South Wales 'Metro' updates
Well that's easily solved with a contactless Oyster card like London's. You can just top that up online or at a station.
Or for excellent coverage a deal with Paypoint/Payzone. That gets you access to just about every local shop.
FWIW, Croydon Tramlink have found so few people are using their TVMs that they're going to get rid of them. And like London buses, Tramlink carries lots of the kind of people (poorer socioeconomic groups, I mean) that this forum seems to like to allege can't deal with card payments.
Gareth Marston
26 Jun 2010
Newtown Montgomeryshire
Thankyou NotAtrainspott
Cutting an existing HR service like you describe has significant problems. What would happen in the Valleys is that the entire service would be converted,
Thats entirely mine and lots of others peoples point. We have been talking about the disbenefits of Transport for Wales proposal to split Valley Lines and create a smaller "Core Valley Lines". You have been so wrapped up in promoting what you see as the benefits of light rail per se you've not absorbed this crucial point. The entire service is not being converted only the existing lines that serve 3.5 of the 10 Unitary Authority areas in South Wales. The rest are being left out. Real World stuff not theory.
B&I
1 Dec 2017
The Merseyrail solution of splitting HR services isn't acceptable now. In Manchester, the only service that was affected by conversion without being able to be converted was the Chester one. Even then, this was simply diverted via Stockport rather than cut short. Cutting an existing HR service like you describe has significant problems. What would happen in the Valleys is that the entire service would be converted, because the lines are dead-end branches and a split would be worthless and operationally impossible. LR not being suitable for the suburban parts of through routes in one city does not mean it becomes unsuitable for physically separated branch line routes in another.
This is just nonsense. I don't want to cut spending on public transport. I want the money we do spend to go as far as we possibly can. With that, you can justify having things that we cannot have otherwise. For the same cost you can have a lot more LR than you can have HR, delivering much more for local communities while being operationally self-sustaining. The best way to protect public transport against people who don't like it is to make sure it's able to stand on its own two feet and not be dependent on the kindness of strangers.
Also, I'm sorry, but how does 'nobody actually wants to use it, unless they really have to' square with Metrolink being busy every day? What you cannot argue against is the concrete fact that Metrolink takes in more ticket revenue than it spends on running the network. If Metrolink was a disaster, that simply could not be true. If a system is capable of making an operational profit, that means it's doing something right. Bad schemes can't make money. If Metrolink was that crap, the unregulated bus operations in Manchester would be making a killing by competing against it.
The higher capacity of a heavier rail system is only required because passenger numbers have grown. Passenger numbers have grown because Metrolink has been a success. If Metrolink were a failure, passenger numbers would have stayed static or decreased, and there would be no need to ever think of upgrading it. Isn't that obvious?
No, the only real cost-saving measure you can do on HR is to run DOO. While that helps, it's nowhere near enough. You still have to pay HR drivers' salaries. You still have no choice but to install lifts or massively expensive ramps to provide accessibility. You still have to maintain the track for trains far heavier than are really required to move the people about. If you want to reopen or extend a line you have no option but to build expensive tunnels and bridges to separate the track from even the lightest traffic flows. Your stations still have to be where the railway could be built, rather than where people actually are and want to go. Essentially anything that suburban HR can do, LR can do too. The same is not true the other way around.
How many cities in Germany have an U-Bahn? Berlin, Frankfurt, Hamburg, Munich and Nuremberg. That's really not that many cities. How many have tramways? I count 57 cities and towns with tram and Stadtbahn networks, according to Wikipedia. Clearly the Germans think that tramway and Stadtbahn networks are more universally suitable for medium-sized cities.
