Southeastern metro fleet replacement/improvement
Wolfie
17 Aug 2010
I will doubtless be accused of wishful thinking here, but I honestly genuinely think that Southeastern metro fleet replacement will become both an early and easy victim of post-autumn budget austerity when it inevitably hits the rail industry, got to pay for all those pay rises somehow haven't we
Send them all up to Derby including the ones currently withdrawn as spares donors or to be recommissioned and put back into use. And whilst they're there, they'll get a heavy mechanical overhaul and major internal refurbishment involving full strip out and start again once that's done, do the same with the electrostar fleet starting with the 376 upgrading. What is a very cosmetic refresh at present to new seats, USB charging and perhaps even some air conditioning? Once that's complete they can heavily refurbish and midlife extend the expected lifetime of the 375 and 377 fleets. Doing this keeps Derby going so happy unions and workers and saves an awful lot of money. I suspect that the only rolling stock investment we're going to see outside of hs2 for quite some time. Is the sprinter replacements and then either at the same time or just after the turbos
No doubt the god-awful 170 fleet can be life extended in some way as well
Apologies for slight off topic but simply demonstrating my reasoning for the cutbacks potentially to Southeastern
I fear that the cost of such a refurbishment, which necessarily would involve replacing obsolete electronic systems (and the integration and testing grief that likely goes with that), would likely approach the cost of procuring new rolling stock.
What is wrong with the 170s to merit that comment?
Doomotron
25 Jun 2018
Kent
As has already been said, the price of a major refurbishment and mechanical overhaul of the Networker fleet would be expensive to the extent of it being completely unfeasible.
As for investment in rolling stock, HS2 won't affect anything. We have a number of fleets in this country that are rapidly approaching the end of their lives and will need to be replaced no matter what, and there's no way they're going to give Class 150s new interiors and air conditioning.
I'm also not sure what exactly is wrong with the Class 170's interior, but I digress.
LUYMun
15 Jul 2018
Cancelled
I'd suspect replacing the remainder of the Met Cam tractioned fleet so all 465/466s are powered by Hitachi motors or similar. Add to that new seating in a 2+2 layout, replacement of door buttons for PSVAR friendly ones, replacing the flooring, fitting PSVAR compliant toilets on all units and probably painting them all dark blue for good measure, and that's the fleet sorted for another 10-15 years. In the latter half of that timeframe, the planning for new rolling stock can begin with construction, testing and introduction accounted for.
Doomotron
25 Jun 2018
Kent
That would be somewhat feasible ten years ago, but now these trains are 30 years old and any money spent on them is a waste. The 465s should not be in service into their 40s, and really should have been replaced long ago.
ScotGG
3 Apr 2013
Does anyone know the actual cost of leasing a new train now with interest rates the highest they've been for 16 years?
While they may go down I don't think anyone sees those 1 per cent rates coming back. It certainly won't be as cheap as it was for many years which must play a part in any decision.
Blindtraveler
28 Feb 2011
I think they are. PS var compliant already with the exception of the 466 which do not have a mega bog but I don't see any issue. The rest of what you suggest and with this done and ongoing good maintenance cannot see why they would not last another 15 years
With the final two 707s moving to Southeastern this weekend, are any further Networker withdrawals into storage planned? There's nothing in RTT yet (looking at Gillingham depot, where all the previous moves originated from), and I'd assume something needs to move if Southeastern is currently utilising all its stabling capacity.
Stephen42
6 Aug 2020
I wouldn't expect anything to be shown yet for storage moves. A pair of 707s typically spent two weeks at Gillingham preparing them for Southeastern service and then got moved to a location with 707 diagrams. Stabling space is limited particularly in metro locations, but some maintenance locations should have a space in case of unexpected arrivals. A single 10-car networker formation would fit somewhere as could be split up or moved further out if needed.
Fair enough, maybe keep an eye out on the Beckenham siding in the coming days, as in mid-2021 this played host to a 10-car Networker for at least a few weeks (although only 1 of the 3 units there went to storage soon after).
Class15
30 Dec 2021
North London or Mildmay line
In regards to 465 availability, is it usual for Blackfriars - Beckenham Jcn services to be just 4 coaches? On my way back to north London I saw one of these at Blackfriars and it was just one 465/9.
PGAT
13 Apr 2022
Selhurst
It is the norm they can only do up to 6 coaches because 8 car trains without SDO can’t stop at the short platform at Elephant & Castle
I can certainly see that it’s not ideal for the trains to see service well into their 40s, however it’s a massive stretch to say they should have been replaced “long ago”. That’s effectively a lifespan of 25 years, which is pretty short by EMU standards, and especially so when one considers that the BREL units have had the benefit of retractioning.
Look at how long some of the PEP-derived fleets have lasted, the 313s and 507s in particular. The biggest issue with the Networkers as far as the end-user is concerned has been that the interior ambience just hasn’t been looked after and prioritised, which seems to be a TOC thing - same can be said for many of their stations. The GN 365s were always very presentable inside.
