More Delay for HS2, and how should we proceed?
Sad Sprinter
5 Jun 2017
Way on down South London town
If you were traveling from Birmingham to Glasgow why would you want to go through Manchester?
Would there be enough demand for individual Birmingham to Scotland/Manchester to Scotland services? I'm talking about a complete high speed route to the Central Belt, so no stops on local stations up the WCML
I suppose and East/West through station in Manchester could open up Leeds/Sheffield to Glasgow high speed services
MPW
2 Dec 2021
Orpington
If HS2 used the existing platforms, how do you release capacity on the WCML?
My thinking was that a tunneled station would be cheaper for existing services compared to HS2 trains which seem to need larger platform and circulating spaces based on passenger numbers etc.
(read ahead at your own risk) alternatively with significant scope creep - a tunnel to connect to another existing rail corridor eg Fenchurch St, with two central london stations each with lower size and other spec requirements compared to a terminal HS2 station. Not saying this is cheaper! I can't help but try to think of a potential future positive outcome from the delays, which I am still finding hard to swallow.
You would need a tunneled station with 15 platforms at least though if you are assuming the existing WCML and DC lines? HS2 doesn't need as many as that.
Routeing Leeds and north-east trains via Manchester would surely lead to the combined HS2/NPR line south of Manchester being overloaded.
Not at all.
Also, assuming a terminus station at Piccadilly, there would be an enormous number of train moves into and out of the HS2/NPR platforms every hour.
Not at all.
There is now!
MPW
2 Dec 2021
Orpington
Whatever paths would free up enough space at Euston for HS2, probably focused on the routes travelling the shortest distance to improve cross-London connections, or whichever has the shortest trains and therefore least space requirement. I was not thinking 15 platforms! My question was really just that, a question, as I did not see this considered in any of the reports I saw, including the station alternative report linked above. Thanks very much for pointing out how unrealistic it is :)
Sad Sprinter
5 Jun 2017
Ever been on XC? The Avanti West Midlands - Scotland services aren't quiet either.
I have never been on XC now you mention it.
Interesting, so a HS2 London to Glasgow/Edinburgh HS line could have
Birmingham, Manchester Airport, Preston, Glasgow/Edinburgh
(Liverpool/Sheffield?), Manchester, Manchester Airport, Preston, Glasgow/Edinburgh
Ah yes but these still pick up at places like Oxenholme and Lancaster en route which presumably a HS line would miss out?
An imaginary HS line from Crewe / Golborne to Scotland would certainly miss some stops, but not all.
What about north/east of Manchester?
If you mean the new line from Manchester to Yorkshire, then that will easily cope.
Energy
29 Dec 2018
The current London - West Midlands - Preston - Scotland WCML service will remain post HS2 for Oxenholme and Lancaster.
There's no planned connection between the HS route into Piccadilly, and Preston, without going back to Crewe.
The original plan did have a 3rd side to the HS2 triangle near Rostherne towards Golborne/Wigan, but that's been "paused", if not canned.
There's no other connection to the classic network north of Crewe.
There will be no connection at Manchester Airport either.
stuu
2 Sep 2011
Yes, but there is currently no plan for any new line east of Marsden, at least not that the government have included in their plans. Is there really capacity for long distance trains through Huddersfield and Morley?
snowball
4 Mar 2013
I think the north side of the triangle was definitively dropped well before the Golborne link itself was dropped. It was only ever intended for empty coaching stock movements, when a depot was planned south of Wigan, later moved to Crewe.
matacaster
19 Jan 2013
Huddersfield
The HS2 railway, UK: route optioneering document details the station selection, on page 7, from 27 initial options, to 10, then to 4 and finally to 1 preferred (Euston) and two alternatives (Euston double-deck and "King's Cross Lands - cut and cover").
It's an interesting document that details a lot of the thought that went into route selection along all of Phase 1.
Screen capture of the relevant page:
Very interesting, thanks.
yes.
Greybeard33
18 Feb 2012
Greater Manchester
Speaking to people I know, all the planned disruption for Handsacre on the Trent Valley lines has been pulled for the next 18 months (apart from next weeks 9 day block). So clearly that points to it being paused.
AIUI the HS2 work planned for the WCML 9 day block next week is to install the bridge over the HS2 mainline near Whittington. That will eventually be needed for Phase 2a even if the Handsacre link is abandoned.
It is perhaps more significant that work on Handsacre Junction itself has seemingly been paused.
The Fulfen Wood bridge push was always going to happen, that was too late to be paused. That block also has a large amount of NR work in it so would have likely took place regardless. The moving of cables, OLE, earthworks etc to faciltate Handsacre Jn has all been culled.
david1212
9 Apr 2020
Midlands
I have lost the plot now.
Beyond Old Oak Common - Birmingham Interchange - Birmingham Curzon Street and when designed, approved and funded an 'affordable' continuation to Euston is anything else comitted to?
If there is no link at all to the WCML there can not be classic compatible trains beyond Birmingham even via Wolverhampton / Stafford rather than direct to Crewe. If no link at all to the Birmingham - Derby line likewise no classic compatible trains towards the north-east.
SCDR_WMR
17 Dec 2017
Crewe
Indeed, Colwich Jnc work and Lichfield bridge removal also this week I believe
Tezza1978
22 May 2020
Warrington
I'm pretty nigh on certain that the link to the classic lines will be built. Would massively detract from the business case and value for money if removed.
Looks like its just been kicked into the same 18 month/2 year delay for budgeting reasons as the tunnels from OOC to Euston IMO. Personally I think its pointless to put this delay in as it wont save any money "overall" but its clearly to try and give the (useless) government some fiscal headroom to desperately put in a last minute tax cut before the election...
350401
5 Feb 2009
The phase 1 business case is partly based on being able to run trains off HS2 and into the classic lines. Handsacre will open during the 2029-33 window, albeit later than the first captive phase from OOC to Curzon Street. There may be a bit of rephasing of works to give the government fiscal headroom for pre election tax cuts, but even the current government aren’t so mad as to axe the link that enables the line to be used as more than just a Bham to London shuttle.
There will be the option to avoid building the Handsacre WCML junction as long as HS2 is built to Crewe.
But that choice is a couple of years away.
It would upset Stafford/Stoke/Macclesfield users who can only be served via the Handsacre link.
