TfL to scrap paper tickets
Benjwri
16 Jan 2022
They're not, it's that as with TfL's own tickets there's a premium for using a paper ticket.
Not to mention the prices are nothing to do with the TOCs, it's a standard add on to their London Terminals fare
There is a premium for using Contactless on almost all journeys from Redhill.
There's a premium for using contactless the entire way sometimes, but a paper ticket to London Terminals, then contactless will always be cheaper than a through ticket.
28 Aug 2020
Oh dear, that's a good question. The Chiltern website does specify how to buy the ones they've set online, but I can't find any mention on the GWR website at all of them, only their family advance tickets, which wouldn't be relevant here.
It's possible to buy the GWR ones online, just not from GWR, it seems. I've bought them from London Northwestern Railway before, for example
sheff1
24 Dec 2009
Sheffield
How is it a premium when it costs less for a through paper ticket to Zone 1 than buying an e-ticket to London Terminals and using contactless in Zone 1 ?
James H
25 Jun 2014
Thank you - that's super helpful. I've indeed just been able to find them on the LNR site. Even by the standards of the UK rail industry, an utterly bonkers state of affairs!
sheff1
24 Dec 2009
Sheffield
Super Offpeak single NCL-KGX is £82.80 NCL- Zone 1 is £86.80 so £4 for the add on as opposed to £2.80 on Oyster
The previous posts referred to using contactless and claimed it was always cheaper than buying a through ticket which is not the case.
778
4 May 2020
Hemel Hempstead
Will cross London journeys with paper tickets still be possible? For example if you wanted to go from Milton Keynes to Portsmouth would you now have to use conatactless to get through the TFL barriers?
It is unknown at present. A lot of the fear about this proposal is about the loss of Cross London interchange with the switch from tickets with magnetic strips to tickets with full sized barcodes, but it is only speculation at the moment that Cross London travel would be lost.
Going by what has been written, there is however a stated desire for the railway, and seemingly TfL, to remove the current credit card sized tickets as rapidly as possible.
Haywain
3 Feb 2013
Perhaps you should reply to the post that made that claim then.
There is however a stated desire for the railway, and seemingly TfL, to remove the current credit card sized tickets as rapidly as possible.
This makes sense, as the acceptance mechanism for barcodes and smartcards is solid state so much easier and cheaper to maintain, similarly for the issuing tech - a simple thermal till roll printer can print an e-ticket, you need much more complex kit to encode one as well.
sheff1
24 Dec 2009
Sheffield
Perhaps you should reply tothe post thst made that claim then.
I did, you replied (quoting just part of my post), to which I replied asking how a paper ticket had a premium when it was cheaper to buy same than use an e-ticket/contactless combination. Wallendsmag then replied but was talking about Oyster, not contactless, which I pointed out.
Going by what has been written in this thread, however, it seems that TfL has signalled clear intention to withdraw Credit Card Sized Tickets, but not to enable any replacement, other than its own solution.
plugwash
29 May 2015
Wasn't ITSO enabled on London Underground barriers relatively recently? Not nessarally a full replacement but certainly one that works for some usecases.
Alex365Dash
2 Jul 2019
Sussex
It works fine on the Glasgow Subway, which also prints paper ITSO tickets at a higher expense than using a smartcard (although not as extreme as the Tube paper single/return fares), but with TfL…
…I actually don’t have a good reason for why this wouldn’t work. It also gives an option to retain paper LU single/return fares (at the extortionate rate) whilst still retiring the magstripe readers at the gates.
On another note, how are you meant to get in a Compulsory Ticket Area (CTA) in a station where the platform tickets are sold by LU only (such as West Ruislip) if the platform tickets are withdrawn? Do you have to have a Travelcard or tap in and out and pay for a same station exit, which would be either the minimum PAYG fare for 2-29 minutes or two maximum fares for 30+ minutes?
Of course, the National Rail approach at non-CTA stations (aka the vast majority of them) where you just ask the gateline staff nicely doesn’t work when you get charged a Penalty Fare for not having a valid travel ticket or a non-existent platform ticket.
The need for someone to be in a Compulsory Ticket Area if they are not travelling is a somewhat niche case.
CyrusWuff
20 May 2013
TfL also use similar technology, with "paper" One Day Bus and Tram Passes bought from Oyster "Ticket Stops" having been issued on disposable Oyster cards for a few years now.
Benjwri
16 Jan 2022
The Glasgow subway works just about because it’s smaller, and this might work just for paper TfL tickets, but the paper ITSO tickets are absolutely terrible for the environment, as they aren’t recyclable and are one use. Use on a scale as large as London Underground would be disastrous.
The best idea I saw was somewhere in Asia where they issue reusable coin-shaped ITSO tokens, which you insert into the destination gateline and they are collected from there and reused. Does mean you need the mechanism, though.
Haywain
3 Feb 2013
These are used in Kuala Lumpur on the local metro system. Coin shaped tokens bought from a machine and collected by the barrier on exit - just drop the token into a slot and the barrier opens. On the airport express they have a similar process but using credit card sized tokens.
Tester
5 Jul 2020
Watford
The Bangkok airport line also uses coin shaped tokens.
Haywain
3 Feb 2013
However, we're not going to see that happen in London as it would require a huge investment in barriers to collect and read the tokens.
zero
3 Apr 2011
I believe the Hong Kong MTR, and Bangkok BTS, still issue single tickets on a magnetic card which is retained by exit barriers and can be reused later (when staff put them back into ticket machines).
Is all of West Ruislip a CTA or is it just the LU platforms? Platform 4 (NR) has an unbarriered exit to a road.
I found something saying South Ruislip NR platforms are not a CTA - but they can only be accessed via LU gates (or a train).
miklcct
2 May 2021
Cricklewood
The Hong Kong MTR has since then migrated to a contactless card which can be collected by the exit gateline, similar to the token mentioned above but being card-shape such that it can be compatible with existing hardware.
The reason is reduced tear and wear compared to magnetic stripe tickets.
Alex365Dash
2 Jul 2019
Sussex
NR platforms aren't a CTA, the CTA starts on the ticketed side of the gateline or if you're going from NR to LU, when you cross the red line up to the bridge which takes you around the ticket barriers.
zero
3 Apr 2011
Yes I remember the red line now. But then I don't understand what point you were trying to make in the original post:
How is (the LU part of) West Ruislip different from any other LU station which are also CTAs if you won't be able to buy a platform ticket any more?
Alex365Dash
2 Jul 2019
Sussex
To be honest, I wasn’t entirely sure if LU CTAs were also enforced in the same way through Penalty Fares legislation - I’m aware from signage at West Ruislip that that is the case at that station.
FenMan
13 Oct 2011
*cough*
This thread is not about West Ruislip station ...
MrJeeves
28 Aug 2015
Burgess Hill
miklcct
2 May 2021
Cricklewood
Are all U zone tickets from outside the zones priced as a fixed amount above the fare between the outboundary origin/destination and the presumed interchange station?