It's a mistake to look at population figures. The numbers which really matter are about density. Los Angeles is a huge city by population standards, but it's one of the least dense major cities in the world. Density is what makes public transport actually worthwhile and necessary. Only when you have very large volumes of people moving along certain corridors in an urban area is the cost of building permanent public transport infrastructure worthwhile. You don't need to have Manhattan or Hong Kong density to justify a tunnelled metro. Instead, you just need long corridors of consistent medium density - think three-four storey tenements - making up the core of your urban area. Extensions into proper suburbs are acceptable when the incremental cost of extension is smaller than the benefits you receive. But, if your city consists of lower-density suburbs essentially all the way into the urban core, the sums just don't stack up. While the cost of construction might be slightly lower, the number of people within practical walking or quick public transport transfer distance from any prospective metro line is too small.
On top of that, the transport priorities of people in lower density areas are also likely to be different. In a higher-density area, people are more likely to have work, study, retail and leisure opportunities again within walking or public transport distance, making them more dependent on public transport in general. In a lower density area, public transport is less of an option and other developments don't happen with as much expectation of it. In a dense city built on public transport companies have little choice but to put jobs within reach of public transport. In a lower-density area companies can just rely on people having their own car, and putting them in cheaper but less conveniently located places like business parks off trunk roads.
When you've got people dispersed over a wide area of lower density, your choice of transport system has to accommodate it. LR is better at handling lower densities than HR, because it can affordably penetrate lower-density suburbs built far from feasible HR routes. It can provide some transport, rather than none. When densities and possible passenger numbers are lower, it can affordably provide a good enough service for the people who are able to use it. The 10tph service to Altrincham is great for the people who are increasingly able to and dependent on travel via Metrolink. The alternative is that they have to pay for the capacity for lots of people who aren't currently able or dependent on travelling, or that the service is dialled back to be more affordable to run.
People use Metrolink BECAUSE HEAVY RAIL HAS CLOSED DOWN AND THERE IS NO ALTERNATIVE. What about all the people who would like to use rail-based public transpirt but can't, bevause there's not enough space on Metrolink to carry them? Who is to say that, if Picc-Vic and the accompanying suburban railway improvements had gone ahead, the millions using Metrolink would not be using those systems instead, in line with the general upward trend in HR use?
Re Germany, statdbahn are modernised street tramways. The larger, more successful German cities - the ones ckmparable to Greater Manchester - have not followed the Manchester model of turning HR into LR. At most, a number of smaller German cities, many in the still-depressed east, have run extensions of LR services onto HR tracks (without kiboshing the latter for HR services, unlike Manchester). Conveniently for your argument, you omit the fact that 14 German conurbations have S bahn systems. Of course, some of them have tramways as well, but they're there to supplement HR services, not to substitute for them.
Similarly, I don't think anyone here argues that there is no place for light rail. In Metrolink's case, the airport, Eccles, Ashton and Trafford Park lines are useful ways of serving their respective areas. All of them, however, could be built without removing HR capacity.
Your argument is utterly contradictory. On the one hand, you argue that LR Iis required everywhere to avoid spending money on excess capacity. On the other, you acknowledged that LR no longer provides sufficient capacity in the city which has been the poster child for conversion of HR to LR, and that substantial extra spending is now required as a result.
The way to secure a viable future for public transport in this country is to provide proper services which encourage more people to use them, not to pander to politicians and civil servants who fundamentally hate non-private car users by providing token systems which can't carry the people who want to use them.
That scenario is far more likely on Manchester's inadequate HR system than Metrolink. And you can up capacity on both, either by running more trains/trams or longer ones, so it's a non-argument.
NotATrainspott
2 Feb 2013
No.
You said the if LR is great, then it should be implemented in the West Midlands. You said this would happen by converting lines and then running heavy rail shuttles from the end of the LR line to towns further out. This is what happens on Merseyrail at Kirkby, Ormskirk and Bidston. This is what cannot happen in South Wales, because the lines in South Wales are branch lines. The equivalent would be having an HR service at the top of the Valley running to somewhere lower down the Valley, where all passengers would be forced to change trains to get anywhere near Cardiff. That's a nonsense. The fact that there is no reason to ever do this in Cardiff is much of the reason why full LR conversion all the way into Cardiff city centre is possible. Because the Valley lines are only suburban branches, and not a suburban part of a longer line, it means it's practical to convert the whole thing at once.
