Southeastern metro fleet replacement/improvement
ScotGG
3 Apr 2013
Another factor that may see the Treasury/DFT block any new order and replacement soon is that if funds are limited in this parliament, wouldn't replacing 40 year old diesels take priority? Also helps with "not London again" viewpoint when it comes to rail improvements and so Northern would see the emphasis for any new train orders to get rid of Class 150 etc. There's already a tender for that.
That keeps Networkers going for another 5 years (using parts from displaced stock now in store or heading there) before any order when they'd all be around 35+ years of age and replaced at 40+ years of age.
SolomonSouth
25 Feb 2021
Gravesend
I know this statement is directed at the Met-Cams, but the BREL/ABB have deteriorated a lot recently.
I’ve been on quite a few and most have had a motor off. If not that, they have had something else broken, whether it be the roof fans, heating or a toilet - not to mention 2 of them (465178/005) are stuck in the Grosvenor wall siding. Couple this with the fact that the early 2020s golden spanner awards (2020-2022) have the /9 and 466 listed as more reliable than the /0 and /1, and it could throw a spanner in the works for SE if not monitored.
SolomonSouth
25 Feb 2021
Gravesend
You certainly can encounter Met-Cams with disabled motors but it seems far more common on the BREL/ABB.
gmaguire
29 Dec 2021
That only really works for them if some BREL units end up in store. At the moment it’s all Met Cams in storage and hardly any parts are interchangeable. Plus the two types are owned by different companies.
delt1c
4 Apr 2008
Another problem with privatisation where stock owned by leasing companies and leased to operators
43096
23 Nov 2015
Not really. The division is all about the builder rather than the owner. Eversholt own the ABB fleet and Angel the Met-Camms. If parts aren’t interchangeable then ownership is irrelevant.
TT-ONR-NRN
30 Dec 2016
Cambridge
Why have the 465/2s not been scrapped yet?
That would explain the state of one BREL unit was experiencing when I travelled between Gravesend and Crayford on it between Christmas and NY just gone: the rear unit (can't remember the ID), had its 2nd carriage out of order and the rear motor was turned off. Compounding it was the front unit toilet was out of order; while this is common even on reliable new units, in this case it meant someone sat in the front unit needing the toilet would have to alight and re-board in the rear unit, but if they get in the first carriage of that unit, they still couldn't get to the toilet.
Could this mean when the 377s come over, it's BREL units that go to store instead of MetCams? When 707s came over, as well as reliability, the common fleet owner (Angel) meant MetCam displacement made sense. But with 377s, the owners are different anyway, so if there are BREL units with the lowest reliability out of all the Networkers, they'd make most sense to withdraw.
Stephen42
6 Aug 2020
I've lost track of this. Tender announced about two years and three months ago. Is that normal to wait so long? When/if will any decision be announced?
Hope I'm wrong but I can see DfT cuts putting the blockers on. Lease costs will be high with interest rates being what they are and the treasury doesn't seem too keen to fund the higher subsidies that will require.
With 13 Class 377's heading over that could displace Networkers as part donors could that keep the overall fleet going for another 5-10 years?
It's not unusual for a fleet of this size, the fleet itself is expected to cost roughly £2bn at the upper end of the vehicle count. If an award is announced it is expected to be July this year (though procurement dates are known to slip).
The new stock was always on the basis of a positive business case. The existing fleet will become harder to maintain increasing cost and a new fleet allows higher capacity per vehicle, better targeting of longer formations through reduced operational requirements, higher reliability and availability. Some existing users will not like some of those aspects, but it will be important to the case. The leasing cost may be higher initially - at some point there will be a crossover where the older stock no longer is cost effective.
Even with the current award the last Networker may be in service 5 years from now, it will take several years to build a fleet of that size without adding the testing time and rollout period.
The deals are largely separate, it is all resource spending rather than capital spending due to the leasing agreement. The subsidy position for each becomes relative to the leasing the existing stock and independent of other deals. The Southeastern deal started first and would naturally be in a position to award first, getting it announced may mean a supplier who lost out on that one is more prepared to lower costs to win the Northern one.
The Northern tender timeline is aborted procurement started August 2023, restarted May 2024, shortlisted announced this month, award estimated Spring 2026. Southeastern is November 2022, shortlist announced May 2024, award estimated July 2025.
It's up to Angel Trains to decide to scrap them. The Networkers have an outside shot at producing more lease income, they could try to compete with the Eversholt once that deal expires or offer some back if the Eversholt ones run out of parts and have to be withdrawn before replacement stock is in service. If keeping them stored is cheap enough or covered by a retainer on storage space it might be worth the risk.
SolomonSouth
25 Feb 2021
Gravesend
In fact, I think some BRELS were stored at one point. I remember a few being dragged in 2022. They are all back now though.
Still, I wouldn't be surprised if some BREL/ABB units went to storage when the 377s come over. They are definitely less reliable - in fact they always were less reliable, and I suspect the storing of the Met-Cams was due to common ownership with the 707s like you said.
In any case, almost no matter how many they store, they will still be the majority Networker on SE anyway. There are 97 BREL 465s to 50 Met-Cam 465s, some of which are stored anyway.
