Stagecoach East Midlands - Timetables, Services, & Wider Operations
CN12 AWU
11 Nov 2024
Been informed 24135 is in hull depot
Can't confirm however info from another bus forum site so not sure if any truth in it
Seems a strange move if true
Zenneth101
21 Jul 2024
Kingston-upon-Hull
37465 by the looks of it might be a repair as it did the 1 on the 17th and then mysteriously disappeared at 9am
Either that or repaint, I doubt Hull needs another E200MMC
It is withdrawn and MOT expired so based off of history (22544/635) its likely just a spare or disposal deal, nothing overly exciting.
RareApe
19 Aug 2025
Mansfield
So will any of the old buildings survive?
Yes, even though the building was described as "dilapidated", if you compare it to how it currently looks and the plan, they look completely different. Mansfield has said it will be partly demolished to "bring it into the 21st century." Therefore, there will be old buildings that will survive.
andyb87
24 Aug 2025
mansfield
It perhaps depends on how “honest” the artists impression is, since on that everything moves around the site and it’s in new buildings. At present the frontage houses the offices etc. and those are shown at the top end, at right angles to now. The rest of the current frontage is replaced by open parking behind a wall/fence, so that really just leaves some retaining walls….. Then again, if you look at the parking bays and charging points then some bays have two cp‘s and others none, so there may be some artistic licence in play. Personally, I rather like the current frontage and don’t really think that an open yard behind a wall/fence advertises the company well. This is after all a location on a busy main road close to the town centre. Then again, perhaps I’m just a traditionalist and prefer a depot to a yard - I just think it looks more professional.
23 Nov 2023
Grimsby
It looks like 10896 is finally being prepared for a comeback; I'm guessing this is it anyway!
Zenneth101
21 Jul 2024
Kingston-upon-Hull
37465 is currently at Hull for MOT, of which it failed due to a form of damage or leak (its on Government MOT check website). Its at Hull likely to get fixed and have a PASS MOT as it will run out on 11th October.
Any Lincoln fans or people reading, 37465 will likely be out for a bit due to this.
TheGrandWazoo
18 Feb 2013
The current buildings are c.90 years old. Also, you are talking about a cost of £5/ft for every bit of depot building you have in terms of business rates and utilities so it's no surprise that operators prefer open parking. Even more so when then considering charging infrastructure.
CN12 AWU
11 Nov 2024
Has anyone heard what extra buses are due to Hull for Hull for in a couple weeks time? I suspect it be MMCs this year from somewhere?
gazmark
28 Jan 2020
Sheffield
Just took a ride on rocky the seasider, droped into limp mode and just refused to start, no power or drive.... Not good
Zenneth101
21 Jul 2024
Kingston-upon-Hull
On the Hull side, history has been made with 26172 replacing 26255 today on the 4/6 however on H0404 diagram instead of H0401 (24192 did that today). I am very happy Stagecoach did that its a rare W for them
CN12 AWU
11 Nov 2024
It's prob more likely 26172 developed a fault this morning so 26255 being a 350 bus went on 350's
26172 when fixed just got used on anything that needed covering hence locals on 4/6
Prob same reason 26173 ended up on 111 apparently yesterday
A mate of mine (ex colleague) works there and said that's what happened
