London Underground stock requests
Chris217
7 Nov 2018
Can't see it on Intertube, but there's a couple of even numbered leading sets just come out of Northfield but which haven't yet reversed anywhere so I can't see what's on the other end... I'd suggest keeping an eye on Intertube every half hour or so.
Thanks
bluegoblin7
10 May 2011
JB
Given the Piccadilly is currently dealing with/recovering from a person under train incident it definitely isn't the best day to go unit hunting! With a special service being implemented (500 series numbers) what is out is what will stay out until much, much later this evening.
jldavies455
15 Dec 2025
Putney
I have time to kill today, I know nowhere near as much as any of you lot, so are there any interesting things out on the LU network, RAT's, engineering, etc, preferably south or west as I don't really want to spend ages travelling up to Harrow for D stock!
Mawkie
17 Feb 2016
#730 and #731 are both out and about today - they are usually the Pic RATs.
Have a look on Intertube.
(Image of a live tracker screenshot from Intertube shows Piccadilly line train #730 headed towards Uxbridge)
bluegoblin7
10 May 2011
JB
3-car 73TS, yes.
Both Central line RATs, T488 & T489, were out this morning - these don’t run as consistently as other lines, but are worth spotting if you can, being formed of 1962 Tube stock. The west end 5-car makes it as far as White City.
That’s your lot today though, if you don’t want to go up the Met.
sad1e
26 Aug 2024
See this thread for RAT timetables.
Speaking of the RATs does anyone know the last time D stock RAT 7040+7107 ran.
For at least the last 2 years it's been RAT 7010+7123 covering the Met line RHTT although I do know that 7040+7107 is still around as I did see it while passing West Ruislip Depot in the simmer
TheEngineer
20 Nov 2023
Milton keynes
slightly long question, but just looking to close out my tube required stock for 2025 if anybody can please help/confirm
Bakerloo
3260 / 3532 - not in service and stored at Stonebridge Park
Victoria Line
17+18
35+36
both stored at Northumberland Park, 35+36 currently being repaired and hopefully back early 2026?
Jubilee Line
96049 - stored 2021?
96056 - Stored 2023?
96091 - set seen outside Stratford market depot but unable to ID each carriage number
96126 - stored 2020?
are all these sets on Stratford depot?
Northern
542+543 - last time i asked were split and not visible on Golders Green depot?
S Stock
21101/102 - not in use in 2025 and stored and Neasden?
21315/316 - stored since 2023 at Upminster?
21469/470 - visible on alps sidings on /Ealing depot covered in Grafitti I believe
Central
Clip Formations
111/446/222/263 ?
001/054/176/201?
093/026/206/109?
Where are:
155, 331, 012 ?
Stored at Hainault - 075 101 341 150??
if anybody can confirm / help with the above it will be much appreciated
Many Thanks
Dstock7080
17 Feb 2010
West London
Central
Clip Formations
111/446/222/263 ?
001/054/176/201?
093/026/206/109?
91111+93446+93222+91263 Ruislip
91155+93012+93142+91331 Acton Works
91201+93054+93176+91001 Ruislip
91093+93026+93206+91109 Ruislip
91079+92100+92232+91043 Acton Works
Peter Mugridge
8 Apr 2010
Oakham
Central Line 341 and 150 are at Ruislip, not Hainault. Both are now unlikely to ever run again - they are basically just empty shells with most components removed and I can't honestly see them ever going back into the CLIP programme.
For the S Stock on the Met - I could have sworn I saw 21101/2 out and about a month or two ago, but unless I rode it I wouldn't have bothered to write it down.
TheEngineer
20 Nov 2023
Milton keynes
Thanks Peter, next time I am in London I will pass Ruislip just to see if either are visible outside somewhere
I look almost every day on Intertube and have not noticed 21101/2 out but I could be wrong.
boiledbeans2
15 Oct 2020
Victoria Line
17+18
35+36
In fact, it's the opposite. 17+18 is currently being repaired and not visible. 35+36, currently no plans for repair, but visible on 24th Road. Visible from Northumberland Park station.
TheEngineer
20 Nov 2023
Milton keynes
Many thanks for the information... can I ask is 24th road outside, or would I just see one end from the station platform... its a long time since i viewed the depot.
Peter Mugridge
8 Apr 2010
Oakham
Try with binoculars from the Carbuncle Passage footbridge if it's not visible from the station? There's a decent view of the depot from there...
boiledbeans2
15 Oct 2020
24th road is under a shed. If you go to Northumberland Park station during weekday rush hours, when minimal number of trains are parked at the depot, you should be able to see the first carriage of the south end of the train. The other carriages would be blocked by the shed wall.
TheEngineer
20 Nov 2023
Milton keynes
Thanks for the confirmation, much appreciated.
Thank you again Peter
Graeme186
6 Nov 2025
Bitton
Utilising data provided by the marvellous Intertube website, my records show that S8 21101/102 was last used in passenger service as T444 on Saturday 06th April 2024
sad1e
26 Aug 2024
Definitely wrong , i rode it on a Watford service on the 7th August 2024.
Graeme186
6 Nov 2025
Bitton
Sincere apologies, I should have been more thorough with my check. I record 21101 being returned to service on the 05th August 2024 following being stopped on 06th April. However, I've not recorded it in service in my S8 fleet monitoring since the restoration of the TfL data feed on the 23rd October 2024.
TheEngineer
20 Nov 2023
Milton keynes
Thanks, that confirms my thoughts its been OOS for a while.. I look at Intertube most days to see if any of my 'wants' are out.
Thank you again, I popped out earlier and although 67&68 were blocking the view I think I could just make out 11035 through the windows on 24 road.
pokemonsuper9
20 Dec 2022
Greater Manchester
I appear to have written down 1992 stock 93342 as ridden (I suspect I may have misread 9342#), despite that unit being in the gap of the 93###s, does anyone know what's in it's place in the formation (115+???+238+209).
It was on Friday on train #123 if that matters.
notverydeep
9 Feb 2014
From the compositions list for Monday, it was 93242 rather than 923342. Today's list shows the formation is still 115-242-238-209...
