Southeastern metro fleet replacement/improvement
If Networkers go for C4 overhauls, can we see one in GBR livery?
The overhauls are being done by sending the moving parts away to Crewe, but not the whole train, so chances are no new livery will be applied at all because the units are not going somewhere this can be done. 465908 got its NSE livery while having a C6 overhaul, which focuses on the body so made sense there.
If any SE unit gets GBR livery, I think a 707 and/or 377 is more likely (707 as the newest fleet, while several 377s in Southern livery would be ideal for a new paintjob that actually has value to Southeastern).
Islineclear3_1
24 Apr 2014
PTSO or platform depending on the weather
Fair enough. I've no idea what a C4/C6 overhaul is nowadays; this may have changed from BR days. So does this mean, a unit has its "un-reconditioned" bogies and running gear sent to Crewe and waits for a reconditioned set to return before being returned to traffic?
Doomotron
25 Jun 2018
Kent
At this stage we don't even know if 304 will be written off, depending on how damaged it is.
From the photos the unit seems to have held up quite well, and (I think, could be wrong) it didn't derail at high speed either. It's impressive how much stronger trains have become in the last 40 or so years. I wouidn't expect it to be a write-off, but if it was I doubt the Networker replacement order would be changed since it's seemingly been signed already.
Mattplans
27 Sep 2024
London, UK
Are networkers having seats removed?
-seen on twitter
HQJ0R7DXsAA0P_h
hwl
5 Feb 2012
-seen on twitter
No that was 1 unit that got modifed ~ a decade ago for a trial (I forget what for, but the unit was chose becasue it had been involved in an incident shortly before hand)
Goldfish62
14 Feb 2010
The September Modern Railways reports that South Eastern have reached a decision on the Networker replacement and hope to place an order by the end of this year.
South Eastern Railway has made the decision regarding the train it wants to order to replace its Networker fleet, with a business case now being evaluated with the hope that an order can be placed this year.
Speaking to Modern Railways at Hither Green on 20 July, SET Managing Director Steve White said the operator had run three parallel procurement processes with one looking at possible cascaded stock, one at new rolling stock and one looking at the finance for new rolling stock.
Mr White said of the current progress: “We have selected our preferred manufacturer and we have submitted the business case for approval. If the business case is approved, then we will sit down and negotiate contracts with the preferred manufacturer. We’re really excited about that. It’s been a long process to get to this point, but we’re very confident we’ve found the right product for this railway.”
It is good that this is progressing.
However with both Scotrail (who apparently have moved onto a shortlist of 5 manufacturers), Northern, and GWR all looking to place orders sometime soon, I do wonder if there will be a clash of production capacity
Presumably if South Eastern place an order (and it was going to be around 350+ vehicles, maybe 500+), then factory capacity (and component supply) becomes more restricted for whoever follows unless they are prepared to wait for build slots At a later date.
Goldfish62
14 Feb 2010
Depends which suppliers they all go with. If they all go for the same supplier I imagine that could present issues, but there's all the usual suspects in the bidding.
I can't see any TOC going, "we're not going to bother ordering now in case someone else chooses the same supplier and delays things".
I was thinking from different perspective, might have got indicative build timeline from a manufacturer months ago. But if that manufacturer gets a big order from elsewhere in meantime, then those dates would slip.
We already know hundreds of EMU and BMU carriages have been ordered in 2026 by European operators. No manufacturers are going to build a completed train if important components are delayed because the parts supplier has orders for next 2, 3, 4 years.
It is a limitation of buying in parts (rather than making in house) could be bearings, door components, wiring fittings or whatever. Imagine a scenario where get something like can't fit toilet roof tank, because toilet module needs to be inserted first, but they are delayed months. Whole process logjams.
The other point is that if planning to order replacement trains, it determines when stop expensive heavy overhauls, or life extension work on existing fleet. Get timeline wrong and incur extra costs of patching up current fleet, or incurring penalties on lease return, or extra expensive short term lease extensions where backed into a corner if need bridging period until new fleet ready
NCT
18 Apr 2025
In the grand scheme of things British orders are a drop in the ocean (OK I exaggerate slightly) compared to the entire European order book.
On the other hand, wasn't Derby churning out Aventras for just about every TOC under the sun not all that long ago?
hwl
5 Feb 2012
Given the delivery time periods being discussed e.g. Scotrail BEMUs in 5 years time, GWR kicked into the long grass, Transpennine gone very quiet and slow Northern unit delivery, the delivery rate isn't that high so most OEMs bidding could theoretically win all the orders and still deliver.
The reality is that CAF and Hitachi would struggle to deliver even a small number of well built units even at low rate (note the "everyone is looking at you comments" with EMR issues recently, Stadler will be expensive and not tick the "made in GB box", Hitachi would struggle with any reasonably sized order so would presumably try to build some in Japan /Italy which might not work politically.
The recent 345071 delivery and quick entry into service might be pushed by Alstom to exorcise any 701 ghosts (now some what acknowledged in GBR controlled era as SWR no being ready for a rolling stock introduction process on a huge scale e.g. staff shortages). Siemens have shown they can churn 2024 stock out of Goole albeit with many challenges to resolve to get them into service.
