Scotrail Class 385 Discussion
Tam
13 Aug 2017
Czech Republic
385002 and 385101 snapped at Velim yard on 4th March 2017.
Tam
13 Aug 2017
Czech Republic
385s at Velim yard, viewed from the top deck of a passing City Elephant.
duffers2324
1 May 2014
385001 and 385102 both out on test again earlier tonight between Edinburgh and Grantshouse U.P.L was great to see it up close and personal at Waverley and also got a couple of pics also had a little peek inside.
mcmad
11 Mar 2015
380's will be used in the interim if the infrastructure is available before sufficient units are in service and proved reliable
D365
29 Jun 2012
Wasn't that always an interim plan? Hence the additional Class 320 conversions.
Southsider
10 Aug 2015
I thought it was meant to be additional, unconverted 321s to serve the east coast routes and free up the 380s from there. I've not seen anything confirming they had arrived and assumed that was down to infrastructure delays meaning they were no longer required.
Does anyone know how many 385s have been produced and where this stands against programme?
SC318250
4 Jun 2011
If a half hourly electric service was required then guessing there are enough 380 units 2x7 cars already available
Another 2x7 cars would be needed
Dont know diagrams but guessing a couple of 7 car diagrams on Ayrshire could be replaced by 6 cars (2 x 380/0 from Inverclyde to Ayrshire) replaced by 314
A 4 car 380/1 on Inverclyde replaced by 314. A 6 car 318/320 on Lanark, then replace 2x314 on Cathcart etc, with the 380/1 on to Lanark
The 334 should have enough slack to release another 1 or 2 into service, which could replace 318/320 on Argyle line to allow another 2 x314 off Cathcart to Inverclyde, which would release 2x 380/0
Or if the other couple of 320/4 are done.
Hope this makes sense
Other option
Could be to put 170 on to North Berwick for a couple of weeks to release 380s
Starmill
18 May 2012
Bolton
I don't think so. It was a franchise commitment to operate some 7 car services on the E&G from December 2016, and enough 380s (to work as a 4 car coupled to a 3 car) were apparently available to cover that work. Unfortunately the wires weren't. The arrival of the additional 320s produced a number of diagram changes that were much discussed on here at the time - someone can hopefully confirm, I think they are still in effect - that involed 320s doing limited work to Gourock and on the Cathcart circle!
Typhoon_93
29 Oct 2012
Newton Aycliffe
How many sets exist now? Complete and otherwise.
Had no idea we were up to 014!
385001 - Scotland on Test
385002 - Germany on Test
385003-013 - in production at Aycliffe.
385014 - Arrived at Aycliffe complete from Japan via Tees Dock on Friday 15/09/17.
385015/016 - Arrived at Tees Dock complete from Japan.
385101 - Germany on Test
385102 - Scotland on Test
385103/104 - Arrived at Aycliffe complete from Japan via Tees Dock currently on Test at Aycliffe.
385108-115 Shells are at Tees Dock awaiting the call to the factory at Aycliffe.
385122 - Arrived at Aycliffe complete from Japan via Tees Dock currently on Test at Aycliffe.
Hope this helps
Gareth
route101
16 May 2010
Class 320s dont operate to Gourock though one managed to get diagrammed onto a service but it was cancelled before it left central . Must be to do with Driver knowledge . They do Newton but not Neilston . ]
I did spy 380 stopping boards at Edinburgh Park funnily enough for 7 and 8 cars
Southsider
10 Aug 2015
When the wires were due to go live in May there was a plan for short term lease of four, standard (i.e. four car) 321s. Time has moved on and it looks likely that plan has been shelved in favour of 380s with 385s shortly after but still dependent on an unknown date for service trains under the wires. Franchise commitments and other plans are up in the air given the uncertainties around electrification milestones.
170401
9 Feb 2010
Hope this helps
Gareth
It certainly does, thank you Gareth :D
iainbhx
8 Jul 2014
385 002 went through Magdeburg Hbf Platform 13 on Friday about 12:35. I was waiting for a RE to Berlin Zoo Bf and I managed to grab a very quick picture. It was part of test train and top and tailed with test train stock.
Mordac
5 Mar 2016
Bet that confused the German spotters!
Typhoon_93
29 Oct 2012
Newton Aycliffe
385016 has now started to arrive on site at Aycliffe with one car arriving on Friday (444016) the rest should be Monday/Tuesday.
170401
9 Feb 2010
This article appears to suggest the first class 385 will run on the E&G sometime in the next few days.
Anyone know anything?
https://www.globalrailnews.com/2017/10/12/hitachi-rolls-out-first-uk-built-class-385/
Hitachi has presented the first Class 385 for ScotRail to be built at its Newton Aycliffe plant.
The rollout comes a few days before a Kasado-built Class 385 takes power from the newly electrified wires between Glasgow and Edinburgh for the first time.
Another three partially built units completed the line-up at a press event earlier today.
The distinctive look of the units is a result of them being the only class in the current Hitachi UK train build with a corridor connection, which Transport Scotland specified as a requirement.
Currently there are two Class 385 units under test in Scotland. Two units are also subject to ride testing on the German rail network as part of the type approval process. This is being done there as it is felt there is not sufficient track access in Britain to complete these tests within the programmed date.
Following the roll out, there was a press tour of the plant to see the Class 385 and Class 800 unit production lines.
Hitachi advise that 71 per cent of all parts are supplied from the UK. These include pipework, windows and internal fit-out. Parts supplied from outside the UK include bogies, which are supplied from Hitachi’s plant in Naples, wiring looms from a Hitachi plant in China, with Japan supplying bodyshells, traction equipment and air conditioning units.
InOban
12 Mar 2017
According to 92002 in the Scottish electrification thread, driver training on the E&G is due to start on Monday.
Chris225
18 Jan 2016
some late night runs starting Tues night appeared on RTT a couple days ago could be 385 testing or training runs.
Carntyne
8 Jul 2015
I believe a Class 385 made it on to the E&G last night for the first time for testing.