If those two examples are a normal duration for just getting to the point where an order is formally made, something is seriously wrong with our system. But that's another debate entirely.
SolomonSouth
25 Feb 2021
Gravesend
Here are screenshots from the 2020 and 2022 Golden Spanner awards to help substantiate my claim of the /9 and 466 being more reliable than the /0 and /1. As seen in the last image, the 465/2, although less reliable than the /9, was at a similar level to the /0 and /1 (and had the redone floor to boot).
hwl
5 Feb 2012
Having one fleet of 4 car 465s would make life far easier, >75% of the 4car networker fleet is now BREL/ABB/Hitachi.
Generally the MetCamm/Alstom ones have been less reliable, more problematic and have more issues on some parts availability.
But the incoming 377s won't be enough to withdraw all the MetCams still running, unless Southeastern are prepared to take a major fleet cut. 13x 377s vs 24x 465/9s and 30x 466s, the difference is stark.
My understanding was that Southeastern needed the stabling space for the first 18x 707s, but also wanted to get the most out of the 465/2s before they went to store (i.e. clock up the miles to the point of their next service/overhaul, then send them off). Therefore, it made sense to move out a few BREL units on a temporary basis to warm store elsewhere (in this case Worksop), then once all the 465/2s were ready to send away, those BREL units returned.
If you add the 43x 466s then in terms of numerical units it's 97x BREL, 93x MetCam, so while BREL was always in a majority on both carriage and unit tally, it was not a huge majority for most of their life.
gmaguire
29 Dec 2021
Does a carriage out of order necessarily indicate a fault with the train? Perhaps someone had thrown up?
The fans seem to be computer controlled. Some can run at different speeds while others can be off.
Don’t think I’ve run into a BREL with non-working heating yet. Recently I’ve been looking forward to getting on the train in the morning since the BRELs are always so nice and toasty inside.
SolomonSouth
25 Feb 2021
Gravesend
I find that Met-Cam heating seems stronger, but that's likely due to the windows not opening as far on them.
Geogregor
16 Sep 2016
Southestern is using LIDAR to scan all its metro routes platforms as a part of procurement of new trains:
As part of the ongoing work to upgrade its Metro fleet, the Southeastern and Network Rail Alliance has appointed Cordel to provide accurate data and imaging of all platforms on the metro network.
Cordel has installed sensor technology on two Network Rail maintenance units, using Light Detection and Ranging (LiDAR) and AI-processing services to provide 3D models and highly accurate measurements of all Southeastern metro station platforms.
This information will then be used to help support manufacturers' design work to maximise unassisted boarding across the Southeastern Metro network. This is a key part of Southeastern’s commitment to vastly improving capacity and accessibility through the introduction of new or improved trains on the Metro network.
gmaguire
29 Dec 2021
For me it’s been the complete opposite. The BRELs have fan heaters under the seats by the doors, which I don’t think the Met Cams have.
SolomonSouth
25 Feb 2021
Gravesend
Currently on a really poor pair of BREL/ABB. Both 465022 and 465176 have half their motors off/broken. We’re crawling up to speed.
Not the first time I’ve had something like this happen with a BREL pair, but never had anything near as bad with a /9 pair.
The DfT procurement spreadsheet shows 350-640 vehicles as quantity to replace the Networker fleet.
Allowing for the 377s arriving, will be about 500 (active) Networker vehicles (class 465 and 466) to replace
Geogregor
16 Sep 2016
Networkers are basically falling apart. Every day there are faults which take sets out of service.
I do wonder how long they can use duct tape, wire and parts from cannibalized sets to keep them running...
But then if the TfL can keep Bakerloo Line trains running despite their technical death then I gues SE can keep Networkers patched up for another decade.
Recessio
4 Aug 2019
Any unit can be kept going, it's just a matter of it eventually becoming extremely expensive. I think the old tube trains on the Isle of Wight were nearly 80 years old by the end! Quite a target for Networkers to beat that
350401
5 Feb 2009
Are southeastern having an issue maintaining the networkers in service then judging by the thread? Anecdotally I am noticing a lot more short formations on south eastern these days. 4 car trains on the Victoria to Orpington service seems to becoming very common now. Today, the 13.00 via Denmark Hill, and 13.03 Bromley South to Victoria via Herne Hill were all formed of 4 coaches. Last night, the 23.25 Victoria to Gillingham was only 6 coaches and sardined - with one of the toilets out. Are the days of 8 coaches on SE metro coming to an end?
PGAT
13 Apr 2022
Selhurst
Those services are allocated 4 coaches
The examples you've given are off peak services. Southeastern usually shorten services then and extend them in the peak. This is especially common on services out of Victoria and Cannon Street (Charing X is usually in high enough demand to keep 8/10 car formations all day).
GEC465
10 Mar 2016
So someone sent this in a server im in. Any info on this?
(Image is a class 465 driving coach in Network Southeast livery with a GWR 769 beside it)
LUYMun
15 Jul 2018
Cancelled
Allegedly it’s 465908 and it has grey doors to make it compliant with disability requirements.
Do we know where that is? I'm guessing this is a restoration to the unit's first livery. The only thing missing from that shot in this instance is most units had white bordering round the windows, but it's possible this isn't finished yet.
