Interlaced track near Mitcham - what's the point?
Purple Train
16 Jul 2022
Exile or exile
On the Tramlink system, in the Mitcham area, there's a section of interlaced track. Wikipedia said that it was included as the cutting towards Belgrave Walk was too narrow, but, if that was the only consideration, why not just use plain single track? Was it simply to avoid building points at each end, or is there another reason?
(Or, indeed, no reason at all?)
(Photograph courtesy of Wikipedia)
hexagon789
2 Sep 2016
Clearance issues I understand
paul1609
28 Jan 2006
K
For a tramway where the trams are driven on line of sight it a simpler and safer system of operation in that you don't have any point operating mechanisms to go wrong.
The cutting was too narrow as an unstable part had years previously had retaining wall added that imposed on alignment of a potential second track. Could have been widened (at a cost) but the tram conversion budget meant wasn’t worth it for short length
The short interlaced section avoids installing points so keeps it simple
geoffk
4 Aug 2010
Exeter
I assume BR didn't adopt a similar policy through the Hastings line tunnels because of possible issues with the live rail.
Recessio
4 Aug 2019
Edit: previous post deleted, I misunderstood the quoted post.
How does live rail work with interlaced track? Presumably the interlacing is spaced so you don't have a live rail where you need a running rail to be?
Basil Jet
23 Apr 2022
A pair of live rails, one each side, might do the trick. At Hastings, I wonder if the need to narrow the twin track was so slight that they might have got away with 5 rails (two tracks and a shared live rail between them, obviously signalled as a single line), but they would need special sleepers made, so just didn't bother.
Taunton
1 Aug 2013
Interlaced track, avoiding points, is quite common on tramways. Here in Leidsestraat, Amsterdam, a single track busy but narrow street, with passing loops every few hundred metres at each canal bridge, the whole street is done closely interlaced, avoiding a series of points :
I don't think Network Rail has any interlaced track, so no experience.
Interlaced track may also be used to avoid putting a point in the middle of a road junction, as at Croydon and Nottingham.
Basil Jet
23 Apr 2022
In Amsterdam there is (was?) at least one place where the points are three tram lengths of interlaced track before the junction: this is so that trams can trickle through the points over time and queue on the correct track, so that when the lights turn green all three trams whizz off in different directions without wasting any green time on changing points.
tbtc
16 Dec 2008
Reston City Centre
My understanding is that this is the reason for similar short bit of track between the Hillsborough tram stop and the Malin Bridge/ Middlewood junction on Sheffield Supertram
The points are at the north western end of the platform (outside the Rawson Spring pub, https://goo.gl/maps/UriPqx3rsqj6aaor7 ) so that trams are already on the appropriate line when they leave the segregated section and rejoin the traffic of Langsett Road
So the mechanics happen on a bit of track that doesn’t have dozens of buses/ trucks etc lumbering over it (potentially damaging things) and that the points can be repaired without having to close the road
(I love these kind of solutions to problems)
D365
29 Jun 2012
On the flip side, there are some crossovers which are located on road sections. But I imagine that these crossovers were avoidable, and are infrequently used.
They are presumably also trailing crossovers, so not motorised or detected and either trailed through sprung or worked manually with a lever. So much less to go wrong with these.
To return to the original topic "Interlaced track near Mitcham - what's the point?" - surely the point is that there isn't a point?
Purple Train
16 Jul 2022
Exile or exile
:lol:
Just so that I can work out what you're saying here, are you referring to points in the middle of road junctions at Croydon and Nottingham, or interlaced track laid specifically to avoid putting a point in the middle of a road junction?
:lol:
Both Croydon and Nottingham have sections of interlaced track which are for the purpose of avoiding having a motorised point in the middle of a junction.
Purple Train
16 Jul 2022
Exile or exile
Thank you. Where's the Nottingham example? (I never noticed it - but if it's on a section I travelled on rarely then I might feel a little better about my memory)
How long a distance does interlaced track have to be before two point machines would be considered to have a lower life cycle cost?
Is this impacted by the complexity of the signalling arrangements? What about a hypothetical branch where all the trains are using ETCS L3H and have no need for axle counters and the like?
dosxuk
2 Jan 2011
I believe that is also the case with this (very short) bit of interlaced track at the Cathedral crossover - without the interlacing the point motors would have been in the middle of the York Street crossing.
Why would the signalling for an interlaced track be any different to the signalling for a single track?
No point machines, and all the equipment required to prove them.
If you can use ETCS 3H you don't need any power supplies at those locations at all.
The signalling for non-interlaced track would have to operate and detect the points - even if it was of a form that didn't need other trackside equipment.
MCR247
7 Nov 2008
Ah. In that case I cannot feel any better about my memory - I used to travel on that section most regularly out of all the sections :oops:
One of the tracks that is interlaced is rarely used - it is the access to/from the middle platform at the Forest from the Wilkinson St direction. The other is the normal southbound line into the southbound platform
Revaulx
17 Sep 2019
Saddleworth
Manchester also: the up track that splits into two at the foot of the ramp coming down from Deansgate-Castlefield.
Lucan
21 Feb 2018
Wales
The site of the Mitcham interlacing had double track originally - from around 1802 (not a typo!). The Surrey Iron Railway came through here, although it had a level crossing with the London Road rather than going under it. The LBSC seems to have dug deeper and built the road over-bridge when they bought the SIR trackbed for their Croydon-Wimbledon branch.
The LBSC/SR/BR branch was mostly single track but was double for the mile from Mitcham Junction, through Mitcham Station, to Mitcham goods yard, the site of which was in the background of the top photo. This stretch was also the passing loop for the two shuttle passenger trains that worked the branch.
Around 1970 the wall on the right of the photo started subsiding. It belongs to the back garden of a large house on London Road that at the time was the Mitcham Labour CLub and is now some sort of church. The wall was first braced with timbers with footings in the "Up" track (the Croydon direction). The line was singled from a point on the Up side of Mitcham Station and the Up platform fell out of use. The goods yard was closed about that time. Later, the up track was lifted and the timbers were replaced by the massive concrete masonry seen in the photo today.
Purple Train
16 Jul 2022
Exile or exile
That doesn't make my memory feel at all better, as I'm now going, "What middle platform?"