Some of the TOCs with procurements open probably only have 1 or 2 OEM what can actually tick all the boxes in sensible way (especially battery requirements) so just as well the required delivery rates aren't too high.
The MetCam Networkers have C6 overhauls due around the end of the decade, so the first units will need to arrive by then to avoid a serious shortfall. I don't know when the BRELs are due a C6, however they're getting C4s this year, which suggests they could be given one more C6 before withdrawal.
Mikey C
11 Feb 2013
I'd be staggered if Derby doesn't get this. Especially now you "can't blame the private operators" any more, and with the volume of carriages being talked about.
Siemens could do it in their European factories, but that won't happen this time.
JCO1406
28 May 2024
I wouldn’t be surprised if it’s Alstom or CAF that wins the order. Siemens would be good for Goole.
I doubt Hitachi would be getting anything for a while after whats happened with the 810s.
Personally, I would like Stadler to win this order, the Flirts are amazing trains and would like to see more of them around, but I doubt they’ll win as they don’t have a UK factory unless one gets built.
Siemens will have more than enough work with the 2024 stock for both the Piccadilly and the Bakerloo lines, so won't be selected unless they have capacity to build multiple fleets at once.
NCT
18 Apr 2025
Have our procurement rules changed so much since Brexit that awards can now be flagrantly made on political grounds?
No, but politically can stop legal disputes by giving everyone an award, effectively giving everyone a piece of the cake and making them happy
example (not a prediction)
South Eastern goes to Alstom at Derby
Siemens at Goole gets Bakerloo order confirmed
Hitachi gets some additional 807s (plus battery pack conversion of other IETs)
CAF gets some more of the Express 897
With Northern needing new trains, and a fleet crisis on GWR due to growth so there is desperately needed regional BEMU order for somewhere like Cardiff-Portsmouth and Salisbury-Waterloo and Oxford-Paddington allowing diesel cascade. There are lots of options to place multiple orders, if GBR / DfT etc wanted to for political reasons
Goldfish62
14 Feb 2010
Siemens at Google gets Bakerloo order confirmed
Stadler needs to be in there somewhere given that it's one of the shortlisted bidders. :)
hwl
5 Feb 2012
Don't forget Scotrail, HS2, Northern, TP and open access stock...
Open access - have been flocking to Hitachi (more Hull/Lumo stock)
HS2 - Hitachi again and some Derby/Crewe work from Alstom
LNER - CAF Tri-modes
TP North (i.e. via Huddersfield) - potentially replacing everything (inc. 802s TBD) 200m EMUs, 150m Multimode-EMU
Northern - out for tender but a real mishmash of unit specs
Scotrail - Siemens to lose?
TfW - More stock in few years time
Two OEMs are unpopular given recent form on deliveries (both with "new" GB factories). (many "never again" recommendations from current operators)
One OEMs is "reassuringly expensive" - which kills them on any larger order
One OEM is generally liked but under the microscope on a recent BEMU order overseas
One OEM is generally liked.
Some more TfW and potential Northern's bi/trimodes? They also have plenty of orders in Europe to worry about delivering.
I'd argue awards have been functionally made on political grounds for decades.
The science of backwards engineering tender specs to assign trains to the desired plant appears well developed.
NCT
18 Apr 2025
If that were the case the Thameslink order would never have gone to Siemens, nor the IET order to Hitachi.
The Hitachi order allowed ministers to cut the ribbon on a new train "factory" in Newton Aycliffe, which is highly desirable. Positive headlines and press releases etc.
The Crossrail order was awarded to Derby very shortly after the Thameslink order, which rather drew the political sting. And I believe Siemens have a giant footprint in the UK in components terms.
Farigiraf
23 Jul 2023
Bridge on the River Cam
Slightly off-topic but what'll happen with SWR, EMR, Southern and Chiltern aging DMU fleets then? Plus the many extras that TfW will need if they deliver the planned network upgrades (and also 153 replacement).
Most late-era BR trains (from the last time that mass fleet replacements were really in action) are expiring now and I don't see GBR or the DfT being particularly ready for it, let alone the Treasury wanting to fund it. Wouldn't be surprised if we still see a few 158s, 165s and 171s around in the 2040s.
Mikey C
11 Feb 2013
It's massively naïve to think that orders aren't placed politically. There's always a way to favour/protect one supplier.
Can you imagine Transport for Wales giving their entire order from a few years ago to Stadler (and say Alstom) with nothing for the CAF Newport factory? It would have been politically disastrous for the Welsh government.
Also, I very much doubt Siemens would have got the 2024 Tube stock order, and the expectation of further follow up orders, without the Goole factory.
Chris172
3 Feb 2018
Is there a rough date for the winner of the bid to make the new trains for SE? Have they announced the classes like Northern did? I assume Northern are in a similar situation with their announcement?
Various dates have been mentioned over last 3 or 4 years, which keeps moving later, so to some extent have to treat them as a very rough target.
More practically various European Operators have placed orders in last few months, so some parts and components might be in a queue from the limited number of suppliers. I would think looking at 3-4 years if adapting existing design, maybe 5 years if it is completely new design and needs development and testing.
So I suspect 2030 or 2031 before a decent number of whatever gets ordered, are in everyday service.
