Stagecoach East Midlands - Timetables, Services, & Wider Operations
jamestaylor94
31 Jan 2018
I noticed a few things looking at 28614's MOT history
1. It has never had it done at Hull before, its usually at Mansfield
2. Theres a note on its latest one about a kingpin (I'm sure the engineer people will know) so that's likely to need repairing before any prep into service.
Also I saw a picture on discord which 100% confirms 24197 is at Mansfield now.
What discord is this mate?
RareApe
19 Aug 2025
Mansfield
I don’t have time to get a good photo, but I seen this in Mansfield.
Zenneth101
21 Jul 2024
Kingston-upon-Hull
jimbob185
9 Oct 2018
From what I heard all 26 euro 6 Cummins engined Enviro 300 MANs are due to leave Hull which would be:
22757 FX09 DBU
22776 FX09 DCV
22797 FX09 DDE
22877 SP09 DPV
24161 PO59 MWU
24162 PO59 MWV
24163 PO59 MWW
24164 PO59 MWX
24183 SF10 BYU
24186 SF10 BYX
24187 SF10 BYY
24188 SF10 BYZ
24192 FX10 AEC
24193 FX10 AED
24194 FX10 AEE
24195 FX10 AEF
24196 FX10 AEG
24197 FX10 AEJ (Moved to Mansfield for 27205 SL64 HYT)
24198 FX10 AEK
24199 FX10 AEL
24200 FX10 AEM
24201 FX10 AEN (Moved to Worksop for 28614 FX61 CYY)
24202 FX10 AEO
24203 FX10 AEP
24204 FX10 AET
24205 FX10 AEU
In return Hull will receive Scania E300s from Worksop and 27xxx's from other depots. I have been told that 24192-97 are due to go to Mansfield and in return Hull would get 27xxx's with Mansfield keeping 2 or 3 27xxx's still. I am unsure where the other 27xxx's are due to come from.
CN12 AWU
11 Nov 2024
22757 FX09 DBU
22776 FX09 DCV
22797 FX09 DDE
22877 SP09 DPV
24161 PO59 MWU
24162 PO59 MWV
24163 PO59 MWW
24164 PO59 MWX
24183 SF10 BYU
24186 SF10 BYX
24187 SF10 BYY
24188 SF10 BYZ
24192 FX10 AEC
24193 FX10 AED
24194 FX10 AEE
24195 FX10 AEF
24196 FX10 AEG
24198 FX10 AEK
24199 FX10 AEL
24200 FX10 AEM
24202 FX10 AEO
24203 FX10 AEP
24204 FX10 AET
24205 FX10 AEU
Can you update this list as transferes happen
Presume none been done over weekend?
JD2168
11 Jul 2022
Sheffield
I wonder what Worksop will put the MAN’s on?
I can’t see it being the Sherwood Arrow due to the route length & topography but this is a route the Scania’s are generally on alongside the 21/22/25 to Doncaster
Some of the Scania’s are in quite a need of repainting, indeed a number still have the 19 route branding that they was applied when they were new
Zenneth101
21 Jul 2024
Kingston-upon-Hull
Dw we'll make them look worse for you hehe
22757 FX09 DBU
22776 FX09 DCV
22797 FX09 DDE
22877 SP09 DPV
24161 PO59 MWU
24162 PO59 MWV
24163 PO59 MWW
24164 PO59 MWX
24183 SF10 BYU
24186 SF10 BYX
24187 SF10 BYY
24188 SF10 BYZ
24192 FX10 AEC
24193 FX10 AED
24194 FX10 AEE
24195 FX10 AEF
24196 FX10 AEG
24198 FX10 AEK
24199 FX10 AEL
24200 FX10 AEM
24202 FX10 AEO
24203 FX10 AEP
24204 FX10 AET
24205 FX10 AEU
Adding on: 26 leaving, however there's only 11 Scanias, and Mansfield have 8 E300s (2 are keeping as you said) which adds to 17, meaning 9 random 27s must be from other depots.
I cant help but think Worksop COULD lose 27197-27199 to us
RareApe
19 Aug 2025
Mansfield
36509 broke down this morning while doing the 1. Was last seen on a tow truck most likely heading to hull where it will be fixed and most likely repainted.
Just ignore this message.
Zenneth101
21 Jul 2024
Kingston-upon-Hull
36509 broke down this morning while doing the 1. Was last seen on a tow truck most likely heading to hull where it will be fixed and most likely repainted.​
I don’t know why my text is in bold.
Idk about repainted it depends if the issue is to lots of areas
K13R0N
26 Mar 2019
Grimsby
Why would a Mansfield bus breaking down in Mansfield be towed all the way to Hull for repair?
CN12 AWU
11 Nov 2024
Does anyone know if anything else has swapped over the weekend and today looks like all 28***'s been in service bar 28614 which is rumoured at Hull
24186 hasn't tracked today so wonder if this has also gone as only others not tracking are 24197/24201 which have left Hull
Not sure if another 27*** has switched over
K13R0N
26 Mar 2019
Grimsby
just for another spanner in the works heard Grimsby are getting 26262/72 and some of Hull’s MMC 400’s ?
400 MMCs were rumoured once Hull get their electrics (would imagine it's the 107xxs). 26262/72 were mentioned recently on this forum but don't know how true that is as Mansfield require them for the Sheffield clean air zone
CN12 AWU
11 Nov 2024
I heard 26255 was going back to Grimsby as it's not needed and the late 350 duty will be a 27/28***
But I not seen anything official to vouch for this
All 107** were meant to go Grimsby when electrics are due
jimbob185
9 Oct 2018
I presume the MANs that are moving might be able to replace them as they have Euro 6 engines which I presume means they should be able to go into the clean air zone.
Does anyone know what’s happened to 10734 as it hasn’t tracked for a few weeks?
ChrisC
7 Oct 2018
Nottinghamshire
There have been quite a few occasions in the last few weeks when double deckers have been on the 53 to Sheffield. There was a double decker on the 53 all day on Saturday. Perhaps Mansfield are going to use them more regularly to Sheffield.
Zenneth101
21 Jul 2024
Kingston-upon-Hull
I'd assume repainted or for repair, maybe a newer pride livery
Unrelated, but I got sent this by my friend (80332 in Hull)
jimbob185
9 Oct 2018
According to Bustimes seems to be back in service today. So must have been something Mansfield could fix.
CN12 AWU
11 Nov 2024
They always test new buses down holdersness Road by ADL in Scarborough I believe Merseyside, Manchester, London and others have been noted down there
Zenneth101
21 Jul 2024
Kingston-upon-Hull
As someone who lives on the late 350 duty's daytime route, I genuinely hope 26255 if it leaves gets replaced by a 28xxx
Also just saw on Flickr, 24201 is confirmed to be with Worksop (https://www.flickr.com/photos/122599534@N05/54899614155/in/datetaken/)
