Northern 323s refurbishment and cascade
clagmonster
8 Jun 2005
The 331/1s are to be based at Allerton, but I don't know how many 331/0s are to be based at Allerton and Neville Hill respectively.
I recall that thee were to be 16 331s at Neville Hill and the remainder at Allerton.
childwallblues
3 Jul 2014
Liverpool, UK
I can't see anything more sensible than sending them all to Northern following PRM changes and new seat covers. They are perfectly suited to Northern's EMU needs as they are, and despite being quite old now still look very modern. Then scrap the 319s, they're old and unreliable anyway.
319s are pretty reliable these days.
prod_pep
8 Aug 2010
I have to disagree. There have been several diesel substitutes on 319-booked diagrams recently, and considering how many spares there should be each day, that is very poor. One also let me down only the other week to Broad Green.
I'm desperately hoping common sense prevails and the 319s are kicked into touch sooner rather than later.
185143
3 Mar 2013
150121 did the 16:16 Crewe-Liverpool one day last week!
Red Devil
6 Jan 2016
16.45 Liv-wgn. Enough passengers waiting to fill 2x319's.
What turns up? 1x 142!! Appalling and shameful
AMD
6 Dec 2017
It's not great, but the alternative yesterday was to cancel the service; as it was 142070 which was originally working that diagram failed at Wigan which didn't help matters.
In what way? The Class 319 interior is basically identical to the Class 150 interior (layout as per /1, seats as per /2). Indeed the seating as supplied (except the small number of /2 sets with Chapman seats) is markedly inferior.
A 769 beats a pair of 150s, but that is only because of the pantograph.
The 319's are a massive improvement on the majority of 150's with 3+2 airline seating.
js1000
14 Jun 2014
The seating layout is similar. But that's not the problem.
The 150s are that they are noisy and grotty. Same with many of the Pacers and 156s. The EMUs generally are not. 769s would represent a big upgrade on the 150s. I can certainly see Northern increasing the order from 11 to 20 if the 769s are a success.
Chester1
25 Aug 2014
Northern have expressed interest in replacing sprinters prior to 2025 but Porterbrook only lease 11 x 2 car 150s, 8 x 153s and 7 x 155s to Northern which limits the options to swap units. The 156s are decent units for routes that do not justify a 158 or 195. From a long term perspective it makes to make sure Northern lease 323s, convert 319s as possible and get rid of Porterbrook 150s, 153s and 155s. TfW are only leasing their 5 x 769s as an interim measure so maybe they could go to Northern and some sprinters be scavenged for parts and scrapped?
MatthewRead
21 Nov 2014
West london
Actually TFW are leasing 9 769's
Jonny
10 Feb 2011
Perhaps the 323s could fill in for some of them once available; however 323s have a slight weakness in terms of being limited to 90mph in service as it stands.
MatthewRead
21 Nov 2014
West london
They're leasing five, with an option for a further four units.
It has been confirmed in the latest issue of Today's Railways that they will taking on the additional 4 units they are planning to remove the pantagraph's pending electrification.
craigybagel
25 Oct 2012
The 323s acceleration to 90 is so much better then the 319s however - it would need to be a very long stretch at 100, probably longer then any that exists between stations on the Northern network, for a 319 to outperform a 323.
Mogster
25 Sep 2018
Having travelled on Northern 150s and 319s recently there’s really very little difference. The seating arrangements are just as bad, with the windows open they are both noisy, there’s no aircon, both were old with dirty interiors.
The only advantage, and it is a big one, is that a 4 car 319 can’t be split in 2 so a shortformed service is impossible...
The 319s seem to be disappearing lately, not sure if that’s a sign Northern are having problems keeping them serviceable.
The 100mph of a 319 is at times theoretical due to the tendency of DC motors to fade away at about 80 mph. A 323 has much more chance of reaching 90 mph quickly and sustaining it.
The only bit in the north-west where I’m thinking the 319 might have the edge is on a non-stop run along parts of the WCML.
I don't really see how anyone can compare crampt and not fit for purpose 3+2 airline seating on most of the 150's, with the generally much more open layout of the 319's. The two are worlds apart.
In terms of poor availability, perhaps Northern just don't have enough of them for routine maintenance, and should aquire more from off lease.
craigybagel
25 Oct 2012
The only routes that see 319s and have linespeeds greater then 90 are South of Wilmslow on Crewe services, and between Wigan and Euxton on Liverpool-Preston services. With the amount of station stops on the former, and the relatively short distance of the latter, I don't believe the 319s would be able to sustain 100mph long enough for that extra 10mph to cancel out the vastly superior acceleration of the 323s all the way up to 90mph.
Mogster
25 Sep 2018
The 319s I’ve travelled on recently had exactly the same cramped 3+2 seating as Northern’s 150s. Same weird low seats also.
sprinterguy
4 Mar 2010
Macclesfield
Around two thirds of the Northern 150 fleet has the same cramped, low backed 3+2 Ashbourne seating as their 319s. Only the ex-First North Western 150s were fitted with high-backed 3+2 Chapman seating when refurbished around the turn of the millennium.
43096
23 Nov 2015
Or perhaps the maintenance is c***, like everything else on the TOC.
It's the point about 3+2 airline seating though. I don't know the proportion, but the vast majority round my way, except the ex GW ones have airline seating.
keith1879
1 Jun 2015
Exactly so. I find that in an airline seated class 150 there are very few seats where I can sit without hurting my hips ....my legs are just slightly too long. Similarly the class 323s ....Ok they accelerate quicker and were supplied brand new but they are unbearable to sit in with the exception of a very small number of seats.
driver_m
8 Nov 2011
Agree with @yorksrob They're the same seats, but the way they're positioned bears no comparison. The 319 is a much, much better setup than a 150. Yes they're low, but you don't crack your knee on a 319 unlike a 150. Which for me, are Northerns worst unit to travel in. Yes, that includes 142s. Even 'those' ones.
ABB125
23 Jul 2016
University of Birmingham
Slightly off topic, but Porterbrook will soon have 37 10-year-old class 350s sat in a siding. Would these be more suitable to Northern than either class 319s or 323s (at the right price of course!)?
507021
19 Feb 2015
Chester
I hadn't realised that, apologies.