Ridgeblog
20 Apr 2021
Welling
I mean, it is fine for trains to be in service for a long time as long as they are looked after well and meet current safety compliance standards, which is not as hard as may seem as train technology does not move nearly as fast compared to computing or other technology sectors. Look at trains in other countries. But I did say 'looked after well', as the problem is that most of the SE metro fleet are not so great condition-wise, as most can agree.
ScotGG
3 Apr 2013
Agreed. I was on a Networker the other day and it was probably the worst condition of any train I've seen for 10 years since being in Italy. That includes Pacers, Class 150s and numerous diesel stock getting on for 40 years old across the country in that time.
It was in an almost indescribably filthy state and not just from that day but years of grime. The window frames were gone, the seats broken, the floor uneven (is that water ingress?) and both external and internal doors didin't work. I mean nothing in it was in half decent condition. Nothing. Filthy, and falling apart.
andyjhatton
8 Apr 2023
Dartford
Networkers are certainly in an awful interior state (not sure you could use the phrase "interior ambience")
But at least they have toilets; which hardly anything else in the SE fleet does.
I tend to prefer to use Thameslink where possible. Toilets, and aircon. Double win.
Mikey C
11 Feb 2013
The Networkers should have had a mid life update years ago. Imagine if the 455s had stayed in original condition all their lives.
The frustrating thing is that the 465s with the best interiors are the 465/9s, which have/are being withdrawn prematurely.
NSEWonderer
5 Dec 2020
Networkers seem to have suffered the same fate that the 1992 stock did, they were built roughly at a time where technology was advancing at a rapid pace in a short time. Had they been built a few years later they probably would have faired much better on top of a midlife update.
Pre-covid 8 car formations existed, but I'm guessing either they were focused into the right platforms and/or Health & Safety gone mad has happened since then. They do also send a single 376 on some of the peak diagrams.
Nicholas Lewis
9 Aug 2019
There looked after below the sole bar thats mandatory. Tarting up the inside is avoidable expenditure albeit I totally get to the passenger its what will appeal to them and certainly for the optional traveller help give them an impetus to return.
Although you always have to remember that the inside gives a perception of the general quality of maintenance standards and care and attention.
Even if depots operate a two tier system and put more effort into things like brakes. It is very hard to convince someone a tatty train has had selected parts maintained, and not skimped like inside.
Qwertl
18 Mar 2023
Wales
There did seem to be a number of short Networker formations on Friday. That’s shorter than the normal “destrengthened” Friday formations as well.
Will the October budget be a key milestone regarding whether a new fleet order will or won't be signed off?
Stephen42
6 Aug 2020
Beckenham sidings or more unusual locations shouldn't be required, mid-2021 there were a lot of 707s not yet in service in various places on the Southeastern network. This time around it's only a few more units and 4-car Networkers should be easier to hide at the end of a stabling siding if needed though I'd be surprised if a road wasn't available somewhere.
Unlikely. The October budget is setting the departmental expenditure limits for financial year 2025-2026, the replacement fleet will only incur cost after that. The DfT contract pipeline has an estimated award date of July 2025 for the "Eversholt Networker Replacement" and Southeastern would only pay once the first trains are accepted. It's incredibly common for estimated dates to be over optimistic in public procurement.
With a parallel procurement for financing the spending would be resource leasing cost and not the full capital cost of the trains. The aim has always been cost reduction and avoidance, with the ageing fleet predicted to become less cost effective over time. If the proposed business case favours a new fleet as more cost effective it's hard to see it not being signed off. There will be some additional cost during the rollout that should be included for the Spending Review concluding in the spring, but shouldn't be a reason it wouldn't go ahead as overall it aims to save money.
Robski
15 May 2016
Alstom are possibly proposing a level boarding train for Southeastern based on the Adessia train platform.
Hearing that Alstom has put forward a level boarding train proposal with its new Adessia type for train operator SouthEastern which is looking for new stock to replace Networker EMUs. Adessia is Alstom’s next generation commuter train. #levelboarding
Zeremony
28 May 2022
Interesting, I assume they have stopped offering the Aventra platform.
IMO a 701 in Southeastern spec would have been the cheapest option for Alston in terms of development cost although it doesn't have level boarding.
NSEWonderer
5 Dec 2020
How old is the Aventra platform? 15 years old? Think I remember the initial designs and introduction talks in 2009. So seems indeed the Aventra platform may be at its end.
hwl
5 Feb 2012
No Aventra has effective been rolled into the boarder Adessia family as has been covered numberous times before.
It is worth noting that DfT (and SE's ) definition of "level boarding" is actually "unassisted boarding" rather than level boarding taken literally so floor levels may not be what people are expecting - e.g. an angled extending ramp as specified for HS2 may make an appearance
dorsetdesiro
30 Oct 2017
Better not more 701s after the SWR fiasco, best to go a fresh start with the new Adessia platform if Alstom are successful with the SE contract.
These possibly will look similar to the new Xtrapolis DART+ commuter fleet for Irish Rail.