Dai Corner
20 Jul 2015
No.
What many think/fear will happen is a LR service from the tops of the Valleys running to Cardiff Queen Street where all passengers would be forced to change (or more likely walk to Central) to get a train to the rest of the current local or main line network.
gareth950
3 Nov 2013
Part of the 'Metro Central' plans for Cardiff include 'public realm improvements to encourage walking and cycling between Cardiff Queen St and Cardiff Central'.
Make of that what you will.
PHILIPE
14 Nov 2011
Caerphilly
Does that include people with lots of luggage and in the pouring rain. Maybe not so silly when you think of some of the scatterbrained ideas the Welsh Government come up with.
Dai Corner
20 Jul 2015
Will there be bicycles to borrow/hire or are people expected to take their own on the tram or train, manouvering them through the crowds and up and down stairs or in and out of lifts at Central and Queen Street?
NotATrainspott
2 Feb 2013
People don't have to use heavy rail. There are bus services, and people can drive. Buses run closer to where people are starting and finishing their journeys, while cars have maximum flexibility. For rail-based transportation to compete, it must be better at popular sorts of journeys than either option. Metrolink, by virtue of making an operational profit, is clearly doing so.
What did the Altrincham and Bury line timetables look like just before conversion? The number of seats on a train isn't the only story. The theoretical capability to run a high capacity service means nothing if operational and economic concerns limit it. If you turned up at Altrincham in 1990, how long did you have to wait before you could catch a train to Manchester? Today, you have to wait only about 3 minutes on average.
Have passenger numbers generally grown on Metrolink every year? If so, and there's not enough capacity today, wouldn't that mean that back in 1990, passenger numbers were lower? If there has been growth and it is now that there's not enough capacity (Metrolink frequency to Altrincham is restricted by the single-line section at Navigation Road), then clearly back then there was enough capacity. If there was enough capacity back then, and passenger numbers hadn't fallen off a cliff when conversion happened, then the number of people using HR services was also low back then. When passenger numbers are low, the immense cost of a tunnelled metro line is not justified. When passenger numbers are high, it becomes more justified. Metrolink has caused passenger numbers to increase above and beyond what was possible with any other sort of system, thereby making a tunnel more essential and worthwhile in future.
Again, you cannot simply compare population figures to justify transport decisions. German cities of the same population as UK ones tend to be far more compact as they didn't see so much suburban sprawl. We would be more comparable to Germany if we had decided not to build the New Towns and instead rejuvenated medium-density areas. Without significant areas of medium density, you simply cannot justify the cost of tunnelling. Indeed, it's also harder to justify even a street-running tram system. Of the tram systems in the UK, only Sheffield, Edinburgh(*) and the latter extensions of Manchester Metrolink are not focussed on taking over rail alignments. When you've got a rail alignment to re-use, lower density isn't so much of a problem as the infrastructure cost per kilometre drops significantly.
(*) The only line yet built in Edinburgh spends most of its time following the E&G. However, the system was designed primarily to serve Leith Walk and running down to the BioQuarter along the streets.
Larger cities will have more space on the transport spectrum for independent systems to exist. Megacities like London and Paris can easily justify everything from buses to heavy rail metros existing alongside one another, as they individually have more than enough demand to be economically viable. Smaller cities don't leave so much space on the spectrum, making it more likely for the systems to address multiple needs. Using Leipzig as an example, the new S-Bahn tunnel exists alongside a dense tram network but leaving little space for an U-Bahn to be necessary in between. The sorts of journeys that would be done on an U-Bahn in a larger city get split between tram and S-Bahn so that there isn't massive duplication of resources while all journey requirements still get addressed.
In Cardiff, the problem you've got is that the population and density isn't high enough right now for a tram network to exist alongside a heavier rail network and buses. The only way of making a separated tram system viable would be to take enough passengers off heavy rail for heavy rail to become unviable. Therefore, if we're to address transport needs that aren't served by heavy rail, we have to look at changing the nature of the existing heavy rail system so that it can scale down to these needs without losing out on demand at the upper end.
