonight in place for 67017 which recently returned.
67014 + HD07 at Holyhead tonight, 1V91/1W57/1V46/1W65 tomorrow
67013 + HD04 to work 1W11/1V37/1W96 tomorrow
67012 + HD06 is showing to work 1V31/1W55/1V42/1W23 tomorrow too after a loco swap from 67025 I believe, worked a test run today under headcode 5Z25 I'm pretty sure.
Overall, good to have 4 back out.
Edit: seems to have swapped back around, 67012 is with HD03 and 67017 with HD06 on the same diagrams
Jacob Porrett
28 Jan 2022
Telford
Today at Crewe depot (11/11/24):
67010 connected to HD01
67008 connected to HD05
67017 connected to HD06
67025
67015
ValleyLines142
25 Jul 2011
Gloucester
I was due to catch the 1630 from Manchester on Friday but with it initially showing as a 2 car 197, I bailed, only for it then to be set swapped at Crewe on the way up. I'd already altered my plans so couldn't go with my original, but is there scheduled to be a chef on board this train usually?
MP393
28 Jun 2021
North West
Yes that one does and it’s a pretty reliable one for hot food on board too. The chef availability is getting a lot better recently too with more recruited at the north end of the route now.
ValleyLines142
25 Jul 2011
Gloucester
V
Great, will bear that in mind. Thanks.
37052 xb mr
6 Dec 2023
Stockport
1V91 diverted via Crewe this morning
Due to signal box being shut on Wrexham line. 38 late into Cardiff
67012 has blown up on 1V37 at Shrewsbury. 67025 rescue loco
67017 set 6 being changed
On 1W19 & 1V50 now showing as 197121
67029 Set 6 on 1W96 to Holyhead
JakeMurphy
30 Aug 2018
Di
67012 has blow up on 1V37 at Shrewsbury.
Doesn’t sound good about v37..
Jacob Porrett
28 Jan 2022
Telford
Today at Crewe depot (13/11/24):
67025
67012 declared a failure and was on HD03 now coupled up with 67025 (just the two 67s together)
67015 now connected to HD03
67008 connected to HD05 which has done a test run from the depot to Shrewsbury and back again on 5Z67.
BillStampy
6 Jan 2024
Llanharan
67025
Assuming the whole failure was on 012 and not the set itself, assuming it'll be okay now and serviceable with 015 on it.
HD05 I'm supposing is now ready too, which is good news. That leaves 01 and 02 out of service (if HD03 is too then that's all the LNER ones out!) Unless 01 is nearly ready
37052 xb mr
6 Dec 2023
Stockport
1V91 67029 Set 6
1V31 67008 Set 5
1V33 67013 Set 4
1W11 67015 Set 3 from Crewe
67025
0Z67 08.10 Crewe CS - Canton 11.41
Iskra
11 Jun 2014
West Riding
I did 67014 on the 1230 from Manchester Piccadilly yesterday, it was shown as a loco hauled set on RealtimeTrains, but the loco number wasn’t specified for some reason. Lovely trip in the ex-GC coaches.
At Cardiff the 197 I was meant to catch to Fishguard Harbour never materialised, with a 150 eventually turning up to take us to Carmarthen for buses onwards.
Jacob Porrett
28 Jan 2022
Telford
Had a conversation at work the other day and HD08 is on the cards but it will take another year before we see it.
