Railway General Knowledge.
D841 Roebuck
16 Mar 2012
Rochdale
I think 03091 was the first shunter withdrawn with a TOPS number. By "mainline", however, I meant something capable of over 30mph - not a gronk!
D841 Roebuck
16 Mar 2012
Rochdale
I thought it was 31150, but on checking this wasn't withdrawn until 10/75 (although its crash may have been earlier). As 24061 was 08/75, your answer is better than mine!
Over to you...
Mvann
19 Mar 2010
Peterborough
The 31 accident was 11th July 1975. The 24 was withdrawn on 1st August. Open floor for now.
What was the first TOPS numbered electric to be withdrawn?
Mvann
19 Mar 2010
Peterborough
Incorrect.
Actually it is correct. Been back and checked it. I had it down as a class 74
D6975
26 Nov 2009
Bristol
Give the numbers of 2 class 37s that ran with 2 names at the same time. (ie different plate on each side)
D6975
26 Nov 2009
Bristol
37 408. But 37 428 is recorded as having loch awe one side and loch long the other
Apologies, I missed 428, it did briefly carry Loch Long on the second side after carrying Loch Awe on one side only.
The one I was thinking of was 37410.
ole man
6 Jul 2011
LEC5
As it is a Open Floor (i think)
Where on the WCML will the Down Fast br removed and why?
BestWestern
6 Feb 2011
Another easy one then; what odd 'feature' (think numbers) is shared by Bristol Temple Meads, Bristol Parkway and Cardiff Central?
clagmonster
8 Jun 2005
Do they have 'missing' platforms? There is a long removed closed bay at Cardiff Central, no platform 14 at Bristol TM and there is only one of the two new platforms I believe at Parkway, so maybe they have done something strange there.
BestWestern
6 Feb 2011
Very quick, well done :) Yep, missing platforms would be the answer there. The missing bay at Cardiff would have been platform 5, there is no longer a platform 1 at Parkway, and as you say Temple Meads lacks a platform 14. Platform 2 is also a moot point, as it's no longer used for passenger services and is just a stabling point these days.
clagmonster
8 Jun 2005
Is the other half an inch below Sharnbrook?
I suspect / hope though you are looking for Desborough.
clagmonster
8 Jun 2005
I suppose I'd best chip in with a question. What connection is there between the current status of PWM650 (aka 97650), and the city of its birth.