As I repeatedly say, LR technology is by far the most flexible of any rail-based transport mode, as you can pretty much use any sort of line you want. If you really need to have a segregated line, you can run it with the same trains and using the same technology but without ever ending up running on the streets. This is what happens on the RandstadRail network designed by those most public transport-friendly of peoples, the Dutch. Using T&W Metro-style through running you can have a light metro take over existing HR routes without requiring those tracks to be converted.
What the Metrolink conversion of the Altrincham and Bury lines has done in Manchester is provide the framework required for the other pure street running lines to be built. The lines to Eccles, the Airport and Ashton would simply not have happened if Metrolink hadn't built the expensive street running core in the city centre. The densities along these lines are simply not high enough for them to justify all the infrastructure they would need, but they are high enough to justify it if something else paid for the most expensive fixed costs. When these lines were built, the fixed costs of providing depots and city centre street running and operational control centres and ticketing systems and so on had already been paid. The bigger the network gets, the less significant these costs become. Once a line is built, urban development adjusts to suit and densities naturally become higher. Now that Metrolink exists, there's much, much more interest in building medium-density urban environments along these lines. As these develop, they increase passenger numbers. Before long, the pure street running Metrolink lines will have enough passenger demand to justify their own existence. They'll no longer need the converted HR lines as scaffolding. There'll be more space along the spectrum for independent transport systems to co-exist.
The example used was LR to Kidderminster and then an HR shuttle to Worcester. That's the Merseyrail example, and it means people have to change trains essentially at the edge of the suburbs. Cardiff Queen Street is not at the edge of the suburbs. It's about as far from the shopping area as Central.
I don't believe we're going to see a mass service split at Queen Street, because doing that would be operationally inconvenient for the transport operator more than anything else. At most any extra services running up the Valleys on top of today's service would run onto the streets or down to the Bay, but a split would require actual extra infrastructure spend for no obvious benefit. The people saying there has to be a split are the people saying that NR are going to say no to a HR-standards-compliant LR train running on their metals, or that HM Treasury is going to push for guards and HR costs to be retained in perpetuity in Wales rather than paying a small extra capital sum and getting rid of them forever.
gareth950
3 Nov 2013
From: https://www.walesonline.co.uk/business/business-news/new-vision-sees-cardiff-central-14157440
"Improvements to public realm north and south of the station [Cardiff Central] and between Metro Central and Queen St station to improve access to the Interchange and to encourage walking."
Llanigraham
23 Mar 2013
Powys
It might do in your urban centres but it certainly is NOT true about rural Mid Wales. In fact I cannot think of any shops here that do it.
Del1977
16 Jan 2018
Canada Water
It's not that far, but it is far too far that you could do it with any sort of luggage. Can't imagine that there won't be through trains between the Valleys and Cardiff Central for interchange.
Dai Corner
20 Jul 2015
Even if the initial intention is for LR vehicles to run through Queen Street into the HR network , the fear is that the 'core' Valley lines will be converted and then the money or political will will run out, Trade Union pressure prevents the extension, or a Westminster Transport Secretary says 'no' . It's as much about the political risks as the technical challenges.
NotATrainspott
2 Feb 2013
There are four Paypoint locations in Llandrindod Wells, for example. One is in Station Crescent so ideal for rail users. https://www.paypoint.com/en-gb?postcode=Llandrindod+wells
Rural and regional lines don't benefit so much from pre-payment, as ticket staff on board are more often able to check all tickets between each stop. Urban transport is different because passenger churn is high, there are many stops, and the train environment is busy enough for ticket checks to be difficult. Onboard staff would probably only reach a small fraction of all passengers using the train. Buses enforce ticket checks by default almost everywhere because you have to get by the driver to board.
The problem with the idea of the money running out is that the minimum technically viable metro conversion is fairly large (it's essentially useless to wire up only some of the 'core Valley Lines' and not others). Anything less than that and none of the expenditure makes any sense at all, as there would be essentially no benefits. Then, the optimum amount of conversion is only a small fraction larger than that. Including Barry Island and Penarth in the wiring job when you're doing all of the rest of the Valleys really would not add that much extra cost, especially if done at the same 750V DC. The BCR of that extra spend over the minimum technically viable conversion is good enough that there really couldn't be better uses for the money. The folk ultimately responsible for the costs of today's network, and who hold the purse strings for any capital investment, are HM Treasury. If Cardiff Bay runs out of cash but the scheme is still worthwhile from the perspective of 1 Horse Guards Road, the cash will be provided.
I don't think it's credible that union opposition would only apply in between the minimum and optimum schemes being implemented. If the unions don't like the end result of the entire South Wales Metro idea, they'll opposite the whole thing from the start. Keeping a few HR services trundling back and forth from Central to Penarth and Barry Island isn't magically going to solve the union problems of LR-converting the rest of the Valleys.
B&I
1 Dec 2017
Is there anything good which has happened in Manchester since 1992 which you don't attribute to Metrolink? What about City's recent good form? Down to Pep Guardiola being able to catch a tram to the Etihad?
Would none of this have happened with proper investment in HR? If LR is really so inherently superior, did HR lines really have to be torn up to enable it to go ahead, rather than (for example) a light rail line being built across the city centre following the 1968 plan from Wythnshawe to Middleton? And must every reference to mega, global or alpha cities be followed by an apologia for penny-pinching in the provinces coupled with colossa-spending in London?
Dai Corner
20 Jul 2015
I was responding to the post that denied any knowledge of Paypoint and similar outlets in rural mid-Wales but eliminating cash, if it were possible, would be beneficial as the cost of handling the relatively small amounts must be significant.
You have greater faith in politicians making rational decisions in the interests of the passenger and taxpayer than I do. As has been posted before, either here or in the W&B thread, there are a number of projects which have been abandoned or not used. Gareth M has written about the WG's desire to get any control they can and to take any opportunity to spite or embarrass the Tories at Westminster (and to be fair, vice versa).
Del1977
16 Jan 2018
Canada Water
Mass transit is viable when there's large population densities. London gets more spending on public transport because of its population density. More people live within 5 miles of me than the entire South Wales region. It's pretty obvious that's going to require more spending on infrastructure.
Is the balance right? No definitely not. There are cities other than London that require better urban transport plus better between city to city transport. I hope the SW Metro project is the WAG's attempt to redress the balance and provide a solution appropriate to South Wales' needs.
Indeed. I can't see any problem with something like the Heart of Wales line or even the Aber/Pwllheli line being Paytrains with all ticketing dealt with on board; they are rural lines with relatively low loadings and on the main section a fairly large gap between the stations. But we're talking about the Valley Lines - even in its present form an urban S-Bahn - and on that kind of setup the most sensible place for ticketing is off the train. A viable second option would be non-safety-critical revenue conductors (either on a tram or heavy rail), like Southern's OBSs or tram conductors in Blackpool and Sheffield, but really the idea of the guard doing doors and tickets simply is not workable on that kind of route (as is being amply demonstrated on the Manchester area local DMU services). As for Edinburgh, I don't understand their approach at all and would love to know how they justified it financially.
Envoy
29 Aug 2014
Surely, it would be best to prioritise electrification of the ‘core valley lines’ along with Penarth & the line to Barry Island - and possibly to Rhoose (Cardiff Airport) and onto Bridgend, over doing anything to put trams onto the streets of Cardiff? This rail system has been treated as some sort of 3rd world transport system for long enough. It is time for the stinking diesels to go from these services with frequent stop /starts between stations.
It is highly regrettable that the UK government pulled the plug on the electrification of the main line from Cardiff to Swansea as that also has local commuting trains in addition to the Class 800’s that stop at Bridgend, Port Talbot & Neath. Had that been done, then I would have thought that the UK government would also have desired to see the Vale of Glam Coast diversionary route also electrified to 25Kv? That being a future possibility, then would they want to see the Cardiff to Barry/Penarth line wired at 750 volts DC as that would mean that if the main line was eventually electrified, they would have to continue to use the Class 800’s as bi-modes instead of reducing the weight by removing the diesel engines - which no doubt, Hitachi would wish to see happen?
Would it not be prudent to electrify the core valleys to 750 volts DC and the Penarth & Barry lines to 25Kv and have dual voltage trains (or tram-trains) - with possible battery operation between Queen street & Central to stop conflict between the two overhead electrical systems? This would also solve one the main critical points made on this forum about the metro > the lack of through trains between the valleys and the coast plus the splitting of the suburban City Line - which almost encircles Cardiff.
Of course, they could do the whole Valley Lines to Coast system as 750 volts DC and in the event that the mainline is closed between Cardiff & Bridgend (assuming it was electrified to 25Kv) and the Class 800’s had diesel operation removed, then surely, the local trains could be used to shift the mainline passengers between Cardiff & Bridgend?
Assuming that the present Manchester to west Wales diesel services remain, then of course they could continue to operate whatever happens regarding electrification.
(An increase in the frequency of trains (or tram-trains) on the line through Rhoose / Llantwit Major would not only solve the overcrowding issues on this route but should also negate the need for the Welsh Government to continue spending money on the bus link to the Airport from downtown Cardiff. This route is also the quickest way between Barry and Bridgend & points west).
Del1977
16 Jan 2018
Canada Water
Then that is for the people of Wales to consider when voting for their AMs. Either they'll decide that the current political situation suits their needs, or not.
It comes down to this - Gareth M and others may be concerned about the motivations of the WG. Public transport is a political decision owing to the money involved for infrastructure, subsidy of users and fares paid by travellers. The way to address concerns is through the political process.
Preempting the next response that people will vote for Labour anyway, or Labour will get in anyway through the way the d'Hondt system works - well then, obviously these concerns about public transport are either not widely shared, or on balance, considered less important than other matters.
I absolutely agree. The DMU has to be on its way out alongside the diesel car, or in 20 years' time (possibly even within 10) there will be huge pressure to close these fume-belching DMU railways in favour of electric buses and even electric cars. The railway is in serious danger of losing its environmental credentials.
Any DMU based solution that doesn't involve bi-modes and a plan for medium term electrification has to be dead.
If 750VDC electrification is cheaper, that might not be a bad idea. Or use dual voltage trains of some kind. I wonder how much it would cost to convert a Class 319 to take either 25kV or 750VDC from the pantograph (given that it already has 750VDC circuitry for the third rail), or perhaps to add a second one?
B&I
1 Dec 2017
I strongly suspect that even with the high spending in London it still subsidises the rest of the country.
There is only so far that argument takes you - into a vicious circle of continued centralisation and regional decline, for example
Del1977
16 Jan 2018
Canada Water
Public spending per head in Wales is greater than England as a whole and any English region, 99% of that in London but less than that in Scotland or Northern Ireland.
http://researchbriefings.parliament.uk/ResearchBriefing/Summary/SN04033
Right. Current spending is higher in areas where there is more need.
But if you compare the tax take versus public spending - London spends £3k less than it earns in taxes, Wales spends £4.5k more than it earns in taxes (all per persons).
https://www.ons.gov.uk/economy/gove...alpublicsectorfinances/2015to2016#main-points
cactustwirly
10 Apr 2013
I believe the cost of heavy rail, is far outweighed by the economic benefits that it gives the valleys.
Bit of background, the valleys are on their arse economically, meaning that there are very few jobs.
So to get a decent job you need to commute to Cardiff, to do this you need a reliable transport system. The car isn't really an option because of the large upfront costs and congestion.
Which leaves the train as the only viable option, if you close the valley lines to convert them into tram lines, then this could have a detrimetal impact on the economy of the valleys.
Obviously you'll get the same effect if you convert the tram to street running in the centre of Cardiff, the tram would become very unreliable and people could lose their jobs as a result.
Therefore conversion to LR looks good on paper, but in reality could end up costing the taxpayer more.
